Author Topic: EEVblog #1319 - NEW TS80P Portable USB PD Soldering Iron Review  (Read 14350 times)
Offline EEVblogTopic starter
The TS80P is the upgrade to the TS80, Dave's previous favorite portable soldering iron. But with added USB-PD and 30W vs 18W.
Various Aliexpress stores:
https://s.click.aliexpress.com/e/_BfZODpxj
https://s.click.aliexpress.com/e/_dUG2CxP
TC66 USB-C PD Power Monitor/Logger: https://s.click.aliexpress.com/e/_Bf8wne37
Offline Vovk_Z
  • Country: ua
Re: EEVblog #1319 - NEW TS80P Portable USB PD Soldering Iron Review
« Reply #1 on: July 14, 2020, 05:08:54 am »
"With added Power Delivery" but without it actually. :)
Offline Alterac
« Reply #2 on: July 14, 2020, 07:24:57 am »
Aparently the Power bank needs to support 12v @ 3a and 9v @ 3a in order to use its full power. (The manual, is well, normal translated english - Manual v1.1 PDF )
The iron LCD screen itself is displaying P which indicates that it is trying to use PD.
The chinese forums may have a newer firmware, but i cant find it.
Offline timelessbeing
« Reply #3 on: July 14, 2020, 11:12:36 am »
The niche for this product must be so small. I had a job where I had to frequently solder in the field, and never found myself lacking an outlet. Electronic equipment is usually plugged into one. Everywhere else we used screw terminals. And this thing certainly doesn't replace a desktop soldering station.  I don't understand why these have such a huge following of people :-//
The following users thanked this post: NivagSwerdna
Offline roli
  • Country: si
« Reply #4 on: July 14, 2020, 06:23:48 pm »
I don't see why it couldn't replace a desktop soldering station though. At least for most hobbyists. I currently have one of those Chinese Atten hot air/soldering iron combos and I've been looking for an upgrade. I've looked at the TS80 before, but the lack of power wasn't all that appealing and the TS100 just doesn't look all that ergonomic. So this one now looks like a real contender. I mostly solder SMD stuff anyways (rarely anything beefier) and the compact size is perfect for that. Sure I would go for a JBC... but I don't solder enough to warrant that. And the fact that I can take it out of the house and use it on a car or something is just a nice bonus. Unless you have a better option in the up to 150€ price range?
Offline maginnovision
« Reply #5 on: July 14, 2020, 06:57:46 pm »
I'd say a hakko 951, or a rip off, is a good option for cheaper, but good, mains station. I did production soldering with their older models as well and they were never something holding you back.
Offline roli
  • Country: si
« Reply #6 on: July 14, 2020, 07:14:24 pm »
Hakko in Europe is quite expensive from my previous look at it. So a 951 is not all that cheaper than a JBC. In which case I would rather get a JBC. A clone... sure it's cheap... but is it actually better than a TS80P? Both seem like an interesting options, so I am not discarding either.
« Reply #7 on: July 14, 2020, 08:42:57 pm »
twice as expensive as N.America in fact. Crazy! I guess it's not as popular as the euro brands.
https://eleshop.eu/hakko-fx-888d.html
more than twice the power, good sturdy stand. cool, comfortable handpiece and no tiny fiddly buttons in the grip.
(the old non-'D' station was better IMO. Button interface is stupid)
You should avoid using solder connections in your car anyway.
This thing is an underpowered toy. Doesn't matter if it's SMD, when you have multilayer boards with ground planes and via stitching (just one example).
« Last Edit: July 14, 2020, 08:44:48 pm by timelessbeing »
Offline CChin254
« Reply #8 on: July 15, 2020, 09:58:14 pm »
I did an IC Identification based on screenshots from the video. There were many unknowns with this one, so many chips are marked with the '?' sign when I can't confirm their part number/manufacturer/purpose.
The following users thanked this post: EEVblog, thm_w
Offline tszaboo
« Reply #9 on: July 15, 2020, 10:20:14 pm »
Because it is more expensive than that. And you want to have a holder for it anyway for safely storing it while not in use. And ESD.
Offline CoryV
« Reply #10 on: July 18, 2020, 05:30:26 pm »
Follow-on questions:
1. Does the Ralim custom firmware work with the TS80P and is it recommended? I can't find specifics on the Github notes yet.
2. (Most important): Does the wider hand grip prevent the iron from falling through the Hakko FH-300 stand?
« Last Edit: August 04, 2020, 04:09:39 am by CoryV »
Offline ha_embedded
« Reply #11 on: July 22, 2020, 07:47:39 pm »
Anyone tried a „PD trigger cable“ like this one with the older TS100?
https://www.aliexpress.com/item/4000382036783.html
With the 20V trigger cable the TS100 should deliver 40W if the data on the resistance I found is correct. 60W USB-C Powerbanks are quite bulky but there are also some compact 45W versions out there. Should be okay for this purpose.
I ordered a cable, so in a few weeks I can report here.
Offline CChin254
« Reply #12 on: August 01, 2020, 08:25:27 am »
I have an update of the last IC identification that I did of this device. What was noted previously as the power distribution IC was actually the accelerometer made by STMicroelectronics.
Offline 1847123212
  • Country: cn
« Reply #13 on: August 10, 2020, 04:11:18 am »
the unknown dcdc step down ic is MP9942GJ TSOT23-8 the description is High Efficiency 2A, 36V,410kHz,Synchronous Step Down Converter with Power Good
http://www.alldatasheet.com/view.jsp?Searchword=MP9942GJ
The following users thanked this post: CChin254
Offline CChin254
« Reply #14 on: August 12, 2020, 07:11:52 pm »
Thanks for letting me know! I fixed it now.
The following users thanked this post: MallV
Offline MallV
« Reply #15 on: March 22, 2022, 11:04:40 am »
Hi there guys,
Sorry for reviving this topic.I have this soldering iron and im trying to fin a way to fix it.Suddenly it shut down, i tear it down and i can't see any visible obvious defect;
Do you have a clue where I should start ?Thanks!
ps: it draws no power at all, no pd trigger, PD usb tester doesnt even wake up;
Is it a resistor?
Offline gamalot
  • Correct my English
    • Youtube
« Reply #16 on: March 22, 2022, 12:25:11 pm »
For those who are curious, chip #4 in the picture is probably FUSB302MPX.
https://rocelec.widen.net/view/pdf/0av2cqef3a/FAIR-S-A0001311862-1.pdf
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Offline Ungolian
« Reply #17 on: March 24, 2022, 12:12:49 am »
If you have a PD USB tester, and it's not powering up either, then there's no voltage coming from your power source.  Try a different cable and adapter.
Offline radioda
« Reply #18 on: December 29, 2022, 06:24:16 am »
