Charging at home certainly is helpful, and having solar (and plenty of sun) is nicer still, but I'll wait until hydrogen fuel cells or standardized swappable batteries are common. Electric cars are still immature technology.
Swapable batteries are preferable to taking 10 seconds to plug in at home every night? ![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
Swap-able standardised batteries have several advantages. But I can't see auto makers embracing them because they will dictate the styling of the car to ensure rapid swap access. If that is a requirement. It requires a standardised battery compartment. Since they are so big they will constrain mechanical design to a degree as well. Also innovative companies will want to market their technology as superior. If it is a good idea buyers will have to force them.
It would be great on trips where you might swap a battery for a freshly charged one much as you do with a gas bottle for the BBQ. It would help prevent queueing at charge point as the popularity of electric cars increases. I can see that becoming a problem in smaller towns where a music festival or some post Covid large event is held. The charging infrastructure might meet normal usage but an extra few hundred people all wanting to charge at the same time could be a problem. But then so too will holding a stock of replacement charged batteries unless someone with foresight plans for the influx of visitors.
Plus owners needn't own the batteries and therefore they wouldn't own the need to pay to replace it when it dies and neither would the resale value of the car be as diminished because the new buyer will discount the car by the expected battery replacement cost. Availability of replacement batteries will limit the lifetime of a used car and with electric cars being mechanically simpler you would hope electric cars could have a long service life that isn't foreshortened by the unavailability of replacement batteries. At least at reasonable cost commensurate with the reduced value of the older car and the cost of just buying a new car. With standardised and backward compatible batteries older cars could hopefully utilise newer (cheaper?) technology even at the first battery replacement let alone the second or third.
Even if you didn't have slide out - slide in quick recharge battery upgrades, standard and hopefully cheaper mass produced common battery packs still seem a good idea to me. You rent the battery as long as charging is convenient and swap them when time is short like on a trip. If your car is a glorified mobility scooter 95% of the time as if it were a second car for school runs and shopping then you could just rent a small battery until you needed a longer range one for the holidays.
Yes it seems like you're paying something that you needn't if you owned the battery but you do get the benefit of not selling the car extra cheap because a new buyer doesn't want to wear the large cost of a new battery in a car they don't intend to keep long enough.
The decisions made when a battery eventually needs to be replaced is to me one of the unspoken of disadvantages of electric vehicles. I wouldn't like to see cars with useful service life left just scrapped like we do with other appliances because the new ones are just too cheap and new battery packs too expensive. Getting the huge capital cost of battery replacement off the table seems like a good idea to me.
I just wish power tools had something similar. The modern fad of power tool skins is a partial solution but there seems no reason that benefits the end user to stop there.
