This transparent gel can be bought in 2x 1 kg glass bottles, it's a two component stuff that is pretty expensive. It has a shelf life of only 6 months.
After that the gel becomes unstable and does not fully "dry" and will still flow around.
Somebody wants some?
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
It's no problem to use it with the pressure sensor, it transfers the pressure in a very very linear way.
In fact it is so linear that Fluke uses that in their type 713 pressure calibrators. They use a NovaSensor NPC1210 with that gel inside to make it moisture resistant.
I have made some experiments with that gel for pressure sensors as well, and used Merit M12 series sensors.
They are also available with that gel inside the chimney, but with black dye.
Reason is that pressure sensors are also light sensitive and the gel then blocks the light.
It does not matter in the Cypres Product since there is no light inside.
