Author Topic: EEVblog #1197 - DIY PCB Etching With Water  (Read 12976 times)
Offline EEVblogTopic starter
« on: March 31, 2019, 10:02:16 am »
Experimenting with etching your own PCB's by concentrating existing ferric chloride levels in tap water. How well does it work?
Offline rs20
Re: EEVblog #1197 - DIY PCB Etching With Water
« Reply #1 on: March 31, 2019, 10:46:07 am »
Unbelievably good results! Do you think there might be applications in producing more eco-friendly PCBs?
« Reply #2 on: March 31, 2019, 10:50:09 am »
Someone on Youtube mentioned a new RoHS standard that includes this?
Offline Hootch
« Reply #3 on: March 31, 2019, 11:07:40 am »
Amazing idea!
Although I was a little bit sceptic, I tried it, and it actually works quite good. I even was able to get a better result with four magntes arranged in a x-shape. Put the glas on the cross of magnets and do as Dave did it. It also helps to say and repeat the following little prayer until the copper is completely removed:
Almighty God
Please help to
Remove the copper
In order to make a
Lowcost PCB.
For thou hast the power
Of increasing the concentration
Of Iron and chlorine in this
Liquid for ever and ever. Amen.
Dave, I know your opinion about religion, and I also didn't believe it first. But this works really better than your procedure.
Greetings!
Offline ludzinc
    • My Misadventures In Engineering
« Reply #4 on: March 31, 2019, 11:22:44 am »
I’ll have to try this tomorrow!
The following users thanked this post: BrianHG
Offline Cnoob
« Reply #5 on: March 31, 2019, 11:34:23 am »
Here is another tit- bit of information on Iron dissolved in water, the forming of "bog iron",https://en.wikipedia.org/wiki/Bog_iron.
Offline JackJones
« Reply #6 on: March 31, 2019, 11:36:49 am »
I tried it with photoresist, works a treat!
Although it did take me closer to 1.5 hours to etch. There must be pretty large differences between local water supplies.
The following users thanked this post: EEVblog, thm_w, Andrew McNamara
Offline Whales
    • Halestrom
« Reply #7 on: March 31, 2019, 11:52:18 am »
Negative result here.  My tracks ended up solder plated instead of etched.
I might try running the tap into the sink for a while first, get rid of local plumbing contaminants.
Offline wilfred
« Reply #8 on: March 31, 2019, 11:58:00 am »
What sort of magnet was it that you used. I'll have to try this. I once left an old magnet next to a copper water pipe in my laundry for years and it eventually leaked. I thought I was being clever because it was meant to attract the rust particles that caused problems in my film developing days. I've replaced all of the galvanised steel pipes now of course but I'm a bit concerned.
« Last Edit: March 31, 2019, 11:59:49 am by wilfred »
Offline ZeTeX
  • Country: il
  • When in doubt, add more flux.
« Reply #9 on: March 31, 2019, 12:25:21 pm »
I've tried it and it worked great! I had to leave it for a few hours actually, but hi, it is definitely worth it! save the mess of using ferric chloride, and save some money!
I recommend using the magnets you get from a hard drive, they are strong and work great.  ;)
« Reply #10 on: March 31, 2019, 12:39:47 pm »
Fluke meter hanger magnet. Couldn't find my huge block one after the move.
Offline nixfu
« Reply #11 on: March 31, 2019, 01:38:53 pm »
I got even better results with the magnets arranged in a pentagram, but this only works for PCB's to be used in "evil" applications such as nuclear weapons, and sex bots.  :-DD
« Last Edit: March 31, 2019, 01:41:20 pm by nixfu »
Offline Rolo
« Reply #12 on: March 31, 2019, 01:46:53 pm »
Here in my country the water is best in april so I will try it tomorrow.
The following users thanked this post: janoc, MT, BrianHG, bsudbrink
Offline tggzzz
« Reply #13 on: March 31, 2019, 01:48:12 pm »
Since this isn't "obvious to someone skilled in the art", you could have patented it.
But you can't because you disclosed it. The bright side is that now it has been disclosed, nobody else can patent it and stop you using your invention.
So go ahead and see if you can make all your boards like this :)
Offline golden_labels
« Reply #14 on: March 31, 2019, 01:50:33 pm »
I had no glass big enough, so I’ve used my grandma’s copper bowl. The PCB was untouched until I placed a strong magnet under the bowl to ensure automatic stirring of the solution. I think this is the key: it etched the PCB in just 12 minutes. Now I need advise… where can I quickly buy a new, good quality copper bowl?
 :popcorn:
People imagine AI as T1000. What we got so far is glorified T9.
Offline SilverSolder
« Reply #15 on: March 31, 2019, 02:01:16 pm »
Offline Bud
« Reply #16 on: March 31, 2019, 02:45:00 pm »
It is just begging to run a competition how small track/spacing width you can get. :-+
Offline jim_griff
  • Personal Text goes here.
    • Principal Audio
« Reply #17 on: March 31, 2019, 03:17:39 pm »
It may not be the appropriate time to post this video (depending on where you live on the planet) but here's my experiment and video response:
https://youtu.be/dzL3hDtHzTI
Offline German_EE
« Reply #18 on: March 31, 2019, 04:38:08 pm »
I was with you up to the point where it started working, then I thought of the copper water pipes in our bathroom, then I looked at the date.
Nice one, well done  :-DD
P.S. Water containing Ferric Chloride isn't magnetic but blood which contains iron IS. Look around and you'll find some interesting experiments.
Warren Buffett
Offline free_electron
    • SiliconValleyGarage
« Reply #19 on: March 31, 2019, 04:54:53 pm »
I tried it with my home-delivered bottled water. After 8 hours : nothing. so that proves my water is very clean and does not contain Fe3Cl ! Good.
Then I tried it with tap water here in silicon valley. Etched pretty fast ( a good  25 minutes faster than Daves results) . That probably is because we had so many chemicals form all the old waferfabs leaking into the groundwater.
I found out that i could speed up the process even more if i added a bit of Ammoniumpersulfate or sodiumpersulfate to the water. Side-effect is that it does turn the water a beautiful shade of blue.
Offline GigaJoe
« Reply #20 on: March 31, 2019, 05:13:13 pm »
3% Hydrogen Peroxide + citric acid (white crystals) + kitchen salt
use a plastic bag, warm in hot water ...
UPD, riaiaiaight ... I'm in 31 Match time belt, still :)
« Last Edit: March 31, 2019, 05:18:13 pm by GigaJoe »
Offline firewalker
  • Country: gr
« Reply #21 on: March 31, 2019, 05:17:42 pm »
I used the lab centrifuge and the result was better than using a strong magnet. I used tap water.
Alexander.
Offline GigaJoe
« Reply #22 on: March 31, 2019, 05:22:07 pm »
i have a few centrifuges that i use to use to enrich uranium, so I wonder if I will using it, with sequence of helium cooled magnet, wonder if possible to reach close to 100% ferrite concentration?
The following users thanked this post: jancumps
Offline SparkyFX
« Reply #23 on: March 31, 2019, 05:24:25 pm »
Damn internet, now you´re not even safe half a day before. :-)
Support your local planet.
Offline toby_muc
« Reply #24 on: March 31, 2019, 05:29:23 pm »
Damn, doesn't work in southern Germany, bloody mountain-spring-water ...
