"Hi, I'm Dave, and I'm a dickhead"
That one's bound to come back a few times.
use more care with that knife. slow down Dave!
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
also your camera autofocus is BS , get a better camera, or mod it.
why all the autofocus out of focus.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
two setting are needed you at 2 meters and 30cm from the camera.
your an electronics engineer, Let's work the problem. will two intersecting red 45 degree laser beams give you precise focus at 30cm?
