Dave: while you're at it, hedge your bets and grab the programmer for a few other brands too. If this one doesn't pan out ("oh the IDE is free, but compiler costs $2K and we only tell you if you ask
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
") then you'll have some other options.
You may also want to make a little finger-pressure adapter board for test programming the OTPs. Use a large, unconnected SMD resistor to make a 'wall' that you slide the components up against with your finger. Next to this place the ENIG pads the part is held against.
The SMD resistor should have its dimensions reasonably specced, make sure to make the pads tight too. Put three duplicates of this circuit on a board with a tiny variation in resistorwall<->pads spacings to allow for tolerances when you use it IRL.
It's also worth wiring an unused pin on the pads to an LED+R for a quick-n-dirty self-test of your code writes. Even if you don't end up using it.
Alternatively you might plan to do emulation + in-circuit programming from the start. YMMV.
