Avometers are fucking dangerous. I'm surprised to see people defending them here. The cut outs are notoriously sticky after a couple of overload events which causes total incendiary destruction the next time, they give false indications if you drop them even once and they're bloody unreliable to start with, especially the 8 mk 5 / 6. Why the hell you'd want to rely on one I don't know. They're fun I suppose but that's about it.
Company I worked for eviscerated them by force from the fanboys because people actually had got hurt using them. I wish I had a copy of the PDF they sent around. "anyone with an Avo on their bench will be stuck on assembly for a week". They were giving out HP 34401A's from equipment storage and people were still using Avos...?!?
There is no place for them in a professional setting now. What you do in your own time is your business but if you burn someone's facility down because your Avo was misreading or damaged or you fucked up then... ugh I don't know but just don't go there.
As for stupid, you can't fix stupid. Test procedures are as important as kit but the objective is to minimise
all aspects of risk in any environment so start with the easy wins:
1. Training.
2. Stop people from walking around with loaded guns.
Incidentally I actually do use an analogue meter, but I built it myself, the top range is 150V, it does DC only, FET input and only gets used on anything after a transformer secondary at most. I built this because it's difficult peaking RF PAs with a DMM due to the noise. Everything else, I have a nice Keysight handheld
