Author Topic: EEVblog #1144 - Padauk Programmer Reverse Engineering  (Read 454466 times)
Offline tim_
Re: EEVblog #1144 - Padauk Programmer Reverse Engineering
« Reply #400 on: January 10, 2019, 12:47:40 pm »
I also managed to read and write the PMS154C now. It uses the same protocol as the PMS150 (6 wire). Adresslength is 12, instruction length 14.
The deviceID is 0xE06, which is different from the 0xA16 of the PMS150C. This seems to confirm that this value is indeed a device ID.
Curiously a lot of memory cells were already written on the fresh device. See dump below. I only wrote to 0x20-0x27. So even at 0x00 there was a prior value programmed. Ideas anyone?
Initializing...
DeviceID: E06   Vpp Standby: 5.4
DeviceID is match to:PMS154C
Dumping memory...
Vpp read mode: 7.7
0000: 37E8 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0010: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0020: 1A5A 15A5 3FFF 3FFF 1A5A 15A5 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0030: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0040: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0050: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0060: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0070: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0080: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0090: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
00A0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
00B0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
00C0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
00D0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
00E0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
00F0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0100: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0110: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0120: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0130: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0140: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0150: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0160: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0170: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0180: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0190: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
01A0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
01B0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
01C0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
01D0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
01E0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
01F0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0200: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0210: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0220: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0230: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0240: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0250: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0260: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0270: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0280: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0290: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
02A0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
02B0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
02C0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
02D0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
02E0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
02F0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0300: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0310: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0320: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0330: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0340: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0350: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0360: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0370: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0380: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0390: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
03A0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
03B0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
03C0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
03D0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
03E0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
03F0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0400: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0410: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0420: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0430: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0440: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0450: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0460: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0470: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0480: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0490: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
04A0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
04B0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
04C0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
04D0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
04E0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
04F0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0500: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0510: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0520: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0530: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0540: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0550: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0560: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0570: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0580: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0590: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
05A0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
05B0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
05C0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
05D0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
05E0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
05F0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0600: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0610: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0620: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0630: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0640: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0650: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0660: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0670: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0680: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0690: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
06A0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
06B0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
06C0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
06D0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
06E0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
06F0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0700: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0710: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0720: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0730: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0740: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0750: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0760: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0770: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0780: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0790: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
07A0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
07B0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
07C0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
07D0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
07E0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 2F1C 018B 0183 0191 1950 2FC3 0190 37E8
07F0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 026A 3FFF 3FFF 32FF 3FFF 3FFF 3FFF 3FFF 3FFF 1F5D
Writing to memory...
Vpp initial: 7.6        PWM: 10
Vpp write mode: 11.2    PWM: 43
Vpp after writing: 11.1
Vpp off: 5.5
Offline js_12345678_55AA
  • Country: ht
« Reply #401 on: January 10, 2019, 01:54:31 pm »
So this looks indeed like part of the OTP_ID. You can find the defines for OTP_ID in the IC specific files in "INC_PDK" folder of the IDE:
              OTP_ID     DATA from IC after command phase:
PMC150:    0B80
PMS150:    0B80
PMS150B:  1E01
PMS150C:  2A16     -> A16 (OK)
PMS154:    2A06
PMS154B:  2C06
PMS154C:  2C06     -> E06 (maybe include file is wrong or the read was not correct)
PFS154:     2AA1     -> AA1 (OK)
JS
Easy PDK programmer and more: https://free-pdk.github.io
  • Country: ht
« Reply #402 on: January 10, 2019, 02:03:46 pm »
This looks like the factory testing routine. Might only be present in PMS devices (tested) compared to PMC devices (non tested). PADAUK says PMS devices = "higher yield" in production ... of course if they already check for bad ICs ;), PMC = "better value" (price cheaper since no factory test and you might get several bad ICs)
First instruction is a GOTO to the end of program area where a simple program is stored. I analyzed this program already: https://github.com/free-pdk/fppa-pdk-documentation/blob/master/SpecialCodeFoundInPMS154B.txt
Basically it is an endless loop mirroring the input of PA.5 inverted on PA4,PA.3 and PA.2 ==> WRITER could detect presence of good IC by setting PA.5 High/Low and checking if PA.4,PA.3,PA.2 output inverted signal (we saw this as continuous small spikes from time to time when WRITER is idle)
Later when you program a user program a NOP is placed at first instruction (NOP = all bits 0, like this you can overwrite the old value). The start of the real user program will be at next instruction (I saw this when I dumped a programed 154C).
The last 8 program words are documented partially by PADAUK and some more infos I wrote down here: https://github.com/free-pdk/fppa-pdk-documentation/blob/master/Reserved_Area_Last_8_Words_Of_Codemem.txt
JS
« Last Edit: January 10, 2019, 02:55:27 pm by js_12345678_55AA »
Offline lucas.hartmann
« Reply #403 on: January 10, 2019, 02:22:15 pm »
JS
Nop being all zeros seems like a nice way to give an OTP part a couple extra lives. Embedding relocation in the programmer code would be awesome.
Enviado de meu SM-N910C usando o Tapatalk
Offline tim_
« Reply #404 on: January 10, 2019, 03:45:58 pm »
Ok, PFC154 works now as well: Read/Erase/Write
- A major confusion for me was that there was an additional clock cycle after each read operation. JS, I think you were confused by the same issue. This seems to be a bus reversal cycle to give the slave time to release the data pin.
- The leading zero is missing from the write sequence compared to PMC150.
- Data is 14 bit, Adress 13. Pagesize is 4.
- Used the erase sequence that JS described in an earlier port. The only difference is that I ramped VPP only after the initilization sequence.
There is still some issue that requires memory positions to be written more than once. You can see this phenomon in the dump.  0x20 was written once, 0x24 twice, 0x28 thrice and 0x2c four times. The pattern should be "0x1a5a 000n 0000 0000", where n is the number of writes. As you can see it takes between three and four writes to reliably write that position. It is quite possible that this can be removed by increasing VDD. Therefore the analog logs by Frank will be very valuable.
Interestingly this behavior gets worse when writing at a higher Vpp.
I have observed a similar phenomon in the PMC150C but not in the PMS154.
Initializing...
DeviceID: AA1   Vpp Standby: 5.3 V
DeviceID is match to: PFC154
Dumping memory...
Vpp read mode: 7.7 V
0000: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
0020: 1FFF 0FFF 0FFF 0FFF 1FFA 0182 05E0 0E80 1A5A 0003 0000 0000 1A5A 0004 0000 0000
07E0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 0282 025A 1FFE
07F0: 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF 3FFF
Erasing device...
Erase init response: 0AA1
Vpp initial: 7.6 V      PWM: 9
Vpp erase mode: 8.8 V   PWM: 15
Vpp after erase: 8.9 V  PWM: 15
Vpp initial: 7.8 V      PWM: 10
Vpp write mode: 8.5 V   PWM: 15
Vpp after writing: 8.5 V
Vpp off: 4.5 V
« Last Edit: January 10, 2019, 04:54:43 pm by tim_ »
Offline tim_
« Reply #405 on: January 10, 2019, 03:48:56 pm »
PMC150:    0B80
PMS150:    0B80
PMS150B:  1E01
PMS154:    2A06
PMS154B:  2C06
Exellent find! The pieces of the puzzle are coming together now. :)
The mismatch between C06 and E06 is strange. The deviating bit is in the middle of the sequence, so it does not seem too likely that it glitched or flipped.
Offline tim_
« Reply #406 on: January 10, 2019, 03:56:54 pm »
Ahaha, it's a bug in the chip. When I change words 3 and 4 to 0x3fff, all information is written in the first iteration. Probably there is some kind of internal issue when too many bits have to be written at once.
This explains why only two of four words are written at the same time in the official programmer.
Initializing...
Dumping memory...
0020: 1A5A 0001 3FFF 3FFF 1A5A 0002 3FFF 3FFF 1A5A 0003 3FFF 3FFF 1A5A 0004 3FFF 3FFF
Erasing device...
Vpp initial: 7.9 V      PWM: 10
Vpp erase mode: 8.7 V   PWM: 14
Vpp after erase: 8.7 V  PWM: 14
Vpp initial: 7.7 V      PWM: 10
Vpp write mode: 8.7 V   PWM: 17
Vpp after writing: 9.0 V
Vpp off: 4.6 V
Offline FrankBuss
    • Frank Buss
« Reply #407 on: January 10, 2019, 04:12:30 pm »
Actually the IDE has some support for it. See the file PADAUK_Tool/0.84/Help/CHS/MultPro.html . Unfortunately only available in Chinese, but the translation with Chrome is fairly good. It describes how to use .dc -1/0, .virtual and .checksum to burn an OTP IC virtually multiple times.
  • Country: ht
« Reply #408 on: January 10, 2019, 04:32:37 pm »
The captures from writing PFS154 did not show that. The flash was written in one big go without writing some pages multiple times.
JS
BTW: "DeviceID is match to: PFC154" ==> should be PF*S*154 ;-)
  • Country: ht
« Reply #409 on: January 10, 2019, 04:34:46 pm »
PMC150:    0B80
PMS150:    0B80
PMS150B:  1E01
PMS154:    2A06
PMS154B:  2C06
It's also strange that the "B" part has same OTP-ID as the "C" part. On several other processors "B" and "C" always have different OTP-IDs. SO maybe a bug in PDK include file...
JS
Offline tim_
« Reply #410 on: January 10, 2019, 04:53:09 pm »
JS
I thought this came up somewhere up in the thread? Well anyways. The issue with not being able to write many zeros at the same time could be a current limitation. The embedded MTP memory is probably written with hot carrier injection or another mechanism that requires a lot of current. The total current consumption during writing depends on the numbers of zeros written. I should maybe try to use a transistor to control VDD instrad of a GPIO...
Indeed, chnaged to PFS.
  • Country: ht
« Reply #411 on: January 10, 2019, 05:12:19 pm »
Interesting...
I was able to READ/ERASE with VDD coming from STM32 (3.3V, smallish current) and it worked nice. However writing only sometimes changed some bits.
When I added a transistor to switch VDD (basically wiring resistor to VDD supplied from external PSU and using mosfet to pull it to ground... I know but I had it handy) situation got worse.
I could not write anything anymore. However READ and ERASE still worked.
My experiments with PFS154:
* any VPP 5.7 - 12V and any VDD 2.4 - 7V READ/ERASE works
* WRITE worked only  (a little bit) when VDD was connected to MCU (3.3V), it also stopped working with 3.3V when using the transistor.
So maybe my current limiting resistor needs to be changed. Can't wait to try later today :-)
JS
Offline tim_
« Reply #412 on: January 10, 2019, 05:25:05 pm »
The datasheet actually states that VDD can draw up to 20mA during programming. Could already be a bit too much.
  • Country: ht
« Reply #413 on: January 10, 2019, 10:55:46 pm »
Interesting...
JS
THIS DID THE TRICK!!! Correct VDD voltage + current is essential.  :) :D ;D
When I set VDD to exact 5.8V for PFS154 i could write the complete IC in one go.
<5.7 V only some bits wrong during PAGE WRITE all 0
<5.4 V several bits wrong during PAGE WRITE all 0
<=5 V only some bits changed during PAGE WRITE all with 0
BTW: It is enough to setup VDD + VPP only once. There is no need to change it during a READ/ERASE/WRITE operation.
JS
Offline tim_
« Reply #414 on: January 10, 2019, 11:06:29 pm »
Great! Very nice finding. That means that very accurate VDD control is needed - or you need to write only a limited number of zeros at the same time.
  • Country: ht
« Reply #415 on: January 11, 2019, 12:06:26 am »
After some discussion with a friend and looking on oscilloscope we found that my VDD broke down frequently (e.g. once per bit during read).
So maybe not so sensitive at all, but a capacitor is required to stabilize VDD.
JS
Offline tim_
« Reply #416 on: January 11, 2019, 07:34:16 am »
Adding a stabilizing cap unfortunately did not solve the issue for my programmer. Neither did using a transistor to switch VDD. So it really seems to be related to supply voltage as well.
Offline piotr_go
    • My Projects
« Reply #417 on: January 11, 2019, 01:03:33 pm »
I put 1ms delay after sending address and it fixed my double write problem. (PFS154-08)
I'm using 12V VPP and 5V VCC.
« Last Edit: January 11, 2019, 01:18:42 pm by piotr_go »
Offline FrankBuss
    • Frank Buss
« Reply #418 on: January 12, 2019, 11:31:53 am »
I think it could be very helpful to take an analog log of the PFS154 writes sequence. Most likely it will also be possible to deduce the write direction from the analog voltages.
Frank, do you think you have a chance to do this? If you don't have any PFS154 I could send some to you.
Thanks, I got the ICs. Here is a dump of the PFS154. I added a lot of 0x00 and 0xff to see if the programmer does something special for long sequences. The test project with source code and PDK file is included. This is programming an already programmed chip with the same data, but in the display I could read an erase step, so I guess it is the same for an empty chip. But I can do another test with an empty chip, if necessary.
Signals:
CH1 = PA3
CH2 = PA5
CH3 = PA6
CH4 = VDD
Still a lot of crosstalk. My scope shows a better signal. But I think I can reduce this a bit with a better decoupling of the reference voltages and better shielding of the test cables.
Offline tim_
« Reply #419 on: January 12, 2019, 02:58:42 pm »
Signals:
CH1 = PA3
CH2 = PA5
CH3 = PA6
CH4 = VDD
Thanks a lot! Looking at the data right now. As I'd hoped for, it is possible to identify the data directon from voltages and also slew rates. It seems that most assumptions about the protocol are confirmed.
Offline spth
« Reply #420 on: January 12, 2019, 08:06:56 pm »
There was a  bit of progress on the software side. The compiler is now mostly working (i.e. except for a few corner cases it should just accept valid ISO C17 code and generate correct asm for it), and the generated asm looks okayish, though there is further potential for optimization.
I've written a "Hello, world!" for the PFS154 (https://github.com/free-pdk/sdcc-pdk-code-examples/tree/master/hello-pfs154). The asm generated by SDCC for it looks correct, but I didn't really check the binary code yet (and the assembler is still quite new).
Philipp
The following users thanked this post: js_12345678_55AA, socram
Offline tim_
« Reply #421 on: January 13, 2019, 03:09:50 am »
Philipp
Very nice! I compiled SDCC from your pdk branch and compiled this example. It seems that main code and the initiliaztion code are both relocated to zero? Is that still a bug or is an additional linker-file required?
Offline spth
« Reply #422 on: January 13, 2019, 09:53:19 am »
Kind of both: One could use a linker file (or the --code-loc option), but the default for --code-loc needs to be changed, so it just works for the common case. However, there also are a few other linker / compiler-linker interface issues that need to be fixed.
Philipp
Offline tim_
« Reply #423 on: January 13, 2019, 10:24:58 am »
Philipp
Is there any easy workaround? I am currently looking for a way to generate a binary to test programming with a real example, preferrably as intel hex. I made a small blinky example (attached). Apart from the relocation issues, it seems  to look fine. Otherwise I'll try to use the assembler directly.
I'd prefer not to use the official* Padauk IDE right now for several reasons:
- The tools to decode pdk files from "freepdk" do not compile. (who is maintaining this, btw. I added an issue)
- I would like omit the oscillator calibration code for now as this only adds to complexity to the programmer.
- Out of principle, to avoid IP contamination.
*edit
Blinky on PA.0
#include <stdbool.h>
#include <stdio.h>
volatile int counter;
__sfr __at(0x03) clkmd;
__sfr __at(0x04) inten;
__sfr __at(0x05) intrq;
__sfr __at(0x10) pa;
__sfr __at(0x11) pac;
__sfr __at(0x1c) tm2c;
__sfr __at(0x17) tm2s;
__sfr __at(0x09) tm2b;
unsigned char _sdcc_external_startup(void)
clkmd = 0x34; // Use IHRC / 2 = 8 Mhz for system clock
clkmd = 0x30; // Disable ILRC, watchdog
return 0; // perform normal initialization
void main(void)
pac = 0x01; // PA.0=output
for (;;) {
counter=30000;
while (--counter);
pa=0x00;
counter=30000;
while (--counter);
pa=0x01;
:200002000113002F800B002F002880171830002F800300120830000C01286A006B00820151
:020002000030CC
:020000000C30C2
:20000400342F830B302F830B7A007A00012F910B302F800B752F810B80128110800F810EE3
:1C002400002A1830002F900B80128110800F810E002A2830012F900B10307A003C
:00000001FF
« Last Edit: January 13, 2019, 06:53:15 pm by tim_ »
Offline tim_
« Reply #424 on: January 13, 2019, 03:57:21 pm »
A general issue with SDASPDK: It seems all adress calculation for the instruction memory are based on bytes, not words. Therefore branch targets are off by a factor of two. Or am I missing something?
