Hi guys,
I just bought this device: the DPM8608-RF
I was wondering if you other owners have the same problems like me:
When turning on the device, the output is always short-circuited for a few seconds, during the boot-process (when the fan runs for a few seconds).
With the "Fast-speed discharging" function enabled, the output is short-circuited in the idle state (output off) continually.
This does not happen when the "Fast-speed discharging" function is disabled.
Only when the output is switched on (press OK), the output gives power like you would expect and there is no short circuit of course.
In both cases the charger is supplied by an external power supply and is switched on.
Secondly there are extremely high inrush currents on the input and output.It happens when connecting the charger to a power supply in the input side, when the power-switch is in the on-state. Also the device reboots every 2 seconds when the power supply is connected from a powerless state, and the power-switch was already in the on-state.It also happens when connecting a battery to the output.
Please watch my videos as proof, by clicking on the following links:
1. "Fast-speed discharging" function enabled: https://photos.app.goo.gl/2Rjre5GXnTh81FZY8
You see a 18650 battery connected to the output of the device. I connected a little motor as a reference to visualize the short-circuit. When I turn on the device in de idle-state (no power on output), you see the motor turning, because it is fed by the battery in the closed loop. This is because the output is short-circuited.
2. "Fast-speed discharging" function disabled: https://photos.app.goo.gl/caLsksMpYfHZzR2r6
When powering on the deice, the motor is running for a few seconds and is fed by the battery in the closed loop. Again, this is because the output is short-circuited.
