Hi I watched the video on building a power supply, video #221. I want to built one of my own. However i want to build a SMPS and also control the current (0-10A) and voltage (0-50V).
Can I follow a similar approach? Im thinking on building a SEPIC dc converter and want to control the current and voltage. I then want to display the set values as well as the output values of the current and voltage. So i may use a mirco controller... Any advice on how to approach this?
