Loading [MathJax]/extensions/Safe.js
Author Topic: CHEAP vs EXPENSIVE Home FID Workout Weight Bench Review  (Read 3423 times)
Offline EEVblogTopic starter
« on: May 22, 2022, 06:06:44 am »
Which is the better value FID adjustable home workout weight bench? A $100 ebay cheapie or a $300 Pro-Form Carbon Strength blade design name brand?
FID is Flat-Incline-Decline bench.
https://www.proform.com/strength/carbon-strength-adjustable-bench
https://www.proformfitness.com.au/product/strength/28/proform-adjustable-utility-bench/11602/details
00:00 - $100 ebay no-name Genki cheapie FID bench
05:33 - Dave's got the wobblies!
07:08 - Weight = Quality
07:37 - Pro-Form blade design FID bench
13:03 - Width matters
14:34 - No contest!
14:58 - This is a joke, right? 1.5mm tubular steel!
16:02 - Review of the Everfit / Bowflex adjustable dumbell set
https://amzn.to/3lv4bnE
18:30 - Summary - Pin design vs Blade design
Offline Shock
Re: CHEAP vs EXPENSIVE Home FID Workout Weight Bench Review
« Reply #1 on: May 22, 2022, 05:00:25 pm »
It also depends on your body (frame) size and weights. First one is rubbish, second one is a bit small for me but looks decent enough for a home jobbie. It does look a little high for you though tbh, don't want to put your legs up like you're doing pilates.
For dumbbell weights I use few adjustable sets of cheap standard weights, considerably cheaper and far less screwing around changing weights over when running multiple sets. If you shop wisely you can setup a pair of 45kg for about $200, extra sets beyond that for convenience are less as you end up with a bunch of smaller weights.
For me, more pros than cons. I do have a perfect set in mind one day, but they are hideously expensive.
« Last Edit: May 22, 2022, 05:46:05 pm by Shock »
