Author Topic: EEVblog 1560 - TIP: Use Your Arb Gen as a High Resolution DC Voltage Source!  (Read 3862 times)
Online EEVblogTopic starter
Tech Tip: How to use you Arbitrary Waveform Generator as a High Resolution DC Voltage Source!
Siglent teardown:
The following users thanked this post: thm_w, gjvdheiden
Offline gjvdheiden
Nice video.
A while ago I digged through as much videos about the Siglent generator as I could find on you channel. The teardown convinced me the most.
I remembered from 1 of those videos that you prefer to change the load / output impedance setting by holding the "output" button above the BNC connector and the Siglent couldn't do that. Maybe it was a software version thing, because mine does exactly that and the video is from the first release back then.
Likely this is redundant info for you, but I saw you pushing through the menu doing that. That output button isn't really easy accessible with a T connector / splitter in the way.
Offline Fran_PSR
  • Infinity becomes long, especially towards the end.
Good morning, as always a splendid informative and above all interesting video, thank you very much David. Taking advantage of the topic, I have a problem with a similar generator model but with 80MHz with the possibility of loading waveforms from USB or from PC. I have a need that I can't solve and in the following: I can't find any file with a signal pattern of video color bars in CVBS format similar to those offered by the old TV signal pattern generating equipment to perform calibrations. I have searched the internet and I also consulted the manufacturer, unfortunately I did not get an affirmative answer. Do you know if there is a similar file?
Thank you
