Author Topic: changing the rigol DS1052E to DS1102E using USB , the dummy guide  (Read 1355934 times)
Offline user99
Re: changing the rigol DS1052E to DS1102E using USB , the dummy guide
« Reply #1275 on: April 24, 2013, 06:58:09 pm »
I flashed Gizmo's firmware to my 1052e HW 58 and I now have access to the 2ns time scale but the bandwidth still seems to be about 65MHz.
I also get screen flash while the menu is up and the fft is displayed.  I did the load factory defaults to see if it fixed the flashing but nothing changed and I'm not sure if doing that put the bandwidth back to default.
In  the last post by omegat the images look like the extra bandwidth was enabled.  Is there anything that needs to be done other than the firmware flash?
Offline bilko
« Reply #1276 on: April 24, 2013, 11:24:17 pm »
Unless something has changed, check first post in this thread
Offline user99
« Reply #1277 on: April 25, 2013, 01:07:56 am »
From what I understand the steps in post #1 are no longer needed.  see posts starting at 1200.
Offline lordvader
« Reply #1278 on: May 10, 2013, 06:39:50 am »
Hey all.
Been a long time lurker, but had a bit of a hiatus after realising my Rigol had the 3.01 firmware.
On a whim, I came back, and noticed all my problems are gone (nice !).
I've downloaded gizmo's DS1000EUpdate.rar file, but the md5 I get on it is "f39c4b0b66ad484e4ae37cc8fe66bb31".
I've download it multiple times, and get the same result. I've been using WinMd5, and also tried MD5Calculator.
Same deal each time.
Any ideas what's going on ?
(also just tried md5sum on a linux environment)
Offline mabl
« Reply #1279 on: May 12, 2013, 12:21:50 pm »
Hi lordvader,
this is a RAR compressed file. You have to extract the DS1000EUpdate.RGL first.  ;)
« Last Edit: March 13, 2019, 07:13:22 pm by mabl »
Offline lordvader
« Reply #1280 on: May 13, 2013, 01:19:31 am »
 :palm:
Thanks !
Offline staze
  • I _might_ have a problem...
    • Everybody Staze...
« Reply #1281 on: May 16, 2013, 01:47:54 am »
Just got a DS1052e from tequipment.net (rev 58), and the byte swapped firmware worked flawlessly. Did make sure to md5 and crc32 check the file before updating.
Thanks!
Anyone else think the fan is still a bit loud?
“Give a man an answer, he’ll keep his job for a day. Teach a man to Google, and he’ll be employed for a lifetime”
Offline vasonline
« Reply #1282 on: May 21, 2013, 07:03:19 pm »
On my unit (not hacked)
Purchased april 2013...It starts pretty quiet. But over the next 30 seconds it gradually speeds up.
Greetings
Offline maartenva
« Reply #1283 on: May 22, 2013, 06:32:47 pm »
I've just recieved my new Rigol DS1052E from the distributor.
SN: DSET1509.......
soft version: 00.04.00
What does this mean? New HW version?
I can confim that the firmware hack works with my version.
« Last Edit: May 22, 2013, 06:55:35 pm by maartenva »
Offline vasonline
« Reply #1284 on: May 26, 2013, 01:24:32 pm »
SN: DSET1509.......
Mine = april 2013
DS1ET15040xxxxxxxxx
Offline gandalf
« Reply #1285 on: May 27, 2013, 06:09:52 pm »
Hi All!
This is my fisrt post on EEVblog :)
I think I will apply Gizmo's firmaware to increase BW up to 100MHz after I checked that just one byte changed ;)
diff <(xxd DS1000EUpdate.RGL.mod) <(xxd DS1000EUpdate.RGL)
7574c7574
< 001d950: e501 00a8 6108 0805 1001 6089 e67d 0050  ....a.....`..}.P
> 001d950: e501 00a8 6108 0805 1009 6089 e67d 0050  ....a.....`..}.P
« Last Edit: May 28, 2013, 11:31:08 pm by gandalf »
Offline staze
« Reply #1286 on: May 30, 2013, 06:01:51 am »
Has anyone figured out the 150mhz bit flip?
Offline staze
« Reply #1287 on: May 30, 2013, 06:02:56 am »
Greetings
Yup, mine does the same. Figure I'll just replace the fan after I'm sure it won't die in early life. =) And really, it's not THAT loud now that it's up on a shelf.
Offline WakeUpWolfgang
« Reply #1288 on: June 01, 2013, 07:55:21 pm »
I would love to do this to my scope but I am having problems downloading DS1052_to_DS1102.zip. I also don't see anything telling me what to do with my scope that is software version 00.03.01
Offline mlax
« Reply #1289 on: June 16, 2013, 06:16:23 pm »
If you mod DS1052E to DS1102E, do you need to buy new probes or are the old ones OK ??
p.s: I'm sorry if it was asked already, i didn't find it
Offline staze
« Reply #1290 on: June 17, 2013, 10:19:26 pm »
No, the stock Rigol probes are good to 150-200mhz. That said, I prefer the cheap $13 chinese ones I got off eBay reviewed here: https://www.eevblog.com/forum/reviews/cheap-oscope-probe-quality/
Offline mwpeters75
« Reply #1291 on: June 22, 2013, 05:10:13 pm »
Hello everyone,
Thank-you for this thread.  My initial power up firmware version was 00.04.00.  I have done the Gizmo upgrade and received the 'updata successed, please restart' message.  I have power cycled the 1052E and when the start up banner is shown, I only see 00.04.00 listed as the version, not 00.04.01.  Is this what I should expect since earlier threads have noted a 00.04.01 firmware version.
Thanks for any guidance that can be provided,
MWP.
Offline staze
« Reply #1292 on: June 23, 2013, 08:39:52 pm »
correct, the firmware version doesn't change. if you have access to the 2ns/div setting, then it worked! =)
Offline mwpeters75
« Reply #1293 on: June 26, 2013, 04:02:13 am »
Thank-you for the reply Staze, much appreciated.
I also found that pressing the ch1 button twice, the ch2 button twice, and then menu once, I got a longer firmware number which showed 00.04.00.01.  May I presume that this is the 4.01 firmware then and that this is the latest?
Best regards,
Michael
Offline staze
« Reply #1294 on: June 26, 2013, 06:28:29 am »
correct. and as far as I know, it's the latest version available.
Offline maomi84
« Reply #1295 on: June 27, 2013, 08:56:24 am »
thanks a lot
but now ,my ds1052e scope version is V4.01
how do I upgrade it,thanks
Offline maomi84
« Reply #1296 on: June 27, 2013, 09:06:06 am »
thanks a lot
Offline mwpeters75
« Reply #1297 on: June 27, 2013, 01:38:59 pm »
Now that is interesting:  Maomi84's firmware is newer than mine.  00.04.01.00.02 vs 00.04.00.00.01.  I do have the 2ns horiz tim/div rate.
Does Gizmo need to do a new patch for this firmware?  What do you make of this Staze?  Thank-you, Michael
« Last Edit: June 27, 2013, 02:58:29 pm by mwpeters75 »
Offline staze
« Reply #1298 on: June 27, 2013, 03:47:50 pm »
he's got a slightly newer firmware. Yes, Gizmo would need to make a new one.
Gizmo?
Offline samertje
« Reply #1299 on: June 27, 2013, 09:55:29 pm »
Good day to you all!
First off: thank you Gizmo and others for this 3+year thread!
Went through it and got dizzy after a while  :phew:
For version 00.00.04.00.01:
1) is the serial hack still working (like shown in Dave's video)? Links?
2) where does the USB hack start in this thread for my version?
Thanks again guys and keep on hacking   :)
Sam
