What an awesome little tool, just bought one with plastic shell for $15! ![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
My 2 cents:
There are so many hardware variants based on the exact same core schematic and before everyone rush to buy the variant that Dave reviewed, I think it is better to evaluate which will better fit your needs.
The main difference I considered are:
Thru hole vs smt components If you forget to discharge a capacitor before testing it the THT version can be fixed quickly
Assembled vs DIY Kit a DIY kit shouldn't be an issue in this forum
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
With push button vs with rotary encoder whith the encoder it is easier to navigate in the menu to select specific measurements options (opto, IR, Servo...)
With case vs without case I like the case one
For instance my personal preference is the one that is called Hiland DIY M12864 Kit at Banggood, because it is THT, it has a nice case and it is faster than the color display variant.
I modifyed it to have:
External input voltage
ICSP connector
UART for measurement logging also with Bluetooth....
Mauro
