Apparently any of us that did work 30 yrs ago -- with analog only (no storage) scopes -- weren't doing real electronics; if you are to believe a lot of people in this thread.
a) You weren't working in a world full of digital devices so you didn't need storage nearly as much.
b) I've seen all the film camera attachments and stuff you used to use when you actually needed 'storage'.
c) I bet you'd have switched in a heartbeat if today's cheap DSOs were available.
The number of times storage was really needed, I could count on the fingers of one hand.
The Polaroid camera attachments usually were used when checking waveform "specs", rather than to record some fleeting happening.
In fact, they often incorporated a "projected graticule" device which projected a transparency upon the CRT
face.
You fitted the waveform of interest into the reference marks on the image, checked its compliance, & if required, took a picture .
Those of us who were quite "gung ho"about digital things were in for a horrible shock when the Tek & HP guys came round to demonstrate the first generations of DSOs, as they were virtually unusable for everyday Electronic work, which consisted of a combination of analog & some digital circuitry.
A lot of the stuff Techs do on a day to day basis is to do with signal integrity at a quite a basic level.
"Is the signal there at all ?
"Is it approximately the right level?"
"Is it breaking up, or will it do so if I wiggle the cable, tap the board, etc?"
"Is there a lot of hum on the signal?"
It is nice to be able to see "runt" pulses, read RMS values & all the rest, but this is of more importance to EEs developing stuff which hasn't actually worked yet, than to anyone fixing something which has worked.
Police Officers spend most of their time apprehending speeders, burglars, street drunks, & so on.
The International Jewel Thieves don't come along very often.
