Author Topic: EEVblog #1283- What is Mains Ripple Injection?  (Read 5818 times)
Offline EEVblogTopic starter
« on: February 04, 2020, 10:43:24 pm »
A mystery bunker item teardown turned out to be a very interesting and obscure bit of test kit.
Subscribe: http://www.eevblog.tv
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
Re: EEVblog #1283- What is Mains Ripple Injection?
« Reply #1 on: February 05, 2020, 02:58:52 am »
We  have  something like    that here in  Florida ( not like that  Aussie  country  8) 8))  where   my   power  provider  Florida  Power and Light shuts  down high  power  energy devices  like   water heaters  and air conditioners  during    high  demand periods  , for   reduced  prices   on the kiilowatt  hour.   We  have a control  box that F.P.L   shuts  down high demand   240 volt  appliances  either by  like what you   show in this video  with  ripple  injection or  the 4G  network
« Last Edit: February 05, 2020, 03:02:59 am by johnlsenchak »
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #2 on: February 05, 2020, 04:11:12 am »
In Sydney, the 'zell' found your old fusebox is a throwback to when Prospect County Council monopolised the supply of electricity. The zells were supplied to PCC and installed in residential meter boxes along with two meters, a general rate and the off-peak rate which was activated by the zell, through a hard non fused hot water isolation switch which was separate to the one marked main switch(!), fed through a regular old ceramic fuse and then it went off toward your hot water tank.
When your hot water tank died, a new 315 litre tank would take up to 48 hours to supply hot water, so plumbers used to unceremoniously cut the county council security tags running through the screws on the zell and flick to switch to on so the tank would start heating immediately. The next off-peak signal cycle would cause the zell to just act as normal. From about '92? onwards the zell supplied was a new and improved model. With this one, you could flick the breaker switch inside the zell all you like but the thing would turn off again after about 20 minutes. Fuckers!
Commercial premises had a similar arrangement in that while there was no zell, there were separate meters for Process Heat. There were different rates offered and it was intended for kitchens with deep fryers and big ovens. Hand dryers in the dunnies were permitted also if I remember correctly.
The other annoyance with zells was if a lightning strike killed the zell, your tank could take a day or two before you realised the heater wasn't working. You'd ring your electrician, who would come out only to tell you the zell needs changing. So then, you'd have to contact the govt-run Prospect CC and ask them nicely if they could kindly replace the zell at their convenience any time in the following fortnight. Maddening. Some later HWT's had booster elements in the top connected to general rate, and when the zell quietly shit itself, your power bill skyrocketed.
Off peak signal injection has played havoc on audio equipment from the early '70s with early transistor amps and rudimentary power supplies. You'd hear that 1050hz sound all the time. The valve gear that I had didn't seem to pick up as much or maybe I didn't notice it.
This annoying signal still plagues Sydneysiders to this day as it causes LED downlights to 'dip' and speed controlled fan motors to be affected. Whilst I have systematically gone through my place and replaced or filtered audio gear that picks it up, my air-con fan sounds like darth vader at times during the night.
I saw a vid once of a car sized signal mechanical injector at a power plant. I'll see if I can find it.
« Last Edit: February 05, 2020, 04:12:58 am by Ed.Kloonk »
iratus parum formica
Offline jancelot
« Reply #3 on: February 05, 2020, 03:34:27 pm »
I guess it can cause vibrations on electric motors.
Online Kleinstein
« Reply #4 on: February 05, 2020, 04:15:41 pm »
The extra frequency could effect some not so well designed zero crossing detection used in some motor controls or clocks.
Some motors also directly can work like a speaker - so one might hear some of the frequencies.
Offline schmitt trigger
  • Country: mx
« Reply #5 on: February 05, 2020, 04:19:16 pm »
I believe I saw that one too. It is a multipole generator driven by a synchronous motor. The generator has many poles. to generate an output frequency several times that of the mains.
Offline sibeen
« Reply #6 on: February 05, 2020, 11:18:53 pm »
I began working on large UPS systems for a manufacturer in Melbourne 1987. About 6 months into the job I'd flown up to Brisbane to commission a 400 or 500 kVA unit. In those days commissioning could take a week or two with lots of 'on the fly' changes being made to the UPS. All the control boards were full of resistors on stands and I'd carry around a booklet with every 1/4 watt resistor value and spend a week or two taking measurements and changing resistors to suit local requirements etc.
I still vividly remember looking at the mains waveform when this weird ripple superimposed itself upon the 50 Hz. I did a WTF is that in response and very luckily had a senior engineer with me who casually leaned across, had a look, and told me it was just a Zellwegger tone. He then explained what it was for and all was right in the world. I took one look at Dave's box at the start of the video and knew exactly what it was going to be :)
The following users thanked this post: Ed.Kloonk
  • Country: mx
« Reply #7 on: February 06, 2020, 03:36:15 am »
The following users thanked this post: Ed.Kloonk, SeanB, SilverSolder
Offline Shonky
« Reply #8 on: February 10, 2020, 04:25:10 am »
Dave,
Interested in offloading this? I am developing a Decabit decoder, so this could be quite useful for testing.
« Reply #9 on: February 10, 2020, 04:53:53 am »
Sure, send me an email.
Offline f4eru
    • Chargehanger
« Reply #10 on: February 10, 2020, 01:56:15 pm »
Capturing this transmissions
 is the perfect use case for puttinc to use the pass/fail  waveform triggering feature of modern scopes
Offline Chalky
« Reply #11 on: February 10, 2020, 07:12:13 pm »
In NZ I think we called them Ripplay aka Ripple Relay.  https://www.hotwatercylinders.nz/blog/what-is-ripple-control/
Offline Ed.Kloonk
« Reply #12 on: July 19, 2020, 10:41:01 am »
Offline Ed.Kloonk
« Reply #13 on: July 19, 2020, 10:43:21 am »
30kW 50 Hz motor injecting 1050 Hz ripple
Offline SilverSolder
« Reply #14 on: July 19, 2020, 12:42:06 pm »
Got to love the data transmission at 0.1 Baud or something!  :D
