Author Topic: EEVblog #1138 - Systron Donner Counter Teardown  (Read 5203 times)
Online EEVblogTopic starter
« on: October 23, 2018, 09:42:15 pm »
Teardown Tuesday
An early 1970's Australian made Systron Donner Nixie tube display counter/timer.
The following users thanked this post: boB
Offline N2IXK
Re: EEVblog #1138 - Systron Donner Counter Teardown
« Reply #1 on: October 23, 2018, 10:44:06 pm »
Nice!  If you take the "recycle time" control off the "infinity" setting, the gate should run repeatedly without manual reset....
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
« Reply #2 on: October 23, 2018, 11:29:09 pm »
To think, if  Dave didn't take this unit out of the dumpster, all that gold would have ended  up in a  landfill
 How much  money in gold do you think those boards  have on them  when  it  comes to the Aussie  dollar?
Good day mate
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Offline richnormand
« Reply #3 on: October 24, 2018, 02:09:39 am »
Unless you have the remote set in the back (my 6054B is like that).
Also the oven ref will not respond to adjustments until an hour or so while it stabilize. You also need a pretty long screwdriver to reach the adjustment pot that is surrounded with foam.
Extender boards are most likely for board adjustments that are unreachable when fully inserted.
EDIT:
Looks like I was wrong. Dave has a different OCXO than I have.
See post #8 here
https://www.eevblog.com/forum/blog/eevblog-1139-tcxo-oven-oscillator-repair/
« Last Edit: October 25, 2018, 08:55:42 pm by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
« Reply #4 on: October 24, 2018, 03:25:19 am »
Yes, but it's not very usable. The fast mode is completely unusable, you never get a displayed reading long enough to read it, and the slow mode is agonisingly slow to auto-refresh.
Offline Dr. Frank
« Reply #5 on: October 24, 2018, 01:40:09 pm »
Very nice tear down and functionality check.
The time base selector has a 10 nsec setting, therefore I assume the internal time-base PCB to deliver 100MHz, not only 10MHz.
The circuit contains a rather simple 10MHz oscillator on the right, but there's that MC3060, which might be an ECL dual FF, similar to 74H74, so inside that metal can part might be an ECL PLL circuit (int and ext) to 100MHz.
There's also that -5.2V supply, which indicates more fast ECL ICs inside the counter.
So maybe the inputs work up to 100MHz also.
Obviously they use two distinct mains transformers, one permanently operating for the OCXO, and the bigger one, switched, for the counter itself.
I also ponder about these both osc. inputs on the rear, ext./int Time Base and STD Freq Input, where to feed the OCXO 10MHz in. I did not catch your description in the video correctly..
Anyhow, that TTL grave reminds me of my own counter build in the 70 ties, but already with the higher integrated Mostek MK50398 counter / latch / display driver and 7 segment LED.
It had a 7th digit, for > 10MHz counting, and a period mode also, to get higher resolution for low frequencies, by dividing either input frequency, or time base / gate time.
That's obviously also provided on the Systron Donner counter, when you use B-input and period mode.
Frank
« Last Edit: October 24, 2018, 01:57:03 pm by Dr. Frank »
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: October 24, 2018, 02:28:19 pm »
Lots of classic logic!
Just one thing: I'm disappointed you didn't do something Lucas-related for number 1138! :D
Seven Transistor Labs, LLC
Online edpalmer42
« Reply #7 on: October 24, 2018, 04:43:08 pm »
I've worked with old counters that have a Recycle Time control.  It's a pot.  Turn it clockwise and the display hold time decreases.  Adjust it to a convenient setting.  Looks like the fast and slow switch gives you two speed ranges.  Doesn't this one work like that?
Offline tchicago
« Reply #8 on: October 24, 2018, 05:29:36 pm »
A mix of DTL, TTL and ECL logic. DTL did not need much of decoupling capacitors as it has a "soft" switching. TTL did need them as the TTL logic gates have current consumption spikes when the gate state is switched. That is due to both high and low output transistors being partially open during the transition.
Offline bitwelder
« Reply #9 on: October 24, 2018, 07:50:27 pm »
I hope Dave will use this beauty next time he needs to pick a giveaway winner.  :-+
Offline SilverSolder
« Reply #10 on: October 25, 2018, 12:16:54 am »
Love the smell of leaded solder in the morning!
There is something deeply cool about Nixie tubes (any light emitting gas discharge technology actually!).
