Author Topic: changing the rigol DS1052E to DS1102E using USB , the dummy guide  (Read 1364094 times)
Offline luisr320
  • Country: pt
Re: changing the rigol DS1052E to DS1102E using USB , the dummy guide
« Reply #1750 on: November 13, 2015, 11:32:35 pm »
Hi. Can you please send me the latest firmware USB hack to luisr320(at)gmail(dot)com?
My Rigol DS1052E in on original firmware version 00.04.01 SP7, HW58
Thank you
« Last Edit: November 14, 2015, 03:58:54 pm by luisr320 »
Offline ahhui
  • Country: cn
« Reply #1751 on: November 17, 2015, 02:17:42 pm »
Just would like to say,glad all you guys who have emailed me are happy with the modded 00.04.02.01.00 update, Glad i could help. :-+
Hi Straycat,
    Would you please send me a copy of firmware? My scope is DS1052E with 00.04.02.01.00. Thanks a lot.
my email is ahhuic(at)yahoo.com.
« Last Edit: November 17, 2015, 02:20:38 pm by ahhui »
Offline zyxel13
  • Country: at
« Reply #1752 on: November 18, 2015, 07:06:40 pm »
Good Evening Straycat,
Thankyou for Helping us!
I just bought a Rigol DS1052E that is already modded to a DS1102E with the following Data :
SW Ver : 00.04.01.00.02
Hardware Version = 57
1) is the FW Version that is already modded upgradeable to 00.04.02 ?
2) if yes, could you please send me the Update File to : konstgrs(at)gmail(dot)com ?
Thankyou in Advance,
Cheers,
Konstantin
Offline straycat
« Reply #1753 on: November 22, 2015, 07:00:53 pm »
Hi all. Thank you again for your messages. Glad to hear i have helped a few people here, . Im an engineer for a well known company and this time of year gets very busy guys,so please bear with me as i will do my best to get round to answering as many questions as i can. Or another great way is to put them on this blog as there are many great people on here who will be more than happy to answer your questions  regarding firmware updates and any ds1000 issues. Thanks  :-+
Offline alex.electron
  • Country: by
« Reply #1754 on: November 23, 2015, 05:23:30 pm »
Can you send me hacked firmware 00.04.02 for 1052e??
alex.electron (at) mail (dot) ru
Thank you!
Offline luisr320
  • Country: pt
Re: Changing the rigol DS1052E to DS1102E using USB , the dummy guide
« Reply #1755 on: December 01, 2015, 09:32:26 am »
After slogging through 114 pages of messages, I finally took the plunge using Gizmo's most recent image file.
It's still available here: http://jahansen.com/rigol/DS1000EUpdate.00.04.01.00.02.zip
Instructions as before --
Copy the DS1000EUpdate.RGL file from the .ZIP onto a [FAT16 Formatted] memory stick, put it in the scope, and select OK when it asks if you want to update the firmware. It's that simple.
For peace of mind, check the copied file's MD5 (the one on your USB thumb drive) against the MD5 of the image file from the .ZIP.  Always do the "eject" sequence on the USB drive if using Windows before pulling the USB stick out of your PC.  The Rigol scope doesn't bother with any data integrity checking, which is rather short-sighted.  If the file is corrupted at all, you will most likely brick the scope.
Previously the readout of my Rigol DS1052E was:
Boot-up screen showed version 02.05.SP2
Serial #: DS1ED131XXXXXX
Software: 00.02.05.02.00
DSP 00.00
FPGA 02.00
HardVersion: 58
After updating I get:
The boot-up screen now shows version 04.01.
Software: 00.04.01.00.02
DSP 00.01
FPGA 03.70
HardVersion: 58
Despite the lack of a Rigol model number and serial number change, it appears that it is now a 100MHz scope.  I'm gonna haul it down to a lab with a 100MHz signal gen for testing, my generator only goes to 5MHz.  The changes in Gizmo's file survived the scope's internal recalibration and several power off/power on restarts.
That's the route I took; your mileage may differ.  Neither Gizmo nor I accept any responsibility for possible damage to, or "bricking" of your equipment.  Life's full of risks; ya bets yer money and ya takes yer chances; nothing ventured, nothing gained; and a whole bunch of other cliche's I can't recall.
Many thanks to Gizmo for his work and for answering his PM/email.
For those still looking for the most recent image file, here you go. :)
Offline hammy
« Reply #1756 on: December 01, 2015, 10:32:09 pm »
The newest patched firmware file is version 04.02.01.00 (DS1000D & E: 00.04.02.SP1). This file is distributed via email by several members of this forum on enquiry ...
(Special credits to straycat, I assume he is the originator of this patched version.)
The compare between the patched and the original file looks like this:
Patched firmware file from eevblog forum. Differs in one place from the original rigol firmware file:
hammy$ cmp -bl 50_to_100_mhz_update/04.02.01.00/DS1000EUpdate.RGL Original_Firmware_Updates/v00.04.02.01.00/DS1000EUpdate.RGL
 104092   1 ^A    11 ^I
Cheers
hammy
« Last Edit: December 04, 2015, 11:08:47 pm by hammy »
Offline luisr320
  • Country: pt
« Reply #1757 on: December 02, 2015, 12:36:00 am »
Well the one I point to works pretty well even if it is not the latest one. I asked for the latest one and got no answer. So I guess we are stuck with that one.
Offline luisr320
  • Country: pt
« Reply #1758 on: December 02, 2015, 08:58:36 am »
 104092   1 ^A    11 ^I
Cheers
hammy
Hammy, please send that latest version to my email luisr320(at)gmail(dot)com and I will set it up on a server and post a link here for everyone who may need it in the future.
Thank you
« Last Edit: December 02, 2015, 07:42:50 pm by luisr320 »
Offline hammy
« Reply #1759 on: December 02, 2015, 04:44:03 pm »
Sorry  :'(
Hammy, please send that latast version to my email .......(at)gmail(dot)com and I will set it up on a server and post a link here for everyone who may need it in the future.
Thank you!  :-+
You got an email.
Cheers
hammy
« Last Edit: December 02, 2015, 04:45:51 pm by hammy »
Offline luisr320
  • Country: pt
« Reply #1760 on: December 02, 2015, 07:42:13 pm »
Thank you, Hammy.  :)
So here is the link to the latest firmware to upgrade your RIGOL DS1052E to 100Mhz.
I claim no credit for this file as it was sent to me by Hammy. Also, read this topic before you try to install this new firmware.
CAUTION: YOU MAY BRICK YOUR RIGOL OSCILOSCOPE
I had no problems whatsoever on mine, but just be aware.
Newest patched firmware file, version 04.02.01.00 (DS1000D & E: 00.04.02.SP1):
http://www.linhadafrente.net/Luis/04.02.01.00.zip
« Last Edit: December 03, 2015, 08:59:20 am by luisr320 »
Offline Blissfull
  • Country: ve
  • All I know is I know nothing. Seriously.
« Reply #1761 on: December 04, 2015, 08:27:34 pm »
Hello.
I'm sorry my account is at zero (It seems I haven't used my account in ages, and had to register again).
Would someone mind sending me the latest 100Mhz fw for the 1052e? Thank you very much.
Question about this changed fw. IDK if the Disa protocol will advertise the equipment's capabilities, but if it does I wonder if the Mhz range change gets reflected on this too, allowing to use programs like the USB spectrum analyzer software at 100Mhz.
My email is lars.gold at gmail dot com
Edit: Disa, not Visa, it's not a CC
Ignore me please... I just saw the link. Sigh
« Last Edit: December 04, 2015, 08:34:59 pm by Blissfull »
Offline straycat
« Reply #1762 on: December 09, 2015, 01:15:24 pm »
Hi guys,. just like to thank you for your messages. i am doing my best to get round to you all. Hope all is going well with the updates to the ones iv sent it to :-+. Still busy, but will get there.
Offline straycat
« Reply #1763 on: December 09, 2015, 01:18:30 pm »
A huge thank you to luisr320 for putting a link up, will save me a lot of email sending. :-+
« Last Edit: December 09, 2015, 01:20:40 pm by straycat »
Offline Medtech1
  • Do or do not, there is no try
« Reply #1764 on: December 11, 2015, 06:45:46 pm »
I just ordered a DS1052E, and will be anxious to see what firmware they are shipping them with and if it can be upgraded to 100Mhz.
Has anyone else purchased one in the last month or so and able to upgrade?
Thanks
Michelle
  • Country: by
« Reply #1765 on: December 12, 2015, 06:12:56 pm »
Thanks
Michelle
Hi.
I purchased DS1052 in last month, it came with 04.01 SP7 firmware.
I made firmware update with cracked one successfully.
Offline Medtech1
« Reply #1766 on: December 12, 2015, 06:25:10 pm »
Hey Alex, can you please let me know exactly what method you used?  just a url? so I know? there are so many methods.
(was it this custom/hacked  firmware  http://www.linhadafrente.net/Luis/04.02.01.00.zip?)
I wouldn't mind also finding the original 4.02.01 firmware and comparing it with the modified 4.02.01 in a hex editor.   From my understanding the only change was in the one address location changing the 09 to 01.
In checking the latest firmware from RIGOL, I think this is the model series?   DS1000E/D: 00.04.02 {July 28, 2015}  showing a release date of Jul 28, 2015.. so its quite new.
Appeciate it!!
Michelle
« Last Edit: December 12, 2015, 07:18:58 pm by Medtech1 »
  • Country: by
« Reply #1767 on: December 17, 2015, 07:11:21 pm »
Appeciate it!!
Michelle
I used this firmware (4.01.XX)- https://yadi.sk/d/RTnPFN0gmJYEa
Put it on the usb flash drive and update your 1052
Offline Medtech1
« Reply #1768 on: December 18, 2015, 04:56:42 am »
Straycat/Hammy/Luis:  Can you please send me the md5 hash for:
    04.02.01.00.zip
Thanks!
Offline hammy
« Reply #1769 on: December 18, 2015, 06:43:50 pm »
$ md5 /Rigol_original_firmware/v00.04.02.01.00/DS1000EUpdate.RGL
MD5 (DS1000EUpdate.RGL) = e92489296c98852d3ac49ae3e0102303
$ md5 /50_to_100_mhz_update/v00.04.02.01.00/DS1000EUpdate.RGL
MD5 (DS1000EUpdate.RGL) = 5dd088f282e3d9653392e9ccbdea6601
The hacked firmware archive http://www.linhadafrente.net/Luis/04.02.01.00.zip
$ md5 /Downloads/04.02.01.00.zip
MD5 (04.02.01.00.zip) = 4ff8b14d7df458db37b78682de412338
Could anyone please doublecheck and confirm to build a "net of trust"?  ???
Thank you!  :-+
Cheers
hammy
Offline Medtech1
« Reply #1770 on: December 18, 2015, 10:41:32 pm »
Hammy... perfect.. thank you!!!!
Offline Medtech1
« Reply #1771 on: December 18, 2015, 11:17:04 pm »
Latest firmware for the DS1052E:   DS1000E/D: 00.04.02 {July 28, 2015}
Source:  http://beyondmeasure.rigoltech.com/acton/form/1579/001e:d-0001/0/-/-/-/-/index.htm )
Rigol sent me the latest  firmware via email which I just did a checksum:
angel-n2:/export/home/michells/rigol/RigolDirect/Rigol-Steve-HUSS_Dec18-2015 {michells}: ls -la
total 8461
drwx------   2 michells sysadmin       3 Dec 18 15:11 .
drwxr-xr-x   3 michells sysadmin       3 Dec 18 15:11 ..
-rw-------   1 michells sysadmin 4194325 Dec 18 14:19 DS1000EUpdate.RGL
angel-n2:/export/home/michells/rigol/RigolDirect/Rigol-Steve-HUSS_Dec18-2015 {michells}: digest -a md5 DS1000EUpdate.RGL
8091bfefb00433ec6b78737e25f10149
This checksum does not match the  04.02.01.00 here.. so I responded back to him (Rigol US) for a checksum to confirm.
Offline Medtech1
« Reply #1772 on: December 19, 2015, 04:11:32 am »
I noticed on the Rigol UK site, the latest FW for the DS1000E series is:
But on the US Rigol site, it says:
When I viewed the firmware I received from Rigol US today  in a hex editor, there were references to 00.04.02.00.00. So I'm a bit confused.  The Rigol US guy that emailed me also said they don't have a checksum, which surprised me a bit, since it was my understanding the scope does no FW integrity check before updating it.
I've been holding off on installing any FW until the checksums are confirmed.   ;/
Offline hammy
« Reply #1773 on: December 19, 2015, 12:59:36 pm »
Hi
could you use the strings command for this file?
$ strings v00.04.02.01.00/DS1000EUpdate.RGL |grep "00.04"
00.04.02.01.00
00.04.02.01.00
00.04.02.01.00
00.04.02.01.00
$ md5 v00.04.02.01.00/DS1000EUpdate.RGL
MD5 (v00.04.02.01.00/DS1000EUpdate.RGL) = e92489296c98852d3ac49ae3e0102303
I received the firmware file from Rigol on October 17th.
Maybe they decided to send you another version, based on your hardware revision?  :-//
Cheers
hammy
EDIT: Thank you for the updated website link!  :-+
« Last Edit: December 19, 2015, 01:03:38 pm by hammy »
Offline straycat
« Reply #1774 on: December 19, 2015, 02:52:55 pm »
Hi guys, some of you are a bit concerned about the checksum of the firmware,00.04.02.01.00.
 so iv done some checking for you.
 50mhz=E92489296C98852D3AC49AE3E0102303
100mhz=5DD088F282E3D9653392E9CCBDEA6601.
All are md5 on firmware 00.04.02.01.00 Hope this helps.  :-+
« Last Edit: December 19, 2015, 02:54:43 pm by straycat »
