Hello guys, you can see for yourselfs how new my account is so I won't bother to say otherwise.
I created the account to report that on a brand new 1052e which came with the 00.04.01.00.02 firmware, you can directly update using Gizmo's file.
I copied the file after clearing off a usb drive, ejected, powered on scope, inserted drive. a few moments later it said something to the effect of 'firmware update found - same version. update?' and gave OK/Cancel.
I hit OK and it started a progress bar. I let it finish, it said success restart - I powered off, waited a moment or two then power on, started up as usual, flipped to measure and time base now goes down to 2ns.
Thanks everyone that has contributed to this.
BTW call me crazy all you want, part of me was hoping to brick this scope as I just came across one that decodes CAN bus messages directly...Oh well, better luck next time?
Lurk mode engaged.
