I have this screwdriver and I do use it quite a lot for repair work. It is nice to habve a standard size screwdriver on the bench and be able to swap bits without it turniong into a pile of odd screwdrivers, As well as the basic kit, I picked up a separate kit with normal handle from wiha because it was the cheapest way of getting all the extra 6mm hex fitting bits and something to store them in, it also means I can have the frequent use bit in the speede and another bit in the normal handle.
In terms of shape, build an tip quality really happy.
First problem Forget the price of the system, this is how wiha really make money!!!!! --> only 6mm hex bits fit NOT 1/4 inch, and the wiha bits are pricey, I had to order a separate T8 bit, (I think WERA might also be doing some 6mm bits now, but just flat, pozi, philips and a small range of torx, none of the other security bits etc). The Wiha range is really limited.
Next - slow turning, but fast enough - however slow gearing should mean plenty of torque so it can undo screws, but it is hopeless for that - I need to start almost every screw manually then engage the power, and if you try to be clever and simultaneously operate the ring switch, then it detects overcurrent, switches off, so you do not get austomatic transition from turning manually to turning by power, you have to relase the switch and re-enable - it annoys me every time!
So I've got one, i use it, I like Wiha drivers, but won't buy from these guys again, over priced driver, limited bits, and locked into expensive Wiha 6mm hex fittings - I pay good money for good product, but this leaves a bad taste. Buy something else.
