Author Topic: EEVblog #1057 - µCurrent Murphy  (Read 21593 times)
Offline fusionmkx
Re: EEVblog #1057 - µCurrent Murphy
« Reply #25 on: February 13, 2018, 06:51:19 am »
Fascinating, thanks! This has been a very educational episode indeed.
Offline Decoman
  • Country: no
« Reply #26 on: February 13, 2018, 03:55:53 pm »
Not being all that into electronics, my unit #4990 seem to have the one labeled 321T looking closely.
Offline donmr
  • W7DMR
« Reply #27 on: February 13, 2018, 05:51:15 pm »
I look at this very simply.  The op-amp supplying the virtual ground has some limit to it's frequency response.  Anything above that limit needs to be shunted through one or more capacitors.  You don't need larger caps that this however and I suspect that the 100nF Dave is using may be a bit more than that.
Offline amitmey
  • Country: il
« Reply #28 on: February 13, 2018, 07:02:50 pm »
Hello,
I found my uCurrent has 321s too and behave the same (3.6mv offset connected to BM235 and 4.7mv when connected to the scope with 5Mhz noise up to 25mv).
The offset was cancelled to 0.01mv when 0.1uF ceramic cap was added over R7.
Amit
« Last Edit: February 13, 2018, 07:04:57 pm by amitmey »
Offline Kevin.D
« Reply #29 on: February 15, 2018, 01:57:36 am »
Apart from the possible issues created by having Virtual GND which has a source impedance of 270 Ohms :- meaning some fraction (~ 270/Zload) of your output signal appears across R10, your output signal rides on top of this common mode signal who's amplitude increases as Zload decreases and approaches R10, this though isn't the source of the oscillation shown in that video (which at one point looked to be around 2Mhz, well above the lmv321 crossover freq), this though is probably tipping the two  unstable Max4239's configurations (u1,u4) into oscillation.
 Max4239'S are Decompensated op-amps, these are only stable at gains greater than 10. Another way of stating this is that the fraction of Output signal you feed back to the inv input shouldn't be greater than 1/10 .
So adding feedback caps (Like c3,c4 here in Ucurrent schematic) which then at some freq (1/2pi C4 Rf) starts to feedback a greater portion of the output signal will cause any NON unity gain stable Op-amp to become unstable.
There are a number of techniques available to enable use of NON unity gain stable OP's with capacitive loads . One I won't discuss here is a resistor + cap between the op's inputs  http://www.ti.com/lit/an/snoa486b/snoa486b.pdf
Here's one I sometimes use with both compensated and decompensated Op's, being useful when a flat response is desired. First decide what is the max value of Capacitive load that we want the Op-amp to be stable with then Cf can be calculated.
 I usually make Cf*Rf= Cload*(Rop+Riso). Where Rop is the open loop output impedance of your OP (typically 50-100 but there are exceptions).
 Then calculate Cs by making  Xcf/Xcs = Rf/Rg . Here for these relatively low frequency OP's we can ignore the small input capacitance (few pF) of the Op-amp which adds to Cs .
One way to describe whats going on here is that initially the gain is set by feedback resistors Rf and Rg then at some frequency (= 1/2pi Cf Rf) the capacitive divider Xcf/Xcs takes over the feedback roll. Because of wider tolerances in capacitors it's not really possible to match Cf/Cs as accurately as you can Rf/Rg so you won't get a perfectly flat response Over your OP's entire B.W .
Addition :- The OP still has to be able to drive the series combo of Cr+Cs :  Ct = (Cs*Cf)/(Cs+Cf) and if this get's to large it itself will load down the op-amp, (so then you would try to use lower values by increasing Rf,Rg).
Simpler is indirect drive method :- here the capacative load is simply isolated from the Opamp feedback node by a resistor 'Riso'. I generally choose in both methods to make Riso to be = Rop  (usually ~ 50 Ohms varying if I want to achieve a specific Zout or working with unusual opamp's)  this should be sufficient to stabilize for capacitive loads of practically any size. Making it larger doesn't really increase stability value, it just means higher Zout.
The major difference between the first and second method is that in the first method Riso is inside the feedback loop so the op-amp reduces the apparent output impedance to approx (Riso/1-Loop Gain) which is very Low (< 1 milliohm at DC). Then at the comp freq ( 1/2pi Cf Rf) the capacitors take over feedback, above this frequency  Riso is no longer inside the feedback loop, thus Zout rises to ~ Riso .
With the second method Zout = Riso over the entire B.W , Which doesn't matter here considering the main intended usage (load is usually 10M Zin multi-meter) which results in a tiny measurement error proportional to ~ (Riso/10M).
Unlike the final output amp (U4) which sees the load, the first Max4239  (U1) shouldn't need any compensation, just remove C3 to make this stable. ( the few pF input capacitance of U1 creates a pole with R5||Rf  but it's well above Fcrossover so no problem).
Regards    Kevin.D
Later Edit :-  I want to correct something I posted above, the statement that 'adding single feedback cap's like C4 and C3 always makes Non unity gain stable op's unstable is incorrect. If I had bothered to do the maths before I had posted I would have seen that in Daves Ucurrent the zero created by C3,C4 is at (1/(2 pi 10p 10k) = 1.6 Mhz  thats just below the crossover for this op-amp when at a gain of 10. You can of course use single small feedback caps that give phase boost's near the  crossover frequency (when loop gain = 1) like Dave did here without being worried  what happens at the higher frequencies because loop gain is then well below crossover. So doing this (even in decompensated amps) help's the Op-amp to remain stable with small load cap's or stray cap on the inv input. The problem is when larger values of feedback caps are used to try and compensate for larger values of load capacitance's, it might be ok for fixed load capacitance values in some cases but when the load capacitance is variable then a decompensated OP will become unstable when the load cap is then much smaller or no longer  present. This is where the two techniques posted above come in as they can cope with wide variation of load capacitance.
« Last Edit: March 04, 2018, 11:47:12 am by Kevin.D »
The following users thanked this post: thm_w, ogden, MiDi
Offline marcognon
« Reply #30 on: April 18, 2018, 12:20:30 pm »
I have huge offset with my uCurrent gold, one of the first batches (bought from the site right after Kickstarter campaign ended). Like 5-10mv even on shorted position, on all three ranges, measured with dmm UT61E, and I tried another two cheap meters.
Even I had the correct op amp, I tried replacing the LMV321 with every variant available to me : Texas Instruments, ST Microelectronics, etc.
The result stays the same. Output capacitors like in the following video fix didn't helped.
Any idea how it could be made to work ?
« Last Edit: April 18, 2018, 12:24:29 pm by marcognon »
Offline d-digiacomo
« Reply #31 on: June 20, 2018, 07:38:36 am »
I'd like to purchase a µCurrent GOLD. Could those in stock at present still have the offset issue?
Danny Di Giacomo
Offline marcognon
« Reply #32 on: June 20, 2018, 01:46:57 pm »
I don't recommend buying it.
I tried 2 more op-amps with same result. I think instability is from design, not from out of spec components. Those uCurrent which work are just by luck ... who knows. I purchased mine right after Kickstarter campaign ended so it should have worked because it had a good op-amp.
Better design your own and learn something in this process. This is what I'm planning to do.
My conclusion is : op-amp design is not so easy as it looks from some enthusiastic videos ...
Offline Susceptibility
  • Country: hu
« Reply #33 on: February 03, 2022, 11:09:15 pm »
Hi!
I know, this is an old topic, but just saw the Murphy video.
I am curious about R8 - why is it connected like that? I know that R8 is an output protection resistor, but connected like that, every capacitive load on the measurement terminals effects the feedback circuit. If the R8 is placed after, then the load is seen through the resistor, and may not influence the circuit a way that creates oscillations, even with the "bad chip".
Offline Kleinstein
« Reply #34 on: February 04, 2022, 10:21:43 am »
The original way R8 is connected is indeed bad and it is doing more harm than good. The red drawn way is the better solution.
AFAIR the problem was more with the virtual ground part and the red modification alone may not solve this, though it can help.
