I've got two UT120C meters bought back in 2013, both with 09/2012 production date on the back. One of them I carry around in a document pouch so it basically goes everywhere with me, mostly to be used every other day at work if needed. The second one is a garage meter. They are quite durable, after 5 years the cases are now definitely less transparent from all the scratches and do not lock properly anymore, but the meters inside still pretty much look almost like new. Of course they both share the same flaw on capacitance (10,15nF minimum reading). Both meters have survived some accidents and they still work fine, so I'd say they were definitely worth buying.
Btw, I think the UT120C cases were designed to wind the probe wires around the holders inside instead of just sticking them there. At least it works for me, I've been doing that for years and never had a problem with probes or wires sticking out from the case.
