Author Topic: EEvblog SSL certificate has expired today  (Read 3804 times)
Offline NorthGuyTopic starter
« on: August 27, 2020, 01:29:05 pm »
EEvblog.com SSL certificate has expired. New one is needed.
Offline gnif
Re: EEvblog SSL certificate has expired today
« Reply #1 on: August 27, 2020, 01:32:08 pm »
Expires: Tuesday, 27 October 2020 at 10:37:10
Not sure what cert you're getting
Offline digsys
    • DIGSYS
« Reply #2 on: August 27, 2020, 01:39:24 pm »
Also got "Your connection is not secure" on Firefox, but works OK on Chrome ??
Offline KaneTW
« Reply #3 on: August 27, 2020, 01:49:00 pm »
Got an expiration earlier on Chrome too.
Offline PA0PBZ
« Reply #4 on: August 27, 2020, 01:51:01 pm »
See also here: https://www.eevblog.com/forum/supporters-lounge/eevblog-letsencrypt-certificate-expired/
Cert valid till today 15:09 CET, It's now 15:50 and Chrome says expired.
Online Alex Eisenhut
  • Place text here.
« Reply #5 on: August 27, 2020, 02:00:30 pm »
 The certificate for www.eevblog.com expired on 8/27/2020.
Error code: SEC_ERROR_EXPIRED_CERTIFICATE
Offline PA0PBZ
« Reply #6 on: August 27, 2020, 02:02:35 pm »
There's a new one already, however new? Valid from July 29 to October 27, looks like Gnif recycles certificates?  :D
Offline rhysb
« Reply #7 on: August 27, 2020, 02:11:29 pm »
I got an expired Cert error after a refresh it was fine (got the other cert). seems like it's a issue with one of the servers and not the other that the site is load balanced across
expired at 11:09PM (Syd Time) (about an hour ago)
Edit: just got it again see attached
« Last Edit: August 27, 2020, 02:17:06 pm by rhysb »
Offline PA0PBZ
« Reply #8 on: August 27, 2020, 02:16:56 pm »
Yeah, I see the expired cert again now :|
« Reply #9 on: August 27, 2020, 02:18:15 pm »
This is the one that's expired and is being served (to me at least):
Serial number: 03:AE:F2:B1:69:6A:23:C3:8F:B1:73:AF:82:20:CF:DB:FB:EB
Fingerprint: SHA-256 7C:AC:4D:2B:7E:55:72:4A:7D:95:8B:4E:9D:B2:2C:B7:EE:20:B3:E9:5E:5D:F2:89:B4:E9:BA:DF:3D:35:68:D8
CN: eevblog.com
Issuer CN: Let's Encrypt Authority X3
Validity
Not Before 29/05/2020, 14:09:27 (British Summer Time)
Not After 27/08/2020, 14:09:27 (British Summer Time)
Offline PA0PBZ
« Reply #10 on: August 27, 2020, 02:20:24 pm »
Gnif is aware so I suspect it to be solved soon.
Offline Haenk
« Reply #11 on: August 27, 2020, 02:31:10 pm »
expired for me too
Offline b_force
    • One World Concepts
« Reply #12 on: August 27, 2020, 03:11:14 pm »
Same here in firefox, chrome as well as opera
Online Monkeh
« Reply #13 on: August 27, 2020, 05:37:10 pm »
Clear your browser cache and the cert error will go away.
50/50 chance and you piss away all that useful cache. Don't do that.
192.154.109.3 is using the current certificate. 192.154.111.219 is using the expired one.
Offline PA0PBZ
« Reply #14 on: August 27, 2020, 06:04:46 pm »
No, a cert error wil not go away when you clear the cache, reboot the pc or do a rain dance. There are 2 servers with a load balancer, one has an expired certificate and the other one is still valid (until October if I remember correctly).  Which server you get depends on how the dice rolls.
Offline maginnovision
« Reply #15 on: August 27, 2020, 11:09:58 pm »
I get the cert issue either way here.
The following users thanked this post: wraper
Offline b_force
« Reply #16 on: August 28, 2020, 12:16:26 am »
Still same here as well, doesn't matter which computer or VPN server I use.
It's kind of annoying....
I guess I can make an exception rule.
Offline gnif
« Reply #17 on: August 28, 2020, 01:54:59 am »
Sorry about this everyone,
The certificate renewal process on one server had failed, which is why it was inconsistent.
I don't, we use LetsEncrypt which only issue a certificate for a few months at a time and it requires a service to renew them before they expire.
The following users thanked this post: EEVblog, b_force, thm_w
Offline PA0PBZ
« Reply #18 on: August 28, 2020, 06:59:24 am »
Yes sorry, I didn't notice it was another server.
