Author Topic: EEVBlog #465 - LED LCD panel teardown  (Read 25721 times)
Online tom66Topic starter
Re: EEVBlog #465 - LED LCD panel teardown
« Reply #25 on: May 02, 2013, 08:24:15 pm »
If you hook CCFLs to a flouroscent tube ballast, the result will be an explosion of glass from the CFL.
Offline M0BSW
  • Left this site 2013, they will not delete it ????
« Reply #26 on: May 03, 2013, 06:16:37 am »
 I won't be doing that then, perhaps no point in keeping them.
no one would or will tell me how to delete this account
« Reply #27 on: May 03, 2013, 03:02:48 pm »
They will work on battery powered inverters though, like the ones you get in camping lanterns.
Offline M0BSW
« Reply #28 on: May 05, 2013, 09:31:52 am »
That's a nice idea sean, something to play with on a rainy day. cheers
Paul
« Reply #29 on: May 05, 2013, 09:37:02 am »
Any lamp inverter that has a sinlge wire to the lamp will drive them, or you can use the power blocks for EL wire as well.
Online amyk
« Reply #30 on: May 05, 2013, 10:13:51 am »
Inverters are also sold with CCFLs intended for PC case lighting (no idea why anyone would want to add EMI next to their sensitive electronics...)
http://www.amazon.com/12-Cold-Cathode-Case-Lights/dp/B000BUDHOA/
Offline Dexmind
  • Country: id
« Reply #31 on: August 12, 2018, 03:42:51 pm »
Thanks for the video.i learn a lot from that :) .
I have problem if someone can help.i cracked my screen wire trace inside glass.how i fix connect again that wire? Where location i can do jumper wire? Thanks a lot before :D
Offline jakeisprobably
    • Upcycle Electronics
« Reply #32 on: February 08, 2019, 08:33:43 pm »
What is the purpose of these trace shapes and routing?
(From the video ar 23:11)
