Author Topic: Connecting u-current Gold to Micro  (Read 1668 times)
Offline satyaeee247@gmail.comTopic starter
« on: January 08, 2023, 12:14:02 pm »
Hi Everyone,
I am new to this forum.
I am currently working on u-current measurement and came across your youtube video of Dave.
I would appreciate it anyone could help with the few queries I have.
How do you hook up u-Current gold to a microcontroller for sensing positive and negative voltages ?
Please check the Schematic I made in the image
1. Can I directly connect +2.5v and -2.5V without battery ?
2. Should I connect the negative (DC_VOUT-) to the ground of the board ?
3. Is this correct way of measuring positive and negative voltages, If this is the case Micro cannot take voltages less than 0V, is there a way around it ?
I would appreciate it if you could answer these questions.
