I can read successfully and it has been written. not sure how to compare it to input, since input is a IHX file, readout seems to do a HEX file or a BIN file.
no blank check yields a successful write and failed verify. Even running several times.
What is the hello world supposed to do? That is to say, how can i test that it is functioning? i assume a hello world over serial, but this does not happen.
Wirelength is about 10CM. Anyway to slow down programming, in case wire length is an issue? it could be 100X slower and that would be just fine with me.
