Author Topic: 4K Video Editing PC Build  (Read 54274 times)
Offline Stefan Payne
Re: EEVblog #1098 - 4K Video Editing PC Build
« Reply #175 on: June 26, 2018, 04:09:16 am »
Yes and if you had a Plugin for your Forums that Allows people to thank other for Posting something, you don't need to have that Problem. You just get the one with the most votes/thanks and misuse that feature for other things.
.. have you actually used this forum? Like, ever? Looked around?
no, tbh.
I'm more used to vBulletin and know my way inside and out of that Software.
Invision I sadly also use. Its kinda cancer...
Anyway, a bit of Electronics porn. Something I can link and don't care about Copyright. Because I made those pics myself.
Something not that awesome but still somewhat OKish:
« Last Edit: June 26, 2018, 04:12:40 am by Stefan Payne »
Offline Razor512
Re: 4K Video Editing PC Build
« Reply #176 on: June 26, 2018, 04:29:58 am »
For the thread that is actually responsible for prepairing and feeding the processed frames over to the GPU, how much CPU time is it using. It is not hard to end up with a CPU bottleneck while having task manager report a low overall CPU usage. On a CPU with 16 threads, a single thread just needs to use a little over 6.25% overall utilization to be fully occupying the time of a single core.
This type of behavior is why you will see behavior like the CPU usage in fallout 4 dropping when you spawn a ton of NPCs, the AI is single threaded and the engine waits on that thread before doing more work.
Beyond that, other bottlenecks can arise if in your editor timeline, you have effects or adjustments that are not multi-threaded. Not sure how many of those limits sony vegas has, but adobe premiere, as well as after effects, have many effects and adjustment options that are computationally expensive while also being single threaded.
Those limits are at least the case when using the nvenc plugin for adobe premiere pro (though it has gotten really unstable as adobe premiere has been updated).
Offline EEVblogTopic starter
« Reply #177 on: June 26, 2018, 04:40:24 am »
The forum does have that feature.
The following users thanked this post: Razor512
Offline gnif
  • Views and opinions are my own
    • AMD
« Reply #178 on: June 26, 2018, 04:47:11 am »
Yes, with filters/effects there is certainly a correlation with CPU clock, but for the final encode via NvENC there is little to no gain in having a faster CPU clock.
As for your assumption that the effects may not be multi-threaded, video processing (not encoding) is an extremely SMP friendly computing paradigm. You have thousands of concurrent jobs you can do at once, one for every frame. The only part of that process that must be ordered is the final encode as mpeg uses motion prediction. Most effects are performed on the GPU anyway using shaders, again bringing us back to synchronization spin locks.
Without actually profiling the application, it is impossible to determine if you have high CPU usage, or high CPU wait in spin locks, CPU load alone is no indication of overall system load or performance with this computing paradigm.
SMTS Software Development Engineer @ AMD
« Reply #179 on: June 26, 2018, 04:54:18 am »
See, Problem solved.
Should use that next time you need to know something :)
Offline gnif
    • AMD
« Reply #180 on: June 26, 2018, 05:06:00 am »
I remember you Stefan, you are that person that decided to argue that my ATX motherboard was incompatible with my ATX standards compliant PSU. People like you are exactly why Dave doesn't consider "advice" from people like you reliable. Too much of it is conjecture, opinion or speculation as to how things work, and are not based on empirical evidence or understanding.
« Reply #181 on: June 26, 2018, 05:42:29 am »
Yes because I have such a situation here. And it happens in some very rare occasions.
I have a perfectly fine Corsair HX750i that works with like half a dozen ATX Motherboards.
And I have a Gigabyte X79-UD5 that also works with half a dozen other ATX PSU.
But the Corsair HX750i does not work with the Gigabyte X79-UD5...
And its the same thing that people working in the industry say, that it can happen, though its a very uncommon occurance.
And replacing either of those component solves the Problem.
And they don't really know what caused it.
Yes, I've talked with people of the industry about that stuff and that is what I know. If you don't believe me, fine. You don't need to. But insulting me for something that you don't believe, is that really necessary??
« Last Edit: June 26, 2018, 05:45:44 am by Stefan Payne »
Offline gnif
    • AMD
« Reply #182 on: June 26, 2018, 05:59:49 am »
And its the same thing that people working in the industry say, that it can happen.
That's also what people working in the Industry say. Like jonnyGURU, he mentioned that from time to time, that a PSU just does not work with a  motherboard although both are perfectly fine and within the spec...
but you argued that a missing signal is just a "incompatibility". It wasn't just slightly out of spec, it was completely dead.
In your example, did you measure the PSU to verify why it was "incompatible"? Did you obtain another HX750i to verify it wasn't at fault? Did you perhaps think that the Gigabyte board might be slightly out of tolerance and was playing it safe by refusing to start with a possible faulty PSU? My point remains, you have no empirical evidence, just your assumptions.
I wouldn't have said a thing, but when you started telling Dave how to use his forum, and your condescending attitude I felt it was time to speak up.
« Last Edit: June 26, 2018, 06:32:53 am by gnif »
Offline pkplex
« Reply #183 on: June 26, 2018, 06:17:49 am »
Dave really called it.. so many people with their nickers in a twist about a damn computer.
The following users thanked this post: hans, gnif, Dubbie
« Reply #184 on: June 26, 2018, 07:32:04 am »
Because there is so much Misinformation, Bullshit, Lies and Fairy tales in this area you can write books about that...
And now a highly regarded electronics person does all the things those People are fighting against...
That's one of the reasons people are posting here right now...
Epecially in the PSU area. Like the lie of "Single Rail is better, Multi Rail is garbage*", bigger fans equal lower noise (no it doesn't!), Efficiency equals quality (well, there is a bit truth to that -> there are no good quality 80plus Bronze or worse PSU right now. The best bronze ones are just somewhat OK right now because Gold is like 2,5€ more in manufacturing), that the manufacturer is the most important thing...
Or stuff like you need a 750W PSU for an office PC (well, in ATX Formfactor, there are no really good PSU under 400W), should be loaded only up to 50% (when the good PSU are rated at continuous power at higher ambient temperatures, usually 40°C, sometimes 50°C. The Cheaper ones are only rated for like 30-35°C Ambient).
When we come to Graphics Cards and CPUs, it doesn't get any better.
The worst thing I've seen is that people believe that nVidia Cards are for Intel and don't work well in AMD Systems or vice versa with AMD Cards -> people believe that they only work well in AMD Systems...
*That is essentially Multi Rail in a PSU:
(Pic of a 14.95€ PSU ;))
A Shunt Resistor or a coil per Rail, a wire per Rail to the supervisior (or something like that like an LM393). And just some way to limit the current for a certain set of cables. And switches it off, if it is over the set limit.
PS: For the Electronic Nuts who want to learn about Power Supply Stuff and are pretty bored, google Texas Instruments UCD3138A.
And that thing is already used in some higher end Power Supplys today. And has has a 31,25MHz ARM7 Core...
Offline wraper
  • Country: lv
« Reply #185 on: June 26, 2018, 07:40:07 am »
Dunno what is with Gigabyte but I stumbled on several of their motherboards (most I had) which had issues with PSU compatibility. Like not starting at all or starting with all or most of USB ports not working. Or Voltages displayed in bios being random crap, not just off but complete nonsense. Really weird, the weirdest part is that if I switched incompatible PSUs between such 2 mobos, both started working fine  :palm:.
« Reply #186 on: June 26, 2018, 08:13:26 am »
I might have been wrong in that case.
And might have my mind at the Corsair <-> Gigabyte Situation because as far as I remember that was a fairly recently occurance for me at the time.
No, because I don't have no warranty on any PSU I have here right now.
What I remember is that a somewhat similarlish PSU, though a bit different Plattform worked -> Corsair RM650i
And I have talked to people who were at the time responsible in PSU Development at a PSU Manufacturer. And they told me that that stuff might happen. They said that it had to do with the with the Tolerance of the PSU and the Board, if both are a bit borderline "in the right way"; it doesn't work.
And I think I've seen a similar configuration by someone else in a Forum in their Signature. So its not a general incompatibility just something that happened with the Board and the PSU I have.
I have two other PSU that use a similar Infineon LLC-Resonant mode Controller as the Corsair, both don't have that Problem. Though the Supervisor is a different one...
Those things are less common these days and probably something like winning the lottery (in a bad way).
The usual Failure rate of a decent PSU should be at 1% or less.
A 2% Failure Rate is considered bad and a major problem.
And you need "the right" motherboard as well...
« Reply #187 on: June 26, 2018, 08:29:28 am »
Because I deliberately bought a cheaper PSU instead of some high end one?
Wow, what a crime!
Although I know jack all about Silverstone, they at least look like a legit company, Taiwanese instead of Chinese, legit presences in the US and EU, been around a long time etc. The supply I got has been independently tested to meet the Bronze 80 standard, which without knowing much about the world of PC PSU's sounded at least OKish. It's got to better than some OneHungLow no-namer from ebay? I just needed an OKish PSU, yet people seem to think this is some sort of crime against humanity  ::)
« Reply #188 on: June 26, 2018, 08:47:41 am »
Silverstone has some decent PSU, the Strider Gold ( ST55F-G) seems OK, below that, they could do better - much better.
The Strider Platinum Series is pretty nice, though the Casing is on the cheaper side.
Here some Pics of a Strider Platinum:
https://img.tweakpc.de/album/lT
Made by Sirfa, all Japanese Caps (made in China of course because of the Import Tax China has, it has to be manufactured there).
Best thing is the pretty beautiful soldering (except for the hand made part of course)...
No polymers though...
80plus is totally useless though because many companys (if not all) do send in golden samples...
Some even totally different units than they sell...
« Reply #189 on: June 26, 2018, 08:54:17 am »
Ok, so Mr PSU expert now admits that Silverstone make some decent PSU's. I can sleep better tonight, thanks.
So are you accusing Silverstone of doing this?, or just floating this theory to somehow back up your stance that my choice of the cheaper PSU was complete shite?
BTW, the 80 BRONZE series is not the cheapest supply they make, that's the 80 BASIC.
So according to you I at least chose a decent PSU brand name, and I went one level one form their entry level offering. Do you still have a problem with my choice for cheap PSU?
a)one level up.
Offline Fungus
« Reply #190 on: June 26, 2018, 08:57:57 am »
Interlaced 50i and 60i are a disaster for fast moving objects, much worse imo than 30p, 25p or even 24.
All of that is very relative. Raw frame rate tells you nothing, it depends on the persistence of the display.
eg. I used to use 50Hz monitors all day long, no problem, because the phosphors were designed for no flicker at 50Hz.
Then cheap-ass, low-persistence PC monitors came along and anything less than 75Hz was unbearable.
Cinemas project at less than 30fps but nobody complains of headaches.
« Last Edit: June 26, 2018, 09:00:52 am by Fungus »
Offline Fungus
« Reply #191 on: June 26, 2018, 09:04:58 am »
....my choice of the cheaper PSU was complete shite?
It's probably fine. The problem is you've published hundreds of videos criticizing PSUs in one way or another. It creates expectations in the viewers.
Solution: Get it opened up on video (alongside the one you took out....) :popcorn:
« Last Edit: June 26, 2018, 09:07:18 am by Fungus »
Offline TheAmmoniacal
  • Country: no
« Reply #192 on: June 26, 2018, 09:11:06 am »
@EEVblog: Get the MASTERWATT MAKER 1200 MIJ or nothing!
< goes on a rant about Dave's bad component choices because I'm an AMD fanboy and you should have gone with Ryzen >
« Reply #193 on: June 26, 2018, 09:15:39 am »
Why so Agressive Dave?!
As an Engineer, shouldn't you want any information you can get about anything?!
Yes, they do some good stuff.
But your PSU is not one of them.
No, I'm saying that 80plus is useless you overrated it and only, at most, tells you that the efficiency should be around that area.
You can't trust whatever there is written further than you can throw it.
And they don't do realistic testing...
Because with modern Systems, you have something like 1-2A on each minor rail.
And if you're lucky like 5A on +5V at most.
Brand is irrelevant as everyone has equal oppurtunity because everyone has access to many of the contract manufacturers and can order whatever they want - as long as they are willing to pay for it.
All that counts is what you (as a manufacturer) wants and what prices you can get or make. If you want a group regulated unit that is rated for 25°C room temperature, you get that.
If you want an independently regulated 80plus Titanium (94% Efficiency at 50% load) that is rated at 50°C you get that as well. Just a question of Price.
Point is:
If you don't cut cost on a good quality PSU, you're not able to deliver a competitive priced 80plus Bronze unit.
The difference in Cost between Bronze and Gold are negligable these days.
And that is why you still see the "System Integrator Level" units with Double Forward Topology and Group Regulation for 5V and 12V. 3.3V always was regulated independently...
That is the reason why all the good stuff these days comes with at least an 80plus Gold Label. And at worst some decent 80plus Bronze units are as expensive as entry level Gold units.
« Reply #194 on: June 26, 2018, 09:21:02 am »
Wanna bet the Thermaltake Toughpower has bulged caps? ;)
If it is the one I think it is, it should come with Entry level SamXon Caps...
If I'm wrong, it is one of the newer ones with
€dit:
It is the Tough Power XT that comes with DC-DC but only has Teapo Entry Level Caps (SC Series, rated for 2k, not 3k because DOWNSIZE Caps or rather custom size wich makes a recapping almost impossible because you need 10mm 3300µF/16V Low Impedance Caps), Review from good old Gabriel Torres -> https://www.hardwaresecrets.com/thermaltake-toughpower-xt-775-w-power-supply-review/2/
Similar Plattform to the old Corsair HX750 and 850, the ones that were officially 80plus Silver.
But its around 10Years Old or so.
The ironical thing is that its better than the new one. As far as I remember they were always independently regulated -> Dual Mag Amp at the time  :o
Only the newest ones had DC-DC.
Problem is the age, it can fail any second now and its not that great by todays standards either.
« Last Edit: June 26, 2018, 09:35:05 am by Stefan Payne »
Offline wraper
  • Country: lv
« Reply #195 on: June 26, 2018, 09:38:17 am »
They don't make anything. Just order some already available PSU design with some minor customization from several actual PSU manufacturers. That's why one PSU model they sell does not say anything about another model. They may be made at completely different places.
Offline pkplex
« Reply #196 on: June 26, 2018, 09:58:05 am »
And you felt it necessary to add to the heap?
« Reply #197 on: June 26, 2018, 10:10:11 am »
Was never my intention.
I did just say what I think is what people thought about this stuff.
So I can understand why some People are not amused by this public video on youtube.
IMHO this Video would have been better as a Bonus for the Patreons, maybe unlisted on Youtube...
« Reply #198 on: June 26, 2018, 11:23:36 am »
I did, a teardown is in the video, it's exactly what I'd expect for the price, and a surprise of a Japanese main filter cap.
Offline Fungus
« Reply #199 on: June 26, 2018, 11:32:25 am »
There's a new video? Ok, let's see.  :popcorn:
