Author Topic: EEVblog #1331 - BattLab One Review  (Read 3289 times)
Online EEVblogTopic starter
« on: August 21, 2020, 03:30:06 am »
Review of the BattLab One open source battery life estimator tool from Bluebird Labs.
A tool that allow you to measure the current and power consumption of your product in active and sleep modes and do "what if" analysis on estimating product battery life.
https://bluebird-labs.com/
Offline Dave
  • Country: si
  • I like to measure things.
Re: EEVblog #1331 - BattLab One Review
« Reply #1 on: August 24, 2020, 09:58:06 am »
7:30
How exactly are you going to calibrate Rds(on) out in software, when it is highly variable?
The Vgs depends entirely on output voltage setpoint and the resistance is also going to vary with temperature.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
The following users thanked this post: Dave_PT
« Reply #2 on: August 24, 2020, 11:33:55 am »
7:30
Temp is the main thing but that's not a huge deal except for precision work. And it's reasonably linear so can be mapped in software reasonably well.
In this case with say a 10mohm Rds it's going to be an order of magnitude lower than the sense resistor, and then temp coeff is like a few percent of that over say a 50C range.
I deliberately didn't want to go into a tangent at that point.
