Author Topic: EEVblog #1245 - Most Excellent IBM PCjr Keyboard Repair  (Read 7205 times)
Online EEVblogTopic starter
« on: September 12, 2019, 10:28:30 pm »
Can you find the fault in the IBM PCjr wireless keyboard before Dave does?
A most excellent adventure in troubleshooting.
Offline SparkyFX
Re: EEVblog #1245 - Most Excellent IBM PCjr Keyboard Repair
« Reply #1 on: September 13, 2019, 02:11:29 am »
Wow, the logic chip testing feature in the device selection dialog of the MiniPRO, either forgot or overlooked it. Thanks for showing and pointing out that failure mode of the capacitor.
That keyboard needs some cleaning as well :D
« Last Edit: September 13, 2019, 02:49:11 am by SparkyFX »
Support your local planet.
Offline poot36
« Reply #2 on: September 13, 2019, 03:31:34 am »
Around the 8:22 mark on your video what is the bubbly liquid that drops on to the ESD mat?
The following users thanked this post: Fungus
Offline NivagSwerdna
« Reply #3 on: September 13, 2019, 04:23:23 pm »
It appeared that the C was OK when tested with the DE-5000 LCR meter.... this is a bit worrying since I tend to use that device when repairing things... tell me more...
Online Kleinstein
« Reply #4 on: September 13, 2019, 05:32:46 pm »
The cap tester may not check for leakage.  With an electrolytic cap this leakage could be current for reformation of the oxide layer. So there is a slight chance that just leaving the circuit powered for some time could have fixed the problem.
Offline SparkyFX
« Reply #5 on: September 13, 2019, 09:47:29 pm »
Got a quite similar one, from what i read in the manual, it tests with 0.6Veff and runs AC tests (C,ESR, D, theta) in serial mode.
Measuring Rp in parallel could do the job if i got it right, but probably not at 6V and without knowledge of typical comparison values. So questionable if it can show "leaky" caps without other symptoms?
The CMOS input probably does not feed/draw enough current for this self healing to happen. Would need to ground the input artificially for the time.
Offline orion242
« Reply #6 on: September 14, 2019, 02:40:17 am »
Lol, spit.  Dave must be foaming at the mouth, rabies from his outback adventures!
Offline wilfred
« Reply #7 on: September 14, 2019, 02:43:07 am »
Australia is free of Rabies. Dave must have been foaming at the mouth for other reasons.
Offline orion242
« Reply #8 on: September 14, 2019, 02:46:59 am »
Australian Bat Lyssavirus!!
He's always talking about bat $hit, must be near them.
Offline Per Hansson
« Reply #9 on: September 14, 2019, 06:46:22 am »
Would be fun to see the Vloss indicated by your cheap component tester (EEVblog #1020) of that leaky capacitor.
