Author Topic: EEVblog #1273 - EMC Near Field vs Far Field Explained  (Read 6027 times)
Offline EEVblogTopic starter
« on: December 20, 2019, 05:50:06 am »
An explanation of near-field vs far-field in relation to EMC compliance testing.
H-field magnetic probes vs e-field electric probes.
Explanation extraction from video #1176
Wideband EMC log-periodic antenna: http://s.click.aliexpress.com/e/DQeIdwZ6
Near field probes: http://s.click.aliexpress.com/e/N5wdxeFQ
The following users thanked this post: jancumps, xrunner
Offline VK3DRB
Re: EEVblog #1273 - EMC Near Field vs Far Field Explained
« Reply #1 on: December 21, 2019, 01:06:05 pm »
Cheaper here... https://www.ebay.com.au/itm/153570679099
$87 Spectrum analyser for the poor man, good enough for use with the near field probes?
https://www.ebay.com.au/itm/Simple-Spectrum-Analyser-D6-with-Trace-Generator-Signals-Ratio-Frequency-Do-K7P3/223621365267?hash=item3410df3e13:g:5AoAAOSwkJxdUbT4
Or a $10 spectrum analyser for the very poor man...
You can also use a good CRO and use FFTs and a wideband RF preamp, instead of a spectrum analyser.
But these days, considering so many products have Bluetooth and/or WiFi, the ideal for many engineers is a spectrum analyser that goes to 3GHz, or better still 6GHz. It is just a matter of time before a NanoVNA equivalent in the form of a decent spectrum analyser becomes available at a fraction of the cost of a traditional spectrum analyser.
Offline VK3DRB
« Reply #3 on: December 23, 2019, 12:58:23 am »
You can also build your own near field test probes... https://interferencetechnology.com/diy-near-field-probes-preamplifiers/
Offline ocw
« Reply #4 on: December 23, 2019, 01:39:25 am »
The Seeed 114990711 / RFEAH-25 20 - 6000 MHz magnetic field probe is just $27.50 at Mouser.
See: http://statics3.seeedstudio.com/assets/file/bazaar/product/RFExplorerRFEAH_25datasheet.pdf
Offline arildj78
  • Country: no
« Reply #5 on: October 08, 2020, 09:38:14 pm »
@EEVBlog, are you still planning to show a DIY solution for far field measurements? So far I've seen some content on near field EMC pre compliance but DIY solutions to far field measurements are rare.
« Last Edit: October 09, 2020, 06:45:21 am by arildj78 »
« Reply #6 on: October 14, 2020, 12:08:53 am »
No plans, but possible. I have a couple of far field antenna.
Offline arildj78
  • Country: no
« Reply #7 on: December 08, 2022, 08:33:53 pm »
@EEVBlog, do you care to revisit this? I´m still waiting for content on DIY far field measurements and how to approach the jungle of compliance as a maker.
« Reply #8 on: December 09, 2022, 10:40:52 am »
Did you post this twice?
I'm not sure, as I got a database error when posting my previous reply, just want to ensure something weird is not happening?
Online nctnico
« Reply #9 on: December 09, 2022, 02:26:31 pm »
Stay tuned....
Offline arildj78
  • Country: no
« Reply #10 on: December 13, 2022, 10:51:37 pm »
No, I didn't post twice, but I did revive an old post.
Arild
