Author Topic: changing the rigol DS1052E to DS1102E using USB , the dummy guide  (Read 1354348 times)
Offline cicastol
Offline reqwired
Re: changing the rigol DS1052E to DS1102E using USB , the dummy guide
« Reply #276 on: November 19, 2010, 11:53:10 pm »
I bring a present to all HW ver 58 owners firmware version 02.04.01.02 (2.04 SP1). I've attached the firmware below and confirm it fixes the noise issue after self-calibration.
Firmware attached, confirmed to work with HW 58 scope can't say much else.
EDIT:
Hashes for DS1000EUpdate.RGL
CRC3: 3B44DEE5
MD5: BCF73565352391935F3A9651D30776EE
SHA-1: B2DDB481F8A71CF7037C93AF9C45CEBBE97C71A2
When I download the file then check with Hashcalc I get different numbers. I've read the past history and downloaded and checked the other firmware files with Hashcalc and gotten matching numbers. I'm just clicking the the link to download ,am I missing a step, or ??  Suggestions?   Thanks
Offline d0ss
« Reply #277 on: November 20, 2010, 12:12:57 am »
EDIT:
CRC3: 3B44DEE5
I've just downloaded and checked the file has the correct hashes, my only guess is that you calculating the hash for the 7zip file.
The file needs extracting first, I recommend 7-zip http://www.7-zip.org/.
Hashes for the 204SP1.7z are as follows;
CRC32: EAE60568
MD5: DC5DF0AF15431465C945353BC1EA830E
SHA-1: 88A31204DAA1A62B27C2DB6CAF3397B5ECC90958
Offline M84AB1
« Reply #278 on: November 20, 2010, 01:59:10 am »
EDIT:
CRC3: 3B44DEE5
I have already successfully hacked my scope with that firmware file (DS1000EUpdate.RGL) and when I read your post I went again to double check the file and it indeed showed different numbers. I then closed hashcalc, reloaded the firmware and then it was showing the correct numbers. I have now closed and reloaded the same firmware file that I used for the hack about 10-20 times and the numbers always match. I am curious why that one time the numbers didn't match. Maybe a glitch in the hashcalc software?
« Last Edit: November 20, 2010, 02:01:01 am by Nejo »
Offline reqwired
« Reply #279 on: November 20, 2010, 04:25:18 am »
CRC32: EAE60568
Thats got to be where I messed up, these are the same hash numbers I'm getting.  Thanks,Thanks
Offline EricF
« Reply #280 on: November 20, 2010, 05:58:30 pm »
Thanks people, another successful upgrade of a hardware 58 model with 2.04SP1 due to the help from this thread. Just received it yesterday from Riko instruments via Amazon. Downgraded to 2.02SP2_patched and then used shafri's program. Upgraded back to 2.04SP1. Process was a piece of cake, took about 30 minutes only because I was extremely methodical and anal about the whole thing. Really appreciate it, and highly recommend it to anyone considering it.
Thanks again!
EricF
Offline teixeluis
« Reply #281 on: November 21, 2010, 01:26:00 am »
Just to confirm that I have a scope originally shipped with firmware 2.02 SP2 (probably hacked by the supplier - dealextreme) and having serial Nr DS1ED12391xxxx, here is a photo from its back, and a photo from the SMPS which apparently doesn't have the HV supply (did the best I could to shoot it through the 3 mm hole).
lteixeira
Offline Zyvek
« Reply #282 on: November 21, 2010, 04:40:48 am »
Another successful upgrade, I received mine just yesterday from Amazon/Riko_Instruments
Firmware was 2.04 and HW=57.  SNDS1ED122XXXXXX
The Rigol wont fully replace my Tektronix 2467B, but I think it may allow me to retire the Tek2430A.
I only have a 50Mhz pulse generator (Philips PM5715) so more testing is in order..
Thanks for the info, this is fun stuff!
« Last Edit: November 22, 2010, 01:01:13 am by Zyvek »
-Z
Offline akisnas
« Reply #283 on: November 21, 2010, 08:09:24 pm »
Hi everybode, i'm trying to download this
DS1052_to_DS1102.zip : the DS1052_to_DS1102.zip is available here on Rapidshare (9Mb)
but without success can anyone help me?
"Rapidshare server is full of quotes"
I 've found the FW VERSION 00.02.04.01.02
Rigol Technologies,DS1052E,DS1ED123xxxxx,00.02.04.01.02
How to find the HW version of the scope?
Kind Regards
« Last Edit: November 21, 2010, 08:16:53 pm by akisnas »
Offline eldis
« Reply #284 on: November 22, 2010, 10:07:33 am »
Hi, I also recently bought DS1052E with firmware 2.05
Seller says, that 2.04 is discontinued. Any progress with modifying this firmware release?
Is there anything I can do to help? perhaps some JTAG dump.. HW is 58
Offline PolossatikTopic starter
« Reply #285 on: November 22, 2010, 09:36:00 pm »
Tested the zip file, works fine, must be rapidshare overload or so.
Added to the first post
* warning that currently 02.05 scopes cannot be hacked
* the way to see your HW version with a nice big fat warning to not mess around.
Real Circuit design time in minutes= (2 + Nscopes) Testim + (40 +120 Kbrewski) Nfriends
Testim = estimated time in minutes Nscopes= number of oscilloscopes present Kbrewski = linear approx of the nonlinear beer effect Nfriends = number of circuit design friends present
Offline reqwired
« Reply #286 on: November 23, 2010, 01:50:00 am »
I had trouble with the zip file also, I was using older web browser,after I installed firefox and had high speed access it downloaded fine.   Just a thought.
Offline akisnas
« Reply #287 on: November 23, 2010, 07:36:01 am »
My scope is updated, wow nice, sweet success. :-*
Oh yes the radip server was very busy. :D
Very nice tutorial for dummies :)
Thanks for all.
Kind Regards
Offline M84AB1
« Reply #288 on: November 23, 2010, 12:15:02 pm »
But didn't one of the forum users report that whilst his firmware was 02.05, the HW was actually 58. By now, we know that HW 58 scopes also came with FW 2.04 SP1 (like mine). So why cant 02.05 downgrade to 2.02 SP2, perform the hack and then upgrade to 2.04 SP1 instead of 2.05?
Unless I missed something along the lines that there is no "patched" FW to make the scope think it is higher and prompt the downgrade?
Offline Fraser
« Reply #289 on: November 23, 2010, 06:43:59 pm »
From what I have read here, it would appear that Rigol have changed the way in which the DS1052E recognises a valid firmware update package. The old method was easily fooled by changing the version number in the update package header. That technique no longer appears to work on FW2.05. The missing knowledge at the moment is how to get the DS1052E into firware update mode in order to accept 2.02SP2. I agree that FW2.05 scopes with HW58 should accept FW2.04SP1 but only after the above problem has been solved.
Offline accepttheownage
« Reply #290 on: November 23, 2010, 07:07:07 pm »
My 02.05 scope will not recognize any of the older hacked firmware. Either we somehow dump the new firmware, find out what the scope is looking for in the firmware, or wait until Rigol releases the new firmware, which probably won't happen
Offline AgeyevAV Russia
« Reply #291 on: November 24, 2010, 06:02:47 am »
Good time of the day :) What hear version HW if firmware 02.05 &
Offline Zyvek
« Reply #292 on: November 24, 2010, 06:25:52 am »
After the hack don't forget to upgrade your probes as well.
When comparing the upgraded Rigol to a bunch of older Tektronix scopes (2236, 2340A, 2445 & 2467B) I noticed a bit more detail using a Tex P6138 vs the included Rigol probes:
The 2467B image is just for reference.
« Last Edit: November 24, 2010, 06:35:21 am by Zyvek »
-Z
Offline Fraser
« Reply #293 on: November 24, 2010, 08:49:31 am »
Can you clarify which Rigol probes you received with your scope please. Mine were RP2200's that claim to be 200MHz bandwidth.
Cheers
Offline teixeluis
« Reply #294 on: November 24, 2010, 10:12:00 am »
According to the datasheet from my RP2200, these are rated to 150 MHz at 10 x attenuation.
lteixeira
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #295 on: November 24, 2010, 10:36:14 am »
good info! new aspect to tinker.
Offline Fraser
« Reply #296 on: November 24, 2010, 01:01:22 pm »
Interesting.... it appears that even rigol don't know the specification of their RP2200 probes. They are advertised as 150MHz or 200MHz bandwidth depending upon where you buy. A Google search on Rigol RP2200 can make for confusing reading  :D
Take a look here:
http://www.aidetek.com/New_products_info/Photo/RIGOL/RP2200_Manual.pdf
YET in the Rigol Catalogue (Page 6) they are clearly shown as 150MHz. The 200MHz spec may just be an error but this doesn't inspire much confidence in the specs. ;)
http://www.rlx.sk/pdf/RIGOL2010No3.pdf
Offline teixeluis
« Reply #297 on: November 24, 2010, 01:27:47 pm »
Yes. Here is the spec of my RP2200.
Offline Zyvek
« Reply #298 on: November 24, 2010, 07:54:13 pm »
Cheers
Sure thing, they are the RP2200 model.
-Z
Offline teixeluis
« Reply #299 on: November 25, 2010, 12:14:12 am »
One interesting feature in a custom firmware would be to allow direct selection of the bandwidth limit from the same CHx > BW Limit command. Instead of just enabling the 20 MHz filter, one could switch between the several hardware filters: 20 MHz, 50 MHz, 100 MHz or the entire 150 MHz vertical BW (if it is in fact the true maximum BW).
lteixeira
