Author Topic: EEVblog #1185 - Dumpster Tek TDS540D Scope  (Read 13233 times)
Offline EEVblogTopic starter
« on: February 27, 2019, 10:29:48 pm »
Will this dumpster 500MHz 4 channel Tektronix TDS540D scope work?
Teardown included of course.
« Last Edit: February 28, 2019, 02:23:40 am by EEVblog »
Offline Deodand2014
Re: EEVblog #1184 - Dumpster Tek TDS540D Scope
« Reply #1 on: February 27, 2019, 10:40:04 pm »
Is this episode 1185? The last episode was 1184 as well.
Offline FERCSA
  • Country: hu
    • www.fercsa.com
« Reply #2 on: February 27, 2019, 11:35:17 pm »
One vote for a repair video!
Good news is the CRT has some kind of sign of life, so it should be something with the controller board.
Don't ask. I'm the same guy who gave you ultra fast internet in the '00s..
#FERCSA
Offline SilverSolder
« Reply #3 on: February 27, 2019, 11:37:35 pm »
Looks challenging to repair without being able to power it up - maybe an external video signal generator would come in handy?
I like the LCD upgrade idea.  Especially if it can be coaxed into making a colour picture!
Offline Brumby
Re: EEVblog #1185 - Dumpster Tek TDS540D Scope
« Reply #4 on: February 28, 2019, 12:29:32 am »
Indeed
EDIT: It's been fixed  :-+
« Last Edit: February 28, 2019, 04:22:42 am by Brumby »
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
« Reply #5 on: February 28, 2019, 12:54:42 am »
Hey Dave
Please  do a  repair  video  on that oscilloscope  with a   1080P  or VGA  display
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Offline snoopy
    • Analog Precision
« Reply #6 on: February 28, 2019, 12:56:07 am »
You still can't buy a cheap decent 4 channel 500Mhz scope which is why these are still sort after apart from the earlier models with cap problems. And with the Tek active probes this makes it an even more valuable combination ;)
Dave when you get a chance try measuring the waveform update rate. You'll be shocked at the performance of these things considering their age. I have a TDS784 and with Instavu or DPO switched on I managed to clock about 390,000 waveforms per second with a 1 MHz signal on the input. They really were way ahead of their times  :clap:
cheers
david
Offline MT
  • Country: aq
« Reply #7 on: February 28, 2019, 01:06:17 am »
Repair CRT then do the upgrade to LCD
« Reply #8 on: February 28, 2019, 02:24:00 am »
Err, yeah,  :-[
« Reply #9 on: February 28, 2019, 02:25:01 am »
1080p is not possible, it's only 640x480 VGA output
« Reply #10 on: February 28, 2019, 02:26:55 am »
Yep, would be really annoying.
First step might be remove and electrically check caps and other things and hope to get lucky before having to try and power it up and feed in a signal.
I'd love to know if it can be colour. The other models are, and the firmware and hardware obviously supports it in some way. Anyone know anything?
Offline tsman
« Reply #11 on: February 28, 2019, 02:32:05 am »
Need to change 1 part, modify the strap resistors and add more VRAM but it looks like you can upgrade your TDS520D to be a colour TDS754D. It would make a very nice colour scope with a new VGA LCD fitted.
« Last Edit: February 28, 2019, 02:35:01 am by tsman »
Offline snoopy
    • Analog Precision
« Reply #12 on: February 28, 2019, 03:13:08 am »
I used to repair TV's a long time ago before they went to LCD. Typically a fault like this could be traced to the yoke coupling capacitor on the horizontal yoke windings. From memory usually a metalized polyester type capacitor or poly carbonate of around 3.3uF is what they used on old 12inch B&W TV's. Does anyone have a schematic of the monitor section ? Sometimes even a dry joint was the culprit around the line output transformer etc ;)
cheers
« Reply #13 on: February 28, 2019, 03:22:58 am »
Cool!
Offline tsman
« Reply #14 on: February 28, 2019, 03:59:53 am »
More upgrades possible :-/O
You can enable all the options via GPIB.
It may be possible to upgrade it to 1GHz as well by removing some caps and altering the strapping resistors. Guide is for an A model though not the D model. It'll be a hassle to recalibrate it though.
Online IanB
« Reply #15 on: February 28, 2019, 04:07:33 am »
"It's always a dry joint around the line output transformer"
...says me from personal experience  ;D
Online DaJMasta
    • medpants.com
« Reply #16 on: February 28, 2019, 04:10:07 am »
Those memory controller QFPs attached to the ADCs are real beauties!  :-+
Offline Moshly
  • What's wrong with this thing
« Reply #17 on: February 28, 2019, 07:34:27 am »
The following users thanked this post: MT
Offline nueron
« Reply #18 on: February 28, 2019, 09:01:38 am »
The TDS monochrome CRT schematics are at the very end (pg 366+) of the TDS520B Mod CM Service Manual. Do a search for "TDS520B Mod CM" and you should be able to download the pdf.
You should also be able to test the CRT outside of the frame via the ribbon cable only. However, I would make sure that everything is properly grounded (e.g. metal strap around the front of the CRT is grounded to the chassis!) as you don't want high voltages flapping around in the breeze...
Offline AndyC_772
« Reply #19 on: February 28, 2019, 11:12:35 am »
It's not that long ago I was making a living with a TDS754D as my main bench scope. They might be old, but performance was exceptional for the time. A solid workhorse of an instrument if ever there was one.
I eventually switched to an Agilent MSO-X3054A for two reasons:
- The Tek was an old scope, and I was always worried that it might finally expire at an awkward moment. Not such an issue if you're using it for a hobby, but when your livelihood depends on it, reliability is key
- One hot summer the combination of a south facing lab and a scope chucking out ~400W became too much to bear. The scope itself doesn't "run hot" as such, thanks to that massive fan and heat sinks, but it does warm a small lab alarmingly effectively.
The new scope has given me back a fair amount of desk space, and the lab is much quieter and more comfortable - but in performance terms there's not a huge amount to choose between them. Serial decoding and much faster horizontal pan/zoom are about the only differences I notice in day to day operation.
I still miss equivalent time sampling. Not sure if anyone's doing that any more :(
Also: I had a TDS540 for a short while too, and its CRT driver board went bad in much the same way. I tried replacing every cap on the board with no luck, and eventually replaced the whole board with a donor. I think the flyback transformer had failed, and they're unobtainium.
LCD kits used to be too expensive to really be an economical repair given the value of the scope. Has that changed now?
Offline snoopy
    • Analog Precision
« Reply #20 on: February 28, 2019, 11:42:56 am »
Offline CJay
« Reply #21 on: February 28, 2019, 03:15:18 pm »
As always, I need a dumpster like that...
The Schaffner gadget, I think I have plugs for it, they look like the ones used on Motion control hardware, I've got one sat on my desk, if there's an intention to get it running I could post a secondhand one over?
Offline bsfeechannel
« Reply #22 on: February 28, 2019, 03:21:38 pm »
Dave is so lucky, it is contagious. I was walking a few blocks from home the other day when I noticed a small cardboard box tossed to the curb. It was full of NOS tubes. It was not a Tek scope, but I had never found anything before watching Dave's dumpster dive videos. Unbelievable.
Offline David Hess
  • DavidH
« Reply #23 on: February 28, 2019, 05:49:56 pm »
There is a lot to be said for 100 GSamples/second or higher to remove all doubt about what the DSO is showing but if I am reading the specifications right, the TDS500D series is real time only and the TDS700D series is needed to support equivalent time sampling.
Some high end DSOs still support equivalent time sampling but it requires extra hardware outside of the vertical signal chain and digitizer which is not amendable to integration unlike faster digitizers so ETS became relatively more expensive as Moore's Law marched on.  Implementing ETS after the ADC is a contradiction.
Update:
The tear-down video seems to show that ETS is supported but the documentation says otherwise.  I wonder what the story is with that.
« Last Edit: February 28, 2019, 07:31:21 pm by David Hess »
Offline David Hess
  • DavidH
« Reply #24 on: February 28, 2019, 07:40:43 pm »
Dave, the Dallas nVSRAMs routinely last about 20 years so those are close to the end of their life.  Before getting too involved in repairing the display, know that the calibration data is stored in the nVSRAMs and the calibration procedures are very involved requiring special equipment and software.
Replacing the nVSRAMs is not too difficult however I have not successfully been able to read a nVSRAM which is that old.  If you try this, I suggest testing your read and write procedures on an expendable nVSRAM of the same type before removing the ones inside the instrument.
