Author Topic: New web site!  (Read 75115 times)
Offline EEVblog
Re: New web site!
« Reply #175 on: February 07, 2016, 10:43:58 am »
I figured out what classes I messed up with yesterday. Can confirm that I'm able to get the dropdowns working aswell! Guess, I'll set up a test environment sometime soon and get cracking?
If you have a theme I can just install then it's easy to do an A/B switch and test it live and see what people think.
I wouldn't want to make any changes without using a proper theme.
Offline makerimages
  • Country: ee
Re: New web site!
« Reply #176 on: February 07, 2016, 11:22:47 am »
No theme yet, as I'd have to build that first :D. There is a way, however to do the theme development on the eevblog live system - clone the default theme into a new one, but not set the new one as default during development, therefore people who want to test it, would have to manually change their theme from their settings page, any any1 else would still get the default. Once done, the new theme could then be set as the default for everyone.
Offline Dave
  • Country: si
  • I like to measure things.
Re: New web site!
« Reply #177 on: February 07, 2016, 11:49:42 am »
« Last Edit: February 07, 2016, 12:53:30 pm by Dave »
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline EEVblog
Re: New web site!
« Reply #178 on: February 07, 2016, 12:00:53 pm »
Should be possible to install SMF locally and simply clone the Curve theme and modify and save as a new one?
Offline EEVblog
Re: New web site!
« Reply #179 on: February 07, 2016, 12:02:56 pm »
Why not use the same theme as the main server? What am I missing here?
One uses Wordpress, the other uses Simple Machines forum. Entirely different programs, they don't share the same themes.
To make the forum look similar to the website it all has to be done manually, every little thing needs to be edited to look the same.
Offline makerimages
  • Country: ee
Re: New web site!
« Reply #180 on: February 07, 2016, 01:09:56 pm »
should be. I'll try that, XAMPP's been acting weird.. will try in the evening(GMT+2)
Offline drussell
  • Hardcore Geek
Re: New web site!
« Reply #181 on: February 07, 2016, 02:20:33 pm »
Or disintegrating. That bloody image makes my eyes go squiffy, just like the RS image.
Fortunately it takes all of 10s in AdBlock Plus to remove the offending image, and all is well.
Lol, that's exactly what I did.  Adblock Plus' filtering to the rescue once again....
If we don't get a choice in theme, at least I can still block that nasty, noisy, distracting image at this end.  :)
Since I only ever visit the forum part of the website directly, I hadn't noticed how horrible it looks until now.
Offline makerimages
  • Country: ee
Re: New web site!
« Reply #182 on: February 07, 2016, 02:29:51 pm »
A question: how many of you actually use the collapse arrow top-right?
It's an ugly image and servers next to no purpouse. I'd personally remove it, but if any1 finds it useful, I'll just change it to a sharper one.
Offline tggzzz
Re: New web site!
« Reply #183 on: February 07, 2016, 03:11:24 pm »
Only unwittingly, and then had to ask how to recover :(
I hate light text on a slightly darker background, in a small font. Classic example is supermarket pasta, where there's one piece of information you need: the cooking time. Of course it is on the back, writ small, in uncontrasting colours. Yes Sainsburys, I'm thinking of you.
Make it more obvious, preferably with some text so we don't have to guess what it might or might not mean.
Offline tggzzz
Re: New web site!
« Reply #184 on: February 07, 2016, 03:17:31 pm »
Don't bother. We're not here for the "branding experience".
You aren't peddling Snickers/Marathon ( https://en.wikipedia.org/wiki/Snickers ) nor Jif/Cif ( http://www.telegraph.co.uk/comment/4257582/Jif-a-suitable-case-for-treatment.html ).
Resist the opportunity to donate to "branding executives' " pensions :)
Online ataradov
    • Personal site
Re: New web site!
« Reply #185 on: February 07, 2016, 07:28:18 pm »
I do and keep it collapsed all the time. Otherwise actual content starts below the first screen. That's a lot of scrolling and looking at the same static (and mostly useless) information every time.
Alex
Offline rrinker
Re: New web site!
« Reply #186 on: February 07, 2016, 09:10:56 pm »
 Ha, never even noticed that until I read this. I've given up on computer displays less than 1080 high so the difference in space makes no real difference to me. I even (at my own expense) replaced the LCD in my work laptop with the higher res model because it was too darn small.
Online ataradov
    • Personal site
Re: New web site!
« Reply #187 on: February 07, 2016, 11:01:33 pm »
You probably have a fast Internet connection as well, so you won't mind if each page refresh came with a 1 MB picture of a kitten?
Simply because you have resource, does not mean you need to waste it. Won't you like to see more useful information on your upgraded monitor? Is not upgrade just to see the same amount as you used to is a sign of bloat?
Alex
Offline EEVblog
Re: New web site!
« Reply #188 on: February 07, 2016, 11:59:18 pm »
What's the problem?
The forum is using the same 95% screen width utilisation setting it always has for the last 5 years. Nothing has changed.
Online ataradov
    • Personal site
Re: New web site!
« Reply #189 on: February 08, 2016, 12:01:47 am »
What's the problem?
No new problems here.
This discussion is about that big collapsible header on top of each page. As long as it stays this way, we are OK.
Alex
Offline rrinker
Re: New web site!
« Reply #190 on: February 08, 2016, 01:27:45 am »
 Maybe we're not talking about the same thing - when I click that arrow in the upper right, the header collapses by one bold font line that says "Hello <username>" and 3 normal text lines with 2 links to unread and new replies and the third line is the date and time. And a slight amount of white space.
 Hmm, let me see what happens in another browser. Nope, same thing in Chrome. Maybe it's because I use adblock and I don't see the huge ad at the top.
Online ataradov
    • Personal site
Re: New web site!
« Reply #191 on: February 08, 2016, 08:07:50 am »
one bold font line ... and 3 normal text lines ...  And a slight amount of white space.
We are talking about the same thing. I know my username already. None of this information is particularly interesting and extra space is annoying.
So I keep this thing collapsed all the time.
Ideally, I'd like to read the entire forum in print mode all the time. Just the useful information and no extra junk.
Alex
Offline PlainName
  • Country: va
Re: New web site!
« Reply #192 on: February 08, 2016, 12:06:20 pm »
That can be useful info - if it doesn't appear you are not logged in, and maybe if it says someone else you should be a bit circumspect.
Offline rrinker
Re: New web site!
« Reply #193 on: February 08, 2016, 12:58:58 pm »
 Oh I'm all for simplifying things with short or non-existent CSS and a nice plain well-formatted text layout. I hate HTML emails. Yes, I'm one of those old "get off my lawn" kind of guys I guess - I am not a huge fan of how HTML has become the medium of delivery for all sorts of content including video now. It's like computers - ever notice that even the latest servers with quad 10 core CPUs take just as long to boot as an old original IBM PC XT? The internet is like that - you get a faster connection but it takes just as long to load a page as id did under dialup because the page has a zillion graphical elements and what would be a 1K text file in notepad is a 50MB HTML.
 Heck my first computer had a whopping 91 instructions. I STILL remember most of them, but a modern processor? Forget ever programming it in assembly. x86 has more than 91 instructions just to add two numbers.
Offline Bud
Re: New web site!
« Reply #194 on: February 08, 2016, 06:57:12 pm »
Are we safe from the latest TeslaCrypt ransomeware Wordpress vulnerability that encrypts user data and which i am reading all over the Net?
Offline wmtdanimal
Re: New web site!
« Reply #195 on: February 18, 2016, 01:07:07 am »
Current website performance audit:
Minimize cookie side currently 57kb
Width and height of images not defined:Slows down rendering speed:
index.php (2 uses)
index.php (7 uses)
index.php
index.php (2 uses)
index.php
index.php
index.php
index.php
index.php
index.php (3 uses)
index.php
index.php
index.php
index.php
index.php
index.php
/forum/avatars/Periodic Table/60neodymium.png
Scripts:
Two inline script blocks were found in the head between an external CSS file and another resource. To allow parallel downloading, move the inline script before the external CSS file, or after the next resource.
CSS in the document body adversely impacts rendering performance.
Link node editor.css should be moved to the document head in www.eevblog.com/
635 rules (80%) of CSS not used by the current page.
: 100%
#MathJax_Zoom
#MathJax_ZoomOverlay
#MathJax_ZoomFrame
#MathJax_ZoomEventTrap
: 100%
#supplyframe
#supplyframe a
#supplyframe table
#supplyframe table tr
#supplyframe td
#supplyframe .logo-pdf
#supplyframe .ad-pdf
#supplyframe .logo img
#supplyframe .ad-copy
#supplyframe .sf-part
#supplyframe a.ad-copy-link
#supplyframe a .ad-description
#supplyframe .ad-cta
#supplyframe .ad-button1
: 100%
.MathJax_Hover_Frame
.MathJax_Menu_Button .MathJax_Hover_Arrow
.MathJax_Menu_Button .MathJax_Hover_Arrow span
.MathJax_Hover_Arrow:hover
.MathJax_Hover_Arrow:hover span
: 100%
#MathJax_About
#MathJax_About.MathJax_MousePost
.MathJax_Menu
.MathJax_MenuItem
.MathJax_MenuArrow
.MathJax_MenuActive .MathJax_MenuArrow
.MathJax_MenuArrow.RTL
.MathJax_MenuCheck
.MathJax_MenuCheck.RTL
.MathJax_MenuRadioCheck
.MathJax_MenuRadioCheck.RTL
.MathJax_MenuLabel
.MathJax_MenuRule
.MathJax_MenuDisabled
.MathJax_MenuActive
.MathJax_MenuDisabled:focus, .MathJax_MenuLabel:focus
.MathJax_ContextMenu:focus
.MathJax_ContextMenu .MathJax_MenuItem:focus
#MathJax_AboutClose
.MathJax_Menu .MathJax_MenuClose
.MathJax_MenuClose
.MathJax_MenuClose span
.MathJax_MenuClose:hover
.MathJax_MenuClose:hover span
.MathJax_MenuClose:hover:focus
: 100%
.MathJax_Preview .MJXf-math
: 50%
.MJX_Assistive_MathML.MJX_Assistive_MathML_Block
: 71%
.MathJax_Display
.MathJax .merror
.MathJax .MJX-monospace
.MathJax .MJX-sans-serif
#MathJax_Tooltip
img.MathJax_strut
.MathJax img
.MathJax_Processing
.MathJax_Processed
.MathJax_ExBox
.MathJax .MathJax_EmBox
.MathJax .MathJax_HitBox
.MathJax .MathJax_HitBox *
#MathJax_Tooltip *
.MathJax .noError
: 50%
#MathJax_MSIE_Frame
.MathJax_Error
: 100%
.MJXp-script
.MJXp-right
.MJXp-bold
.MJXp-italic
.MJXp-scr
.MJXp-frak
.MJXp-sf
.MJXp-cal
.MJXp-mono
.MJXp-largeop
.MJXp-largeop.MJXp-int
.MJXp-math
.MJXp-display
.MJXp-math span
.MJXp-box
.MJXp-box:after
.MJXp-rule
.MJXp-char
.MJXp-mo
.MJXp-mfrac
.MJXp-denom
.MJXp-denom > *
.MJXp-surd
.MJXp-surd > *
.MJXp-script-box > *
.MJXp-script-box > * > *
.MJXp-script-box > *:last-child > *
.MJXp-script-box > * > * > *
.MJXp-mphantom
.MJXp-munderover
.MJXp-over
.MJXp-over > *
.MJXp-munderover > *
.MJXp-mtable
.MJXp-mtable > *
.MJXp-mtr
.MJXp-mtd
.MJXp-mtr > .MJXp-mtd:first-child
.MJXp-mtr:first-child > .MJXp-mtd
.MJXp-mlabeledtr
.MJXp-mlabeledtr > .MJXp-mtd:first-child
.MJXp-mlabeledtr:first-child > .MJXp-mtd
.MJXp-merror
.MJXp-scale0
.MJXp-scale1
.MJXp-scale2
.MJXp-scale3
.MJXp-scale4
.MJXp-scale5
.MJXp-scale6
.MJXp-scale7
.MJXp-scale8
.MJXp-scale9
.MathJax_PHTML .noError
index.css:
78%
body#help_popup
h3.catbg input.input_check
input[disabled].input_text
fieldset
fieldset legend
.underline
.flow_auto
.clear_right
.largetext
.centertext
.lefttext
.double_height
.padding
code.bbc_code
.codeoperation
.bbc_size
.bbc_color a
.bbc_img
.bbc_table
.bbc_table td
.bbc_u
.bbc_list
.bbc_tt
.help
.meaction
.highlight
.highlight2
.titlebg,.titlebg2,tr.titlebg th,tr.titlebg td,tr.titlebg2 td
tr.titlebg th,tr.titlebg2 th,td.titlebg,td.titlebg2,tr.catbg th,tr.catbg2 th,td.catbg,td.catbg2
tr.titlebg th a:link,tr.titlebg th a:visited,tr.titlebg2 td a:link,tr.titlebg2 td a:visited
tr.catbg th a:link,tr.catbg th a:visited,tr.catbg2 td a:link,tr.catbg2 td a:visited
.catbg select
.windowbg3
.pagesection
div.pagesection div.floatright input
.pagelinks
.approvebg
.approvebg2
.approvetbg
.approvetbg2
.stickybg
.stickybg2
.lockedbg
.lockedbg2
.signature,.attachments
.custom_fields_above_signature
.alert
.birthday
.event
.holiday
.warn_mute
.warn_moderate
.warn_watch,.success
a.moderation_link,a.moderation_link:visited
.openid_login
.description,.description_board,.plainbox
.description_board
.information p
p.para2
#ajax_in_progress
#ajax_in_progress a
dl.settings
dl.settings dt
dl.settings dt.settings_title
dl.settings dt.windowbg
dl.settings dd
dl.settings img
dl.settings dt a img
h3.catbg2 a,h3.catbg2
h3.catbg a:hover,h4.catbg a:hover,.table_list tbody.header td a:hover
h3.catbg2 a:hover
h3.titlebg a,h3.titlebg,h4.titlebg,h4.titlebg a
h3.titlebg a:hover,h4.titlebg a:hover
h3.catbg img.icon,h4.titlebg img.icon
h4.catbg a.toggle img
h4.titlebg,h3.titlebg
h4.titlebg img.icon
div.title_bar
div.roundframe div.cat_bar
div.roundframe div.cat_bar h3.catbg
div.title_barIC
div.title_barIC h4.titlebg
#upshrinkHeaderIC p.pminfo
img#upshrink_ic,img#newsupshrink
table.table_list a.unreadlink,table.table_list a.collapse
.table_grid tr.catbg,.table_grid tr.titlebg
.table_grid tr.catbg th,.table_grid tr.titlebg th
tr.catbg th.first_th
tr.catbg th.last_th
tr.titlebg th.first_th
tr.titlebg th.last_th
.table_grid th.last_th input
.table_grid th.lefttext
table.table_grid
table.table_grid td
.additional_row
table.table_grid thead tr.catbg th
#permissions table.table_grid td
.approvebg span.topslice
.approvebg span.topslice span
.approvebg span.botslice
.approvebg span.botslice span
.postbg
.content p
.auto_suggest_div
.auto_suggest_item
.auto_suggest_item_hover
.dropmenu li ul ul
.dropmenu li:hover ul ul,.dropmenu li:hover ul ul ul
.dropmenu li li:hover ul
.dropmenu li li.additional_items
#menu_toggle
#menu_toggle span
.buttonlist ul
.buttonlist ul li
.buttonlist ul li a
.buttonlist ul li a:hover
.buttonlist ul li a span
.buttonlist ul li a:hover span
.buttonlist ul li a.active
.buttonlist ul li a.active span
.buttonlist ul li a.active:hover
.align_top ul li a,.align_bottom ul li a
ul#navigation
ul#navigation li
#adm_submenus
img#smflogo
#guest_form
#guest_form .info
div#upper_section div.user p
div#upper_section div.news p
select.qaction,input.qaction
#mlist table tbody td.windowbg2
table.table_list
table.table_list p
table.table_list td,table.table_list th
table.table_list tbody.header td
table.table_list tbody.content td.stats
table.table_list tbody.content td.lastpost
table.table_list tbody.content td.icon
.table_list tbody.content td.info a.subject
.table_list tbody.content td.children
p.moderators
#boardindex_table .table_list thead,#boardindex_table .table_list tfoot
#posting_icons
#posting_icons ul
#posting_icons img
#postbuttons_upper ul li a span
.nextlinks
.nextlinks_bottom
.mark_read
#newsfader
#smfFadeScroller
#upshrinkHeaderIC
dl#ic_recentposts
dl#ic_recentposts dt
dl#ic_recentposts dd
#upshrinkHeaderIC p
#upshrinkHeaderIC p.last
#upshrinkHeaderIC p.inline
#upshrinkHeaderIC p.stats
form#ic_login
form#ic_login ul li
form#ic_login ul li label
#index_common_stats
img.new_posts
div.table_frame .table_list
.table_frame .table_list td.icon,.table_frame .table_list td.info,.table_frame .table_list td.stats
#messageindex
.childboards
#childboards h3
#childboards .table_list thead
.lastpost img
#postbuttons div.buttons
#postbuttons div.middletext
#postbuttons span
#postbuttons span.lower
#postbuttons .buttonlist
#postbuttons #pagelinks
#moderationbuttons
.linked_events
.edit_event
#poll
#poll .content
h4#pollquestion
#poll_options ul.options
#poll_options div.submitbutton
#poll_options dl.options
#poll_options dl.options dt
#poll_options dl.options .voted
#poll_options dl.options dd
#poll_options dl.options .percentage
#poll_options p
div#pollmoderation
#forumposts
#forumposts .cat_bar
#forumposts h3 span#author
#forumposts h3 img
#forumposts h3.catbg
p#whoisviewing
.post_wrapper
.poster
.postarea,.moderatorbar
.postarea div.flow_hidden
.moderatorbar
.poster h4,.poster ul
.poster h4
.poster h4,.poster h4 a
.poster ul ul
.poster ul ul li
.poster li.stars,.poster li.avatar,.poster li.blurb,li.postcount,li.im_icons ul
.poster li.avatar
.poster li.warning
.poster li.warning a img
.messageicon
.messageicon img
.keyinfo
.modifybutton
div.quickbuttons_wrap
ul.quickbuttons li.remove_button
ul.quickbuttons li.modify_button
ul.quickbuttons li.approve_button
ul.quickbuttons li.restore_button
ul.quickbuttons li.split_button
ul.quickbuttons li.reply_button
ul.quickbuttons li.reply_all_button
ul.quickbuttons li.notify_button
ul.quickbuttons li.inline_mod_check
.inner
#forumposts .modified
#forumposts .reportlinks
#forumposts .signature,.post .signature
#forumposts span.botslice
.attachments hr
.attachments
.attachments div
#quickreplybox
#quickReplyOptions .roundframe
#quickReplyOptions form textarea
#display_jump_to
#forumposts .post_separator
#postAttachment3
.post_verification
.post_verification #verification_control
#post_event .roundframe
#post_event fieldset
#post_event #event_main input
#post_event #event_main div.smalltext
#post_event div.event_options
#post_event ul.event_main,ul.event_options
#post_event ul.event_main li
#post_event ul.event_options
#post_event ul.event_options li
#post_event #event_main select,#post_event ul.event_options li select,#post_event ul.event_options li .input_check
#edit_poll
#edit_poll fieldset
#edit_poll fieldset input
#edit_poll ul.poll_main li
#edit_poll ul.poll_main input
#edit_poll ul.poll_main,dl.poll_options
#edit_poll dl.poll_options dt
#edit_poll dl.poll_options dd
#edit_poll dl.poll_options dd input
#readbuttons_top .pagelinks,#readbuttons .pagelinks
#move_topic dl
#move_topic dl.settings dt
#move_topic dl.settings dd
.move_topic
div.move_topic fieldset
fieldset.send_topic
dl.send_topic
dl.send_mail dt
dl.send_mail dd
#report_topic dl
#report_topic dl.settings dt
#report_topic dl.settings dd
div#selected,div#not_selected
ul.split_messages li.windowbg,ul.split_messages li.windowbg2
ul.split_messages li a.split_icon
ul.split_messages div.post
ul.merge_topics li
dl.merge_topic dt
dl.merge_topic dd
fieldset.merge_options
.custom_subject
.login
.login dl
.login dt,.login dd
.login dt
.login dd
.login p
.register_error
.register_error span
dl.register_form
dl.register_form dt
dl.register_form dt strong
dl.register_form dt span
dl.register_form dd
#confirm_buttons
.coppa_contact
.valid_input
.invalid_input
#maintenance_mode
#maintenance_mode img.floatleft
h3.titlebg img
tr.titlebg td
#admin_menu
#admin_content
#admin_content .custom_field
#admin_login .centertext
#admin_login .centertext .error
.left_admmenu,.left_admmenu ul,.left_admmenu li
#left_admsection
.adm_section h4.titlebg
#main_container
.left_admmenu li
.left_admmenu
#main_admsection
tr.windowbg td,tr.windowbg2 td,tr.approvebg td,tr.highlight2 td
#credits p
.topic_table table
.topic_table .icon1,.topic_table .icon2,.topic_table .stats
#topic_icons
#topic_icons .description
.topic_table table thead
.topic_table td
.topic_table td.subject p,.topic_table td.stats
.topic_table td.lastpost
.topic_table td.stickybg2
.topic_table td.lockedbg2
.topic_table td.locked_sticky2
#fatal_error
.errorbox h3
.errorbox p
.errorbox p.alert
#basicinfo
#basicinfo .windowbg .content
#detailedinfo2
#ptweet
#detailedinfo
#basicinfo h4
#basicinfo h4 span.position
#basicinfo img.avatar
#basicinfo ul
#basicinfo ul li
#basicinfo span#userstatus
#basicinfo span#userstatus img
#detailedinfo div.content dl,#tracking div.content dl
#detailedinfo div.content dt,#tracking div.content dt
#detailedinfo div.content dd,#tracking div.content dd
#detailedinfo div.content dl.noborder
#detailedinfo div.content dt.clear
#detailedinfo2 div.content dl,#tracking div.content dl
#detailedinfo2 div.content dt,#tracking div.content dt
#detailedinfo2 div.content dd,#tracking div.content dd
#detailedinfo2 div.content dl.noborder
#detailedinfo2 div.content dt.clear
.signature,.custom_fields_above_signature
.signature h5
#personal_picture
#avatar_server_stored div
#avatar_upload
#main_admsection #basicinfo,#main_admsection #detailedinfo
#main_admsection #basicinfo h4
#main_admsection #basicinfo img.avatar
#main_admsection #basicinfo ul
#main_admsection #basicinfo span#userstatus
#main_admsection #basicinfo p#infolinks
#main_admsection #basicinfo .botslice
div#profile_error,div#profile_success
div#profile_error
div#profile_error span
div#profile_success
#generalstats div.content dt
#generalstats div.content dd
#activitytime
.activity_stats
.activity_stats li
.activity_stats li span
.activity_stats li.last span
.activity_stats li div.bar
.activity_stats li div.bar div
.activity_stats li div.bar span
#popularposts
#popularactivity
#popularposts div.content dt,#popularactivity div.content dt
#popularposts div.content dd,#popularactivity div.content dd
.profile_pie
.topic .time
.counter
.topic h4
.topic .post
.topic .mod_icons
#creator dl
#creator dt
#creator dd
.ignoreboards
.ignoreboards a
.ignoreboards a:hover
.ignoreboards ul
.ignoreboards li
.ignoreboards li.category
.ignoreboards li ul
.ignoreboards li.category ul li.board
#theme_settings
#theme_settings li
#paid_subscription
#paid_subscription dl.settings
#paid_subscription dl.settings dd,#paid_subscription dl.settings dt
#pick_theme
#warn_body
#statistics
#statistics div.title_bar
#statistics h3.catbg
#statistics div.content
#statistics div.top_row
#stats_left,#top_posters,#top_topics_replies,#top_topics_starter
#stats_right,#top_boards,#top_topics_views,#most_online
dl.stats
dl.stats dt
dl.stats dd
.statsbar div.bar
.statsbar div.bar div
tr.windowbg2 th.stats_month
tr.windowbg2 td.stats_day
#personal_messages h3 span#author,#personal_messages h3 span#topic_title
#personal_messages div.labels
#personal_messages .capacity_bar
#personal_messages .capacity_bar span
#personal_messages .capacity_bar span.empty
#personal_messages .capacity_bar span.filled
#personal_messages .capacity_bar span.full
#personal_messages .reportlinks
#searchLabelsExpand li
#manrules div.righttext
dl.addrules dt.floatleft
#addrule fieldset
.calendar_table
.calendar_today
#month_grid
#month_grid div.cat_bar
#month_grid h3.catbg
#month_grid table
#main_grid table
#main_grid table h3.catbg
#main_grid table.weeklist td.windowbg
#main_grid table.weeklist td.weekdays
#main_grid h3.weekly
#main_grid h3 span.floatleft,#main_grid h3 span.floatright
#main_grid table th.days
#main_grid table.weeklist h4.titlebg
#main_grid table td.weeks
#main_grid table td.days
a.modify_event
span.hidelink
#calendar_navigation
#mlist_search
#searchform,#simple_search p
#simple_search,#simple_search p,#advanced_search
#search_error
#search_term_input
#searchform fieldset
#advanced_search dl#search_options
#advanced_search dt
#advanced_search dd
#searchform p.clear
.topic_table td blockquote,.topic_table td .quoteheader
.search_results_posts
.search_results_posts .buttons
#help_container
#helpmain
#helpmain p
#helpmain ul
#headerarea
.tborder
div.contentlatest
div.contentlatest .navigate_section
div.contentlatest .navigate_section ul
div.contentlatest .navigate_section ul li
div.contentlatest .navigate_section ul li a
div.contentlatest .navigate_section ul li a span
div.contentlatest .navigate_section ul li>span
div.contentlatest>.quoteheader
div.contentlatest>.quoteheader img
div.contentlatest>.quoteheader a
div.contentlatest>blockquote.bbc_alternate_quote
div.contentlatest>blockquote.bbc_alternate_quote>.attachments
.arp_header
.arppost
.arppost:hover
.arp_left
.arp_rest
.vob_protected
.vob_protected,.vob_protected a:link,.vob_protected a:visited,.vob_protected a:hover
.buttons_tools
.buttons_tools h2
.buttons_tools h2:hover
.buttons_tools a
.buttons_tools a.custom
.buttons_tools a.tutorials
.buttons_tools a.demos
.buttons_tools a.downsl
.buttons_tools a.allt
webkit.css: 100% is not used by the current page.
table.table_list tbody.header td div.cat_bar
www.eevblog.com/: 100% is not used by the current page.
.ui-mobile [data-role="page"],.ui-mobile [data-role="dialog"],.ui-page
Use normal CSS property names instead of vendor-prefixed ones (11)
<unknown>
#MathJax_Zoom
<unknown>
<unknown>
#MathJax_About
.MathJax_Menu
.MathJax_MenuClose
<unknown>
#MathJax_Tooltip
Offline ornea
Re: New web site!
« Reply #196 on: February 18, 2016, 05:37:07 am »
I am struggling to search thru previous blogs and hoping someone can help me search for past CRO reviews, first impressions etc.
I am sure this was easier in the past, but now it seems you only get 5 previous blogs per screenful.  I thought in the past there was all the previous blogs with a brief description of each Blog.
The search feature gives me Error 404.
The "videos" drop down sub menu list is still not populated (I would remove it if it is never going to be finished)
The search forum options returns a massive number of un-related hits.
The http://www.eevblog.org/video/ is useful albeit a little too terse.
Any pointers much appreciated.
