Author Topic: Topic of interest  (Read 3331 times)
Offline MosaicTopic starter
Topic of interest
« on: June 03, 2015, 05:41:53 pm »
Hi All:
This taught  me something new:
https://youtu.be/BnR_DLd1PDI
Now for modern preamps etc, such as found in video cams....a cellular phone on silent mode (in your pocket or from a bystander)appears to emit an interfering EM squawk when it recvs a msg. This signal can get sneak into the audio recording without you knowing it  :o. A live feed picks up the interference. |O
I was wondering if an exercise to test this might be interesting: enclose the caps in a preamp with foil that is grounded and see if the interference is diminished. One wonders whether there are modern caps with 3 pins...one for a body ground shield/can. :-+
