Hello everyone, I've been having a similar situation for over 2 months. In December I purchased a new PC, picked parts at a Microcenter (MC), and had them build it since I am barely an amateur. Over a month later, when the PC cannot be refunded, I started to experience PC shutdowns when standing up from my chair (Event). Like in the video, it wasn't every time but frequent. I would have to reboot the PC from the case. One time when I was working with files in an external hard drive (EHD), the Event occurred and the EHD was fried. The PC was purchased to match my monitor, Samsung Odyssey G7 4k/144hz, and for information, I already had a Secret Labs Titan Chair. MC has been very little help but suggested using an HDMI cable, instead of the DP cable. The Event still happened and I tried about 4 different iterations of HDMI, DP, and HDMI/DP cables. I tried another copy of the monitor to see if I bought a bad monitor, Event still occurred. I am currently testing another scenario by placing my PC on a plywood sheet on 3 towels on a cardboard box on the floor. For 6 days, no Event so far, and yet I am still having ESD happen when standing up. When using my older PC, the monitor had the same black screen situation that was seen in the Shocking 4K BENQ Monitor Problem video. I was lucky enough to get a Watts Up? Pro meter hooked up to my PC to monitor (amps, watts, volts, etc.) The readings were Max Volts at 126.1 after the Event occurred/ 125 before, Max Watts 510 after / 399 before, and Max Amps 5.4 after/ 4.9 before. I haven't been able to review the data yet but will confirm what happens exactly when the Event occurs. I purchased a grounding plug and cable to ground my chair. I heard that I should get a humidifier. Any questions or thoughts on how to address this?
