Author Topic: EEVblog #1094 - Casio FX260 Solar II Calculator Experiments  (Read 4070 times)
Offline EEVblogTopic starter
Some experiments on the Casio FX260 Solar II scientific calculator.
Improving the solar capacity, trying out a Tritium nuclear battery!, current measurement, and probing of the PCB and LCD signals.
BONUS FX991EX Teardown and soldering iron burn!
Offline max666
  • Country: at
Re: EEVblog #1094 - Casio FX260 Solar II Calculator Experiments
« Reply #1 on: June 09, 2018, 07:11:00 am »
If we're talking tantalum and super cap, isn't going overboard on capacitance detrimental to low light performance, due to higher leakage current of the cap?
« Reply #2 on: June 09, 2018, 10:02:17 am »
Could be in theory, but tantalum leakage is in the order of a uA or less. Niobium oxide is usually slightly higher.
Operational current was measured at 30 times that, so should be fairly negligible. Closer margin in lower light, but I don't think it'd be a problem. Worth checking though.
Offline Fungus
« Reply #3 on: June 09, 2018, 10:55:31 am »
Does it still charge the cap when it's switched off?
Turn-on delay will be zero if so.
« Last Edit: June 09, 2018, 04:56:57 pm by Fungus »
