Author Topic: 4K Video Editing PC Build  (Read 53155 times)
0 Members and 11 Guests are viewing this topic.
Offline Lockon Stratos
  • Country: hu
Re: EEVblog #1098 - 4K Video Editing PC Build
« Reply #25 on: June 23, 2018, 10:17:19 pm »
Is this even possible? There was a major update since then, so it should not even matter which patches were installed before.
It is possible if you killed windows update. AFAIK only possible on anything below spy10....
:palm: How this is even related, all you need is some JavaScript running in an ad you see while you are visiting some website including eevblog.
NoScript FTW... ;)
Offline Fungus
« Reply #26 on: June 23, 2018, 10:44:42 pm »
As for the PSU:
http://www.realhardtechx.com/index_archivos/SILVERSTONE_Essential_series_ET650_B_650W_4.html
Its as bad as it gets. 8pin Protection IC -> usually no OCP on any rail, no UVP on +12V either.
Capacitor Choice doesn't look that good with JunFu/CapXon
Since I don't think there is any AVL from Silverstone for Cost Reason, it is possible that some units might even have ChengX capacitors - like my CWT GPS-750V has...
I was surprised by the PSU, it looked bargain-basement level to me.
Dave's normal obsession with quality capacitors seems to have gone out of the window on this one.
The following users thanked this post: Frank
Offline Razor512
« Reply #27 on: June 23, 2018, 11:07:27 pm »
In his use case, the intel platform would be better, and the main thing I would change on that system, is the heatsink. He should use at minimum, a NH-D15, especially since he will need to overclock that CPU to get the most out of it.
GPU encode needs the fastest possible single threaded performance or the GPU encoder will get stuck waiting on a single thread to feed it.
He's not using GPU rendering. Besides GPU rendering is limited (in terms of supported settings) and the lower quality of the final product compared to CPU rendering.
https://youtu.be/APvuMPGswug?t=1640
If he is doing what he did in the video that he made and recorded, then a higher clock speed will increase the encode speed, and like in the video, he did see an improvement.
Nvenc only has 1 thread that prepares data for the GPU to render, thus everything will get held up by that single thread. The application will use multiple cores, but the task that is most important, is left with just 1 core. If he could control which core that nvidia encoder thread fell on, and overclock that 1 core to 5GHz,he would see a large speed increase.
If he is relying purely on a CPU encode, then threadripper would offer better encode times, but other aspects of editing will suffer, especially if he does tasks that are traditionally single threaded, such as camera tracking, or if he tries to do a special combination of color grades that cannot be GPU accelerated.
Online wraper
  • Country: lv
« Reply #28 on: June 23, 2018, 11:07:52 pm »
Possible if you killed updates completely. Which means you don't care about security at all.
NoScript FTW... ;)
=NoYoutube and NoManyMore. If you leave scripts enabled for any single website, you are not safe because you can stumble on malicious ads anywhere.
« Last Edit: June 23, 2018, 11:11:11 pm by wraper »
Offline boffin
« Reply #29 on: June 24, 2018, 05:21:45 am »
Where did the video go?  I watched 1/2 of it a few hours back, came back to watch the rest and it's gone.  Who's copyright was offended this time?
Offline Brumby
« Reply #30 on: June 24, 2018, 07:22:27 am »
Dave may have done some further editing and is uploading the new version.
I suggest trying again over the next couple of hours or so...
Offline Fungus
« Reply #31 on: June 24, 2018, 08:12:40 am »
NoScript FTW... ;)
No, but you're a lot safer.
(and the web is a whole lot less annoying)
Online wraper
  • Country: lv
« Reply #32 on: June 24, 2018, 09:07:12 am »
NoScript FTW... ;)
Disabling updates is compromising safety to begin with. Then NoScript to somewhat half-assed solution.
And much more annoying, not less (for less annoyance there is adblock). You'll find like half of the websites don't work or work incorrectly. And every time you'll manually enable scripts, you'll compromise security. I disable scripts myself sometimes against very annoying news sites which want you to pay subscription but allow reading the thing with scripts disabled. But every time I disable scripts, I find that almost any other site is broken.
« Last Edit: June 24, 2018, 09:11:55 am by wraper »
Offline GeorgeOfTheJungle
  • Country: tr
Re: 4K Video Editing PC Build
« Reply #33 on: June 24, 2018, 09:17:38 am »
Calm. 99.999999999% of the browsers are NOT vulnerable. Check yours here:
https://codepen.io/internweb/full/XVZmQW/
If you disable the javascripts, might as well just stop using your computer.
« Last Edit: June 24, 2018, 12:12:45 pm by GeorgeOfTheJungle »
Online wraper
  • Country: lv
« Reply #34 on: June 24, 2018, 09:29:54 am »
What a BS claim, 99.999999999% pulled out of from thin air, there are not so many people on the earth for that figure to make sense. And this tool does not test against meltdown which is the most dangerous.
Offline hans
« Reply #35 on: June 24, 2018, 09:59:41 am »
Seems like the video is up again at the EEVblog2 channel..
I think there is little point to go the i9 series processors on the Intel platform. Then at that point I think a threadripper is way more cost efficient. The 7900x is literally 2x more expensive than the 7820x, for only 2 more cores (which are also clocked a bit slower).
This benchmark suggests it's a pretty linear increase in speed of about 20%, for 100% more cost (but less on total system cost though).
In terms of comparing it to AMD offerings, see same benchmark. The AMD 1800X is nowhere close in h265, the 2700X is an incremental improvement (add a generous 15%), so same. The 1920X is 22% quicker in h264, but about on par as the 7820X in h265. So it's about even I guess.
I assume this is also Dave's workstation at the office, in that case the faster single-core performance of the 7820X should also be taken into consideration. There the 7820X scores 194 in Cinebench single-thread, vs 167 for 1920X/1950X..
I think that in terms of buying equipment as a desktop, then this is key. Although multi-core performance is nice to have for that 22% h264 boost, this is something you could fix with a next gen upgrade or getting a more expensive CPU. The single core performance for daily tasks is something different altogether. However it's hard to guess where CPU land is going to be in 2 or 3 years time. It probably won't be making much improvements in single-core performance though, so it's nice to maximize what's available.
Threadripper gen 2 is already announced for launch end of this summer I think. Flagship is going to be a 32 core 64 thread monster, but I doubt that will be priced as competitively as the 1950X was. Personally I think they will extrapolate the current pricing scheme, i.e. you will still get more cores for less money than at previous gen launch, but I doubt that they will put out a 32-core chip at 1000$, such that the other skews (12, 16, 24?) will be priced accordingly..
I'm planning to upgrade my workstation somewhere this winter, and key for me would be to see what the ST/MT performance vs pricing vs core load will be..
But if you're only doing GPU accelerated rendering, then probably the i7 is plenty..
« Last Edit: June 24, 2018, 10:05:09 am by hans »
Offline elgonzo
« Reply #36 on: June 24, 2018, 11:34:28 am »
Dave's normal obsession with quality capacitors [...]
That's just popular entertainment for the crowd. ;D
Offline Monkeh
« Reply #37 on: June 24, 2018, 11:40:44 am »
Daft CPU, silly flashy RAM, and cheaping out on motherboard and PSU.
Oh well. Lead a horse to water and all that.
Offline EEVblogTopic starter
« Reply #38 on: June 24, 2018, 12:14:44 pm »
And does the job nicely, thanks for asking.
« Reply #39 on: June 24, 2018, 12:16:53 pm »
nonsense, we're engineers. Threadripper is objectively a much better part for a video encoding machine.
Exactly.
Apart from the fact that the CPU is not doing the encoding.
  • Country: hu
« Reply #40 on: June 24, 2018, 12:20:48 pm »
I do care about security, but i want to decide when to update and i do not like my PC restarting on me. Usually i put my PC into sleep mode with a ton of stuff open, i would be pretty pissed off if it would restart because "security".... BTW just because you dont install updates it does not mean you are not safe, the last updates i installed are from 2015 on my win7 partition and interestingly i didnt got any kind of crap on it(it was my main OS up until a few months ago). Contrary to what you believe the reason for disabling updates is not the lack of care for security, but because i care. MS used the update system to spread ad and spyware onto older versions of windows, and they fallen so low that they marked some of them as security updates.
You can enable them on a per domain basis, and with adblock you can do it even on per script basis.... Its not convenient? Yes, but if something is more secure its always less convenient....
Offline Monkeh
« Reply #41 on: June 24, 2018, 12:22:10 pm »
Exactly.
Then why bother with that monster at all?
« Reply #42 on: June 24, 2018, 12:25:42 pm »
I would have gone with Threadripper, because this is exactly what it's made for.
No, it's not. It's made for instances that can make use of large numbers of threads, and that isn't the case in my workflow. The CPU isn't doing the rendering. And Vegas doesn't really make use of it in general.
« Reply #43 on: June 24, 2018, 12:26:58 pm »
Exactly.
The CPU is still decoding the source and funneling the 4K data to the GPU.
Offline Monkeh
« Reply #44 on: June 24, 2018, 12:28:53 pm »
When did that become a 16 thread problem? Decoding is fast and, well, DMA.
« Reply #45 on: June 24, 2018, 12:29:31 pm »
CPU runs at under 60degC when rendering (overclocked). 70degC on 100% all cores loaded. I wouldn't say that's something that needs fixing.
« Reply #46 on: June 24, 2018, 12:31:00 pm »
I never said it did. In fact I believe it's a single thread operation in Vegas. Hence why Threadripper is not the best tool for the job here.
Offline Monkeh
« Reply #47 on: June 24, 2018, 12:34:04 pm »
Don't mind the Noctua fanboys. The Hyper 212 is, although not the best, almost without doubt the best value air cooler on the market. Unless you're using one of the old AMD 220W space heaters it's an easy choice.
.. well I asked you specifically why you picked the monster 16-thread i7, and that was your answer. Note I never suggested Threadripper, either..
Online wraper
  • Country: lv
« Reply #48 on: June 24, 2018, 12:46:34 pm »
So many websites will be broken, it does not even matter. Websites are not controlling what ads they show, so leaving some websites with scripts enabled makes this practically meaningless.
https://en.wikipedia.org/wiki/Malvertising
« Last Edit: June 24, 2018, 12:51:12 pm by wraper »
Offline Fungus
« Reply #49 on: June 24, 2018, 01:10:07 pm »
From the video:
Average CPU use is well over 50%.
« Last Edit: June 24, 2018, 01:23:46 pm by Fungus »
