I wonder what kind of design rules you used for the inner layers.
Did the rows of the dip IC's cut big slots in those layers, or are the power layers sneaking between all pins?
This is an area where SMD is better than THT. Smaller SMD chips also are closer together, hence smaller loop area's and less ratiation. (And the near field radiation is also radiated, even though not very far, it certainly is not conducted).
I also would have loved to see a comparison with the board where you snapped off all the decoupling capacitors. What does that do with radiated noise?
Also not a single word about distributed capacitance between the power planes, but I think this only becomes really usefull in the GHz range.
15dB is a significant difference, but I do not find it shocking, it sort of gives me the idea that the original layout indeed is not too bad. The traces on that board are very coarse. It seems to be designed for home-etching. Any PCB factory can work with much finer design rules, and that would leave much more room for ground fills and via stitching.
I would love to see a teardown of those blue probes. Tear those down!
Is there any magnetics in there, or only an inductor? How much wiring?
Many loops of very thin strands?
Is the coil shielded? How about inter winding capacitance?
I know the're bloody expensive, but a detailed teardown & analysis is much more interesting than a blab about a dumpster dive.
I also would not be surprises if a piece of thin enameled copper wire wound on a corc would give comparable results. Coils of 230V relays are an easy source of thin wire if it's not glued together. A quality comparison between such a homebrew and the blue probes would also be very intersting. The blues are simply out of reach for almost all hobbyists.
Also, you've got CNC machines (mill, 3d printer) and a robotic arm.
You can attach the near field probes to one of those and then let a PC generate a "height map" or the radiated field. Especially if the resolution is high enough to see individual traces this can be a very usefull tool during pre-compliance testing of the first board revisions.
You can get nearer to the traces (higher resolution) on the bottom of the board.
If you want to do a follow up on this, I would also like to hear your opinion about dividing the budget between GND and Vcc planes on a 2-layer board.
I think it is best to:
1). Put decoupling caps as close to the IC's as feasible.
2). Connect the decoupling capacitors (not the IC's) to the power planes.
This way the Capactitors filter more of the noise generated by the IC's.
It keeps the GND plane cleaner.
3). Use Either GND (more traditional) or Vcc (uncommom) with as big an area as feasible.
4). Use lots of via stitching, every trace should have a small loop area with the GND plane.
5). The other Power net: Use some decent grit, but not too much area.
