Author Topic: EEVblog #1324 - Scope TRICK: 2 Probes 1 Hand  (Read 6249 times)
Offline EEVblogTopic starter
« on: July 27, 2020, 01:57:40 pm »
Dave shows how to use reference waveforms to capture, compare and time correlate more then one signal at a time on your oscilloscope when you just can't hold all those probes at once.
Offline Zbig
Re: EEVblog #1324 - Scope TRICK: 2 Probes 1 Hand
« Reply #1 on: July 27, 2020, 08:20:19 pm »
Fun factoid:
My PCBite kit with SP100 handsfree scope probes has just arrived few hours earlier today ;)
Offline Unixon
« Reply #2 on: July 27, 2020, 08:31:27 pm »
Dave, that's cool feature but it requires repeatedly stable behavior from a faulty device under test which is kind of counterintuitive. Am I wrong?
« Reply #3 on: July 28, 2020, 03:40:46 am »
That's why I said you have to find a stable reference point like a power supply ramping up. Trivial to check this first.
« Reply #4 on: July 28, 2020, 03:43:22 am »
Fun factoid:
How is that better than any other flexible arm clamp system for an existing probe?
It does look sexy though and I have those magnetic PCB clamps  :-+
EDIT: ah, I see it's a spring loaded tip.
« Last Edit: July 28, 2020, 03:59:11 am by EEVblog »
Offline Unixon
« Reply #5 on: July 28, 2020, 07:19:41 am »
I mean in a faulty device that point can be intermittently unreliable too and you won't even know it breaks your channel synchronization.
« Reply #6 on: July 28, 2020, 07:53:15 am »
Power supplies (especially linear ones) are pretty basic stuff, they don't just go haywire.
Obviously if you can't find a suitable sync then you don't use this trick, no big deal.
