Author Topic: EEVblog #1061 - Data IO Programmer REPAIR - Part 1  (Read 16269 times)
Offline Daxxin
Re: EEVblog #1061 - Data IO Programmer REPAIR - Part 1
« Reply #25 on: February 03, 2019, 07:44:23 pm »
Data I/O sold a Mass Storage Module for the Unisite.  It had a 80MB PCMCIA hard drive on it.  It replaced the extended RAM card mounted under the motherboard.
I have found only one 170 MB Sandisk flash drive that would work.
hi , yes seen that upgrade , but its working only with new board revision ..mine is old same of Dave shown in youtube
Offline SCSKITS
  • Retired electrical engineer
« Reply #26 on: June 05, 2024, 12:08:29 pm »
I realize that this is a very old thread, but I now have an MSM board for the older version UNISITE with either 1MB RAM or 8MB RAM on board.
The board plugs in in place of the expansion RAM board that is located under the main board.
MSM boards also available for the 2900 and 3900 series and also for the newer version UNISITE that has the RAM modules on the main board.
Boards are listed on EBAY
ed
SCS, DIY upgrades for older test equipment
