I think the programmer is a bit rudimentary with all these jumpers, or maybe I'm doing something wrong? I managed to program the PMS150C parts with SOT-23-6 package, but it was a bit complicated.
I got an SOT-23-6 to DIP 14 adapter from Padauk, see attached images top.jpg and bottom.jpg. The pinout is odd:
signal - | SOT-23-6 pin - | DIP 14 pin |
PA4 | 1 | 9 |
GND | 2 | 11 |
PA6 | 3 | 6 |
PA5 | 4 | 7 |
VDD | 5 | 4 |
PA3 | 6 | 8 |
When I tried to program it, it didn't work, because when I create a project for the PMS150C, the package in the PDK file is S08. In the
program writer user manual on page 21 it looks like you can configure for each pin individually the signal function, like PA6 or VDD. But this didn't work.
So I did the procedure defined in chapter 5 for creating a "connecting board". On page 16 in the user manual you can see the pinout of JP7. The user manual is not very clear, but looks like each pin of JP7 is connected to the ZIF socket on top, except for 4 pins of the socket: The 8 bottom pins are connected to the socket, then there are 4 unconnected pins on the socket, and then the top 28 pins of JP7 are connected again to the socket.
I defined my own "connecting board", as defined in chapter 5 with JP7. The way you do this is to connect the 8 lower pins to your specific pinout. I did this, connecting the signals PA3, PA4, PA5, PA6, VDD, and GND from the bottom 8 pins to my DIP 14 layout on the top side with jumper wires. You can see this in the image jp7.jpg. PA7 and PA0 doesn't need to be connected, which means a minimal programmer might need at most 6 pins, but maybe less. Then I added the pin definitions in the PRE file in the IDE, as explained on page 19 of the writer user manual:
.writer package 14, 4, 32, 8, 9, 7, 6, 32, 11, 0x0000, 0x0000, 0
I had some problems with the open/short tests, but using 0x0000 for mask1 and mask2 worked without problems, which disables all tests on all pins.
After looking again at the adapter layout, the pinout looks exactly like the pinout of the PFS154-S14 chip. Maybe this would have saved me some time with the jumper wires, because I would have needed to define just the right writer package instruction, and could then use one of the pre-defined jumpers for S14 packages. Anyone who did this for the SOT-23-6 parts?
Why I think the programmer is rudimentary: It looks like the with the jumpers JP1 to JP7, the fixed 8 programmer signals are routed to the ZIF socket pins and you have to manually short the pins on the jumpers. For some jumpers like JP2, you get this jumper block, which connects all pins in parallel and the routing is done by the PCB layout, but depending on the package, you have to set individual jumpers, like with JP5. If you have the right connector board, or if your pinout is one of the pre-defined pinouts to use the existing jumpers, it is no problem for production. Just plugin the right jumper, and you can program your chips. But would be much better if it could be configured all in software, without the need to manually change jumpers.
There are already a bunch of 4051 analog multiplexers on the programmer board, but I guess they are used only for the open/short test and maybe chip identification, not to route the programming signals. Probably this would be a problem anyway, if it needs higher power, like when routing VDD and GND. But shouldn't break the bank to add two individual transistors for each pin for switching VDD and GND if necessary, at least up to SOP16. But there are some low resistance multiplexers ICs available as well, which would reduce this to like 4 ICs instead of 32 transistors. Just as an idea, if someone is planning to build an easy to use, universal Padauk chip programmer.
