Author Topic: EEVacademy #5 - Digital Logic Datasheets Explained  (Read 3732 times)
Offline EEVblogTopic starter
« on: August 30, 2017, 10:04:54 am »
Dave takes you on a complete walk-through of a typical (7400) digital logic datasheet and explains all the specifications and information.
The following users thanked this post: MarvinTheMartian
Offline Brumby
Re: EEVacademy #5 - Digital Logic Datasheets Explained
« Reply #1 on: August 30, 2017, 01:06:20 pm »
I never paid any attention to the "Typical Applications" notes before...
That was funny.   :-+
Offline Neilm
« Reply #2 on: September 03, 2017, 08:21:02 pm »
The worst revision of datasheet I have ever seen (read got caught by) was on supply voltage. In the older datasheet I originally had (at work we use common components and store datasheets on a local server) happily said the chip worked down to 3V - Goody, I was designing with 3.3V. The new datasheet changed this to 3.7V. Fortunatly, I spotted this before I had the PCB laid out.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
