Author Topic: EEVblog 1475 - SMD Part Indentification & Substitution Search  (Read 3539 times)
Online EEVblogTopic starter
Answering another viewer question. Can we identify or find an alternative for this SMD part?
https://twitter.com/PoiSolutionsLLC/status/1529065036433571840
Offline gamalot
  • Correct my English
    • Youtube
Re: EEVblog 1475 - SMD Part Indentification & Substitution Search
« Reply #1 on: May 28, 2022, 12:04:39 pm »
I have only seen some parts of Diodes with such a marking pattern, 5 alphanumerics, no other elements, not even the dot for pin 1.
Offline RES
« Reply #2 on: May 30, 2022, 02:51:20 pm »
Maybe a factory production device? For example Ricoh has this dc/dc (SMD code ending at 3q)
3Q   R1210N231A   Ric   SOT-23-5   PWM step-up, 2.3V, 35..100kHz
Found via this SMD markings code site: http://www.smdmarkingcodes.com/Index/search?p=2&xuanze=1&markingcode=3q&baohan=2&fenzuan=0
Offline thm_w
  • Non-expert
« Reply #3 on: May 30, 2022, 09:14:12 pm »
It looks like they use a 4 digit code: https://pdf1.alldatasheet.com/datasheet-pdf/view/216239/RICOH/R1210N231A.html
But there are so many datasheets that don't even mention a package marking at all. Or custom code for automotive, who knows.
Offline manu
« Reply #4 on: June 01, 2022, 07:08:47 am »
Hello,
I read from the original tweet that the ic could be identified. But, for my curiosity, what is the part number?
Offline thm_w
  • Non-expert
« Reply #5 on: June 01, 2022, 09:41:31 pm »
Hello,
They did not say it could be identified, just "figured it out" with Daves help, so presumably what replacement part could be installed.
