It would be interesting to see if inputs controlled by the big custom ASIC work. In other words, playing video from USB Mass Storage, Wireless Display and connecting to the internet. If those (and the tuner) all work, it should still be worth a couple hundred bucks, like for a business which just keeps some videos going in an infinite loop and really wants to do so on a huge panel.
It would also be interesting to see how it behaves if you use a native 4K input and maybe if you disable some of the image "enhancement" features. Maybe it's just the scaler and maybe it gets bypassed when not needed?
I assume the original remote for it is an expensive piece of crap, because the one they included with the 2015 models is an expensive piece of crap that seems only slightly more usable than the 2014 model. Fortunately, a generic LG IR remote probably works fine - if you can't get the Android remote control app to work without setting it up with a real remote, that is.
I might as well mention an occasional glitch that my 2015 LG 4K unit has: The image will occasionally end up with a nasty grey overlay (think analog TV static, but with no motion) until the TV is rebooted. IIRC, it affects both the input and the TV's menus/overlays, so it's probably unrelated.
