Author Topic: EEVblog #1144 - Padauk Programmer Reverse Engineering  (Read 435515 times)
0 Members and 13 Guests are viewing this topic.
Offline bovineck
Re: EEVblog #1144 - Padauk Programmer Reverse Engineering
« Reply #1125 on: July 27, 2020, 08:02:14 am »
Have you checked voltages with "easypdkprogtest.exe"=?
easypdkprogtest
vdd: 3.62   vpp: 3.62    (vref= 3.27)
It looks like the 5V rail is not 5V but more like 1.9V. That can't be good - I have struggled the most with the USB connector so I'll keep working on that - but of course there might be a compromised component somewhere. My OpAmp measurements are way different to this:
Reference voltages when running easypdkprogtest:
                   |   O   |
(DAC-VPP) 1.18V -> |5  P  4| <- -2.7V
          1.18V -> |6  A  3| <-  2.49V (DAC-VDD)
(VPP)      5.0V <- |7  M  2| <-  2.49V
          14.9V -> |8  P  1| ->  5.0V  (VDD)
More like this:
                   |   O   |
(DAC-VPP)   -2V -> |5  P  4| <-  -6V
         -2.42V -> |6  A  3| <-  -0.78V (DAC-VDD)
(VPP)     0.32V <- |7  M  2| <-  -1.44V
          1.69V -> |8  P  1| ->  0.34V  (VDD)
I think MKIII is the way to go with lessons learned along the way... :-\
Take care,
OneCircuit
You're unique, like everyone else
Offline daveatol
« Reply #1126 on: July 27, 2020, 08:39:15 am »
                   |   O   |
What's up with your 15V supply? It should be going to pin 8 of the opamp, and yours is apparently 1.69V. Is your dc-dc converter disabled, or faulty?
Offline bovineck
« Reply #1127 on: July 27, 2020, 11:26:12 am »
It's a mess for sure - I'm going to start again and hopefully have better success with MKIII.  :-//
Take care,
OneCircuit
Offline NickE
  • Country: hu
« Reply #1128 on: July 28, 2020, 12:50:04 pm »
In easypdkprog the --securefill option makes only sense at OTP MCUs. Am I right?
Offline serisman
« Reply #1129 on: July 28, 2020, 05:31:02 pm »
Also the break-out boards, that can be plugged into the programmer, arrived.
Speaking of break-out / adapter boards... I designed some new ones a few days ago:
Gerber files are also available if interested, and I can post all the design files somewhere at some point as well.
« Last Edit: July 28, 2020, 05:40:11 pm by serisman »
Offline ali_asadzadeh
« Reply #1130 on: July 30, 2020, 09:55:42 am »
Can we Port avr v-usb Library to Padauk?
https://www.obdev.at/products/vusb/index.html
It's a bit-bang USB library for AVR's ^-^ >:D
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline kaweksl
« Reply #1131 on: July 30, 2020, 12:56:43 pm »
VUSB won't fit into most padauks as they are around 1K ROM and 80 B RAM.
Check CH552 it is low cost, has HW usb and requires only 2 caps to operate.
Offline serisman
« Reply #1132 on: July 30, 2020, 08:28:12 pm »
tim_ has a project from a few years ago (https://cpldcpu.wordpress.com/2014/03/19/%c2%b5-wire-usb-on-an-attiny-10/) (https://github.com/cpldcpu/u-wire) where he got a subset of the V-USB stack working on an ATtiny10 using 988 bytes of flash and 32 bytes of SRAM.
So, it might actually be possible to get something working on these Padauk MCUs.  It would probably require 'overclocking' and/or using the undocumented 16MHz sysclock mode.  Other than the novelty factor, I'm not sure how useful it would actually be, though.
I agree, those are interesting (and inexpensive) MCUs, and have a USB/Serial bootloader so you don't even need a custom programmer.  Or, use the even smaller/cheaper CH551.  There are also the CH554/CH558/CH559 bigger brothers that even have USB host mode.  Being 8051 based, you can still use SDCC as well.
« Last Edit: July 30, 2020, 08:31:49 pm by serisman »
« Reply #1133 on: August 01, 2020, 07:08:28 am »
If it can be done on a padauk, it would cost a lot less, It can be replaced for USB to UART.
The following users thanked this post: icraftcrafts
Offline tim_
« Reply #1134 on: August 01, 2020, 09:20:35 am »
Indeed! That was a fun project. It was even reposted by one of the AVR founders (I think Vergard), so it surprised some people that this is possible, i guess :)
My guess is that an implementation from scratch in assembler could be much smaller. The Padauk instruction set should be quite efficient in handling the bitwrangling needed for USB.
If you are out for an interesting challenge, go for it! I would recommend to get a logic analyzer with USB protocol analysis capability first. Also, this: https://www.beyondlogic.org/usbnutshell/usb1.shtml
I have to second the comments regarding usefullness of software implementations, though. The USB protocoll is based on polling from the host (your PC), so any client has to be able to respond within microseconds all the time. The can be relaxed a bit using the tricks shown above, but regardless it will mean that any kind of firmware on your device has to be written around the USB protocol. I founds this a bit too limiting.
« Last Edit: August 01, 2020, 09:57:17 am by tim_ »
Offline Talrey
« Reply #1135 on: August 01, 2020, 05:05:58 pm »
Hello everyone. First post here! Apologies if this isn't the right place for this, but this thread seemed to be the most active place for discussing the Padauk OSH efforts.
I put in an order on LCSC for the parts list as given on the free-pdk hardware github, but now it's sitting in inquiry limbo. It looks like there's a couple items listed as "Backorder" with one even being listed as "Unavailable, please remove it." I'm new to LCSC, is there a way to replace these parts with possible equivalents in the order or will I have to start from a fresh order? I'm leery of making two orders given shipping costs.
Ironically, I got an email from OshPark that they'd upgraded my order to their super fast turnaround service for free, due to space on a panel... so now I'm going to get the blank boards way ahead of time!
Offline serisman
« Reply #1136 on: August 01, 2020, 05:13:18 pm »
I finally designed a PCB for my Padauk based 7-segment digital clock.
I also moved the project to its own repository and added some README files:
https://github.com/serisman/pdk-digital-clock
It will take about two weeks before the PCBs are delivered to me, but I feel pretty confident in the design.  I've been running it on a breadboard for a few weeks now.
Feel free to suggest new 'features' or make pull requests with enhancements or bug fixes.
My PCBs were delivered yesterday, and I promptly built one up (used a OTP PMS152-S16):
Front (before installing 7-segment display):
1038784-0
Back:
1038788-1
Installed on monitor (and working):
1038792-2
I am pretty happy with the results, and am calling this project done (at least for version 1).
I updated the github repo with a BOM for anyone interested.
Offline bovineck
« Reply #1137 on: August 01, 2020, 11:35:28 pm »
I had the same problem and had to split my order between LCSC and AliExpress. In the end the parts required for the programmer came from both suppliers at about the same time. The difficult part for me hasn’t been the acquisition of parts, but soldering those pesky SMD components (the USB connector is challenging). At this stage I’ve trashed two PCBs in the process, but the third one is looking good!
OneCircuit
www.onecircuit.blogspot.com
Offline Talrey
« Reply #1138 on: August 02, 2020, 02:02:13 am »
Thanks for the tip, bovineck. Unfortunately, I have to call my bank to approve the payment on AliEx for some reason, and the robot that answered my phone call curtly informed me that the office was closed and hung up on me!  :-DD   |O
Ah well. I'm being cheap on the shipping from LCSC so I've got plenty of time to sort it all out. Excited to dip into this Padauk stuff for real when it does! It's been on my radar since the original EEVBlog vid on it, but I'd always figured ATTiny85s were a better go-to until recently. I'm planning some things with lots and lots of blinkenlights and it felt wasteful to stuff the project full of Atmels when all those fancy features (and the reprogramming) weren't necessary for the design.
Offline bovineck
« Reply #1139 on: August 02, 2020, 02:49:21 am »
I use a prepaid debit card, load with cash at the P.O., then off to the interwebs for shopping. I too am looking forward to getting a working programmer. It’s been a journey, and my soldering skills have definitely improved! 🧐
Offline js_12345678_55AA
  • Country: ht
« Reply #1140 on: August 03, 2020, 03:08:25 pm »
I have a very nice hacking project with a commercial product using a PADAUK MCU coming soon.
Teaser:
000000011001001010000100100001000110010010000100100001001001010010000100
000000011001001010000100011001001000010010000100100001001001010010000100
000000011001001010000100100001001000010001100100100001001001010010000100
000000010101010110000100100001001000010010000100100001001001010010000100
8)
JS
« Last Edit: August 03, 2020, 08:10:25 pm by js_12345678_55AA »
Easy PDK programmer and more: https://free-pdk.github.io
Offline LovelyA72
  • Kashikoma from Massachusetts!
« Reply #1141 on: August 05, 2020, 06:21:06 am »
I am trying to implement tone function.
I am looking for a way to do microseconds delay (like delayMicroseconds() in Arduino). However, existing delay functions are either for milliseconds only or way too large and use all the SRAM.
Any help would be greatly appriciated!
Kashikoma!
Offline NickE
  • Country: hu
« Reply #1142 on: August 05, 2020, 08:55:03 am »
Just execute a few nop instruction. You can put them into a function.
« Reply #1143 on: August 05, 2020, 09:26:24 am »
It's a beauty >:D ^-^
  • Country: ht
« Reply #1144 on: August 05, 2020, 10:21:01 am »
Indeed  8) SOON more details !!!!!!! I got it running.  8)
I had a though time to find out some fact NOT mentioned in PFS154/PMS154 datasheet:
TM3 and PWGM2 share the same interrupt flag.
This means if you have TM3 and PWMG1 enabled, you will get interrupt requests from BOTH.
COMP and PWMG1 also share one interrupt flag.
Only the PFS154.INC header file reveals this:
INTEN IO_RW 0x04
$ 7 @4 : X, TM3 | PWMG2
$ 4 @3 : X, COMP | PWMG1
So my timing calculations been always half/double of what I expected.  |O |O |O |O |O |O |O
With the correct timing calculation I found the bit rate to be 1736 bits/sec  8)
JS
« Last Edit: August 05, 2020, 10:23:43 am by js_12345678_55AA »
Offline serisman
« Reply #1145 on: August 06, 2020, 01:27:14 am »
The delay.h file from the free-pdk-examples repo (https://github.com/free-pdk/free-pdk-examples/blob/master/include/delay.h) has a _delay_us(us) macro in addition to the _delay_ms(ms) macro and only uses up (at most) 7 bytes of SRAM (less if you comment out the delay loop methods that aren't needed).
If you already tried using that delay.h file and are still running out of SRAM, it could be one of the following issues:
  • Possibly there is a bug in the version of SDCC you are using?  Try the latest nightly.
  • If you are including delay.h in multiple .c source files, each one seems to get their own allocation of the method parameters for some reason.  The file should really be broken out to separate delay.h and delay.c files to fix this.  I'll update the examples repo at some point.
The following users thanked this post: LovelyA72
Offline serisman
« Reply #1146 on: August 06, 2020, 01:57:37 am »
So, here's my new rapid prototyping adapter and setup:
I am finding this setup much easier/quicker than anything else I have tried to date, including a dedicated 'dev board'.
« Last Edit: August 06, 2020, 02:04:13 am by serisman »
Offline LovelyA72
« Reply #1147 on: August 06, 2020, 10:20:19 pm »
Thank you for the advice! However, Even I stripped the delay.h to the smallest possible, I still got a SRAM full error.
Here is my source code: https://gist.github.com/Kashouryo/fcf1a8a6995ab7934b9abf936646f6ad
||ASlink-Warning-RAM value 134 too large (128B max)|
Thank you!
Kashikoma!
Offline serisman
« Reply #1148 on: August 06, 2020, 10:41:43 pm »
Ok, I see the problem now.
The _delay_us(us) macro is meant to be used with constants that are used to calculate the correct number of delay cycles at build time, not variables that would require the calculation at run-time.
So, use this:
_delay_us(100);
... instead of this:
uint8_t testVal = 100;
_delay_us(testVal);
If you really need something that is more variable at run-time you will have to come up with a different solution.
It looks like you are running at 1MHz, so each cycle is already 1uS.  So, technically you could skip all the 'calculation' and just call the delay loop directly.  But, there is overhead in calling the delay function as well as the delay loop (7 cycles overhead, 3 cycles per loop) that would still have to be taken into account.
For short delays, you don't really need the abstraction that the delay function provides, you could just directly do something like the following (inline assembly), but you still have to take into account the overhead (3 cycles overhead (2+1), 3 cycles per loop).
  uint8_t testVal = 32;         // 2 cycles - value = ((100uS -3) /3)
__asm
00001$:                             // 3 cycles per loop
  dzsn   _testVal                  // 1 cycle + 1 cycle for final skip
    goto 00001$                   // 2 cycles
__endasm;
You might be able to put some/most of this in a macro and/or possibly SDCC would already generate optimal loop code by just using a while (--testVal); loop or something similar.
Do you have a more complete example of what you are trying to accomplish?
« Last Edit: August 06, 2020, 10:46:21 pm by serisman »
Offline LovelyA72
« Reply #1149 on: August 07, 2020, 01:45:23 am »
I am trying to implement an Arduino-like tone function that outputs a specific frequently on a pin.
Kashikoma!
