It's not that long ago I was making a living with a TDS754D as my main bench scope. They might be old, but performance was exceptional for the time. A solid workhorse of an instrument if ever there was one.
I eventually switched to an Agilent MSO-X3054A for two reasons:
- The Tek was an old scope, and I was always worried that it might finally expire at an awkward moment. Not such an issue if you're using it for a hobby, but when your livelihood depends on it, reliability is key
- One hot summer the combination of a south facing lab and a scope chucking out ~400W became too much to bear. The scope itself doesn't "run hot" as such, thanks to that massive fan and heat sinks, but it does warm a small lab alarmingly effectively.
The new scope has given me back a fair amount of desk space, and the lab is much quieter and more comfortable - but in performance terms there's not a huge amount to choose between them. Serial decoding and much faster horizontal pan/zoom are about the only differences I notice in day to day operation.
I still miss equivalent time sampling. Not sure if anyone's doing that any more
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
Also: I had a TDS540 for a short while too, and its CRT driver board went bad in much the same way. I tried replacing every cap on the board with no luck, and eventually replaced the whole board with a donor. I think the flyback transformer had failed, and they're unobtainium.
LCD kits used to be too expensive to really be an economical repair given the value of the scope. Has that changed now?
