Author Topic: EEVblog #1178 - Build a $10 DIY EMC Probe  (Read 27969 times)
Offline EEVblogTopic starter
« on: February 07, 2019, 08:55:42 pm »
How to make your own magnetic H-field EMC probe for $10 that performs identically to a $300 commercial probe!
The following users thanked this post: Blue, nikifena, mtdoc, WN1X, s8548a, Mortymore
Offline desertgreg
Re: EEVblog #1178 - Build a $10 DIY EMC Probe
« Reply #1 on: February 07, 2019, 10:38:56 pm »
Anyone have a link to the pre-amplifier or a similar one?
The following users thanked this post: ducus
Offline glarsson
« Reply #2 on: February 07, 2019, 10:52:58 pm »
Search for "rf amplifier module" or similar on eBay.
Offline Smokey
  • Not An Expert
« Reply #3 on: February 07, 2019, 11:10:18 pm »
I sorta feel bad for Tekbox.  There is a reason magicians don't talk about how the magic happens :)
Offline Fire Doger
  • Stefanos
« Reply #4 on: February 07, 2019, 11:39:32 pm »
It's not something extremely secret, if you Google "H-field EMC probe" you can see the best practices for making one :-//
I was also thinking of making a set of 4 or 2 on a 50x50  PCB with nice connectors and stuff, 10x PCBs cost like 15$ (from known company), you get x10 set of probes and they don't look like a sex toy :-DD
Online Bud
« Reply #5 on: February 07, 2019, 11:44:09 pm »
The coax in the video is semi- rigid one. Rigid coax has solid outer copper shield.
Offline artag
« Reply #6 on: February 07, 2019, 11:50:09 pm »
I think the plastic coating is a method I was taught in high school (several years ago). That bubbly appearance where you stripped it away is fairly characteristic.
You have a drum with plastic particles in it, compressed air blown in to make it fluidised. Heat the object and stick it in the drum, the plastic particles melt onto the surface and  make a covering.
Usually done on steel - it holds the heat better and melts the particles for longer  - but pcb material might work with a few applications. Perhaps it's warmed up in an oven to smooth the outer surface.
Here's a company selling the outfit :
https://www.plasticcoatings.co.uk/plastic-coatings-processes/thermoplastic-dip-coating.php
Offline cowasaki
« Reply #7 on: February 07, 2019, 11:50:48 pm »
I've seen these probes used for locating dead ICs etc as well.  Is it possible to get any kind of useful reading with a scope?  Not everyone has a spectrum analyser on their bench :-)
Offline wilfred
« Reply #8 on: February 07, 2019, 11:51:29 pm »
I think this one is similar
https://www.ebay.com.au/itm/292353124631
Offline richnormand
« Reply #9 on: February 08, 2019, 12:25:10 am »
Nice video Dave.
Could you have used an isolated coax instead of bare metal, a tab of RTV silicone at the connection and done away with the plastic coating?
I relate to the shorting out the circuit you are testing but at the other end would it might be a good idea use a DC blocking connector to you spectrum analyser, just in case the probe touches something even though you are protected by the outer shield? I know my HP8561E  has a 0 DC MAX warning at the input connector or can you trust the coupling cap in the amp for that?
I found the technique most useful to find a dead coupling capacitor to an MMC before.
It was fairly high frequency but my homemade probe to the SA worked great
See post # 5 and 7:
https://www.eevblog.com/forum/repair/rohde-and-schwartz-cmu200-rxtx-module-issues/msg1030386/#msg1030386
The drop of signal was very noticeable and allowed me to zero-in on the trouble area, despite a lack of schematics.
Keep on the good work.
Cheers.
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
« Reply #10 on: February 08, 2019, 12:36:04 am »
Just search "Low noise amplifier"
« Reply #11 on: February 08, 2019, 12:38:33 am »
Nice video Dave.
Sure, but I didn't see those pre-terminated. I'm sure there are ones, so buy those if availabe.
I should have just slipped over some heatshink before soldering, but I had the can of stuff and thought that might be cool.
Sure you can trust the coupling cap in the amp, that's what it's for.
« Reply #12 on: February 08, 2019, 12:39:15 am »
Yep, that's identical.
I'm sure any of them would work though.
« Reply #13 on: February 08, 2019, 12:40:25 am »
Yes, I know. My Australian brain just shortens stuff.
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
« Reply #14 on: February 08, 2019, 12:42:44 am »
Very interesting   video  !
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Online Bud
« Reply #15 on: February 08, 2019, 01:44:32 am »
There is liquid plasti-dip, you just dip the thing in it and it makes nice even coating.
« Reply #16 on: February 08, 2019, 01:48:07 am »
Sounds better, the spray was pretty crap.
Offline drussell
  • Hardcore Geek
« Reply #17 on: February 08, 2019, 02:07:12 am »
I've only ever seen the "dip" version, I didn't even know they made a spray version of Plasti-dip until this video.
« Reply #18 on: February 08, 2019, 03:33:32 am »
Search ebay for plasti-dip and you can't find anything but the spray
Offline drussell
  • Hardcore Geek
« Reply #19 on: February 08, 2019, 04:10:18 am »
Really?
https://www.ebay.ca/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=plasti-dip+14.5+oz
Edit:  This kit looks interesting:
https://www.ebay.ca/itm/22-oz-PLASTI-DIP-Create-Your-Color-KIT-Tint-Plastic-Dip-Tintable-Plasti-Dip-NEW/331502778292
They've apparently come a long way since I first saw it in the old screw-top metal cans many years ago at my local electronics store.
« Last Edit: February 08, 2019, 04:20:23 am by drussell »
The following users thanked this post: Ellis_Beatty
Offline floobydust
« Reply #20 on: February 08, 2019, 04:26:28 am »
At work we bought the Rohde & Schwarz HZ-15 EMI probe set. Very nice and almost a $1,000 per probe around $5K for the set, guaranteed flat response.
Of course idiot engineer broke one  :palm: I took it apart to fix it and the wand is a pen! For $1,000 I thought custom molded etc, no it's a ball point pen body...
beehive Electronics is a low cost source, I think the main body is a PCB inside the dip. Bigger and not as elegant as the R&S.
The following users thanked this post: Fire Doger
Offline johnmx
  • Country: pt
« Reply #21 on: February 08, 2019, 01:36:45 pm »
Best regards,
johnmx
Offline rlagore
« Reply #22 on: February 08, 2019, 02:55:34 pm »
Thanks for the video Dave! For my first contribution to the forums, attached is a photo of the H-field probes we have in our lab. They vary widely in build quality and performance. You'll notice that we shield the notch in our probes with some copper tape over electrical or Kapton tape. Apparently this helps shield against E-fields. In our lab we build RF resonators and antennas (or "coils") for high field MRI research applications. The decoupled double probes on the left are for sniffing the resonant frequency of various structures.
The following users thanked this post: WattSekunde, Mortymore, shapirus
Offline Gary350z
« Reply #23 on: February 08, 2019, 02:58:52 pm »
Dave,
Nice video, but please explain how this probe picks up the magnetic field.
The following users thanked this post: hooverphonique
Offline drussell
  • Hardcore Geek
« Reply #24 on: February 08, 2019, 03:16:01 pm »
Dave,
Basic electromagnetic field theory.    https://en.wikipedia.org/wiki/Electromagnetic_radiation
An alternating magnetic field sets up an electric field (or vice versa) propagating outwards at a 90 degree angle to each other, somewhat like a chain, (except that the maxima of each occurs in phase, rather than interleaved like it would be if it were a chain.)  This is the basic fundamental principle underlying everything from radio waves to magnetic transformers, motors, etc.
The fundamentally linked nature of these fields is one of the absolute foundations of pretty much everything electronic that has come since the initial discovery nearly two centuries ago.  :)
« Last Edit: February 08, 2019, 03:42:51 pm by drussell »
The following users thanked this post: Mortymore, Technobabble_
