Same snap, made from plated steel on the disposable ones ( will last more than the shelf life when sterile and sealed away from oxygen) and the clip on the leads is made from 316l stainless, including the little spring wire clip used to grip the stud. The little cheap kits you buy at the haberdashery are perfect to make them, just use a small patch of wide self adhesive bandage ( and accept the burn on removal) with a small circle of cotton cloth and some KY jelly as conductor on the skin side, with the stud part through the bandage and cotton, riveted with the kit mandrel.
