I don't see, how reflowing the solder between the leadframe and the cap would cause any issues. The same way solder will align components, the same way, solder will keep the capacitor together. Surface tension.
We're not talking 0603s here. 2220 (and larger) chips will slump to the ground and fall apart. Try it
(Well... if you can find any... I'd gladly try, but I don't have any.
Huh, would be really interesting if they were spot welded or something like that, and just coated with solder for connectivity. I wonder if end caps can tolerate spot welding?...
And yes, the leadframe types are really expensive. One of the solution is to just use through hole capacitor, because those are pretty much the same benefits (maybe higher ESL) but they dont have this inflated price.
Well... maybe.
Like this one, it's probably just a regular 1812-ish chip, with leads tacked on and dipped in epoxy:
https://www.digikey.com/product-detail/en/murata-electronics-north-america/RCER71H106MWM1H03A/490-7518-3-ND/4277142so it's not really extreme priced. But these things,
https://www.digikey.com/product-detail/en/avx-corporation/SE045C106KAR/478-5612-ND/2060743Are they one huge chip? Multiple stacked (side by side)? Or these,
https://www.digikey.com/product-detail/en/united-chemi-con/KTD101B226M90A0B00/565-4652-ND/6189636(oh hey, I didn't even realize UCC made ceramics), where their diagram shows a single chip, but who knows, that's just a representation anyway. And then there's this,
https://www.digikey.com/product-detail/en/avx-corporation/ST205C107MAN10/478-5068-ND/1913137but it's pretty clear what that is.
There's also TDK's potted Ceralink modules, which are probably somewhere inbetween.
(These were selections from a simple search on DK, ceramic capacitors, through hole, equal or greater 10uF 50V.)
Also, this is more of an issue, if you have a large board, and really stressed areas. For small boards and simple stressed areas, like an USB connector this is not an issue. For 0603 and even 0805 this is rarely an issue.
Just be aware, where it is needed. And dont start placing these capacitors on the next arduino compatible boards please.
Huh... what do you mean by "simple stressed areas"? Taking that literally, I can't think of a good reason why the stresses around a connector should be simple; they'll have complex curvature, up, down and around...
I don't think that's what you meant, though, really that the situation itself is 'simple', like, who cares about USB, right? But then, what's so simple about that -- if you don't need a capacitor there, then why put it there at all?
(Which is a valid and important question for most USB connector situations, I might add!)
Anyway, smaller caps I think are less vulnerable on account of their being smaller than the board thickness, therefore the board beneath them looks much stiffer than otherwise. Though they aren't as elastic or strong either (smaller chip, less elastic stretchy range -- which is to say, same bulk elasticity), so it's not clear if that should work in our favor, or wash out.
Ah, think of it this way: a relatively large cap will see torque (bending) from its electrodes,
as well as stretching due to the board bending. Whereas a very small cap sees only the stretching of the board surface. This does not save smaller caps in any way (the percent stretch of board surface is independent of scale, so an 01005 is
just as prone to failure as an 0402 on, say, a 3mm thick board), but disadvantages large caps (an 1812 on 1mm board will see significant bending as well as tensile strain). You'll see the difference in the fracture shape, where bending tears the corners off the chip, whereas stretching either shears the pads off the chip, or cracks it more vertically (I think?!).
