0 Members and 19 Guests are viewing this topic.
Here's a solution that works for me: downgrade to 3.01, change your trigger calibration with drieg SCPI commands and next, upgrade to 4. Now I have a perfect calibration ^_^ Envoyé depuis mon Nexus 7 avec Tapatalk
and I can't download it.
I!, could someone repost the last original firmware so i can eventually revert the mod of my oscilloscope for warranty purposes?Regards
Edit: Bugger... no luck so far. I'll keep on looking anyway.
Have a working rigol by now. Thing works like a charm and have been using it already.Great Scope!I have Software version:00.04.01.00.02DSP: 00.01FPGA: 03.07HardVersion: 58I flashed the firmware with the new one gizmo linked.Flashing seemed to work, scope is still fine.However its still DS1052E.I tried turning it into the DS1102E through the DemoIDN tool.While all steps seem to work as written, when I restart the scope I get my slightly modified serial number (EB)But the scope still lists: DS1052EDid the hack succeed?I managed to go to 2.000ns nowEdit: I should note that the command :INFO:BW? returns 100
Anyone else think the fan is still a bit loud?
Hi,I have a new DS1052E with FW 00.04.01.00.02 on it. When I put a USB-stick with the 100Mhz version in, the scope asking me to do the "update" to the same version (Detect a same-version software, do you want to upgrade?). I think, it will work, but for guarantee-reasons I will have the chance to go back to the original FW. Where can I find it? A few pages before, there is a link, but it's not usable.BTW: Gizmo, great work Thanks a lot!
I think, after an upgrade to the 100Mhz Version, the only way is, to use the not cracked version (00.04.01.00.02 50MHz). So I'm searching for this version. It is on my new scope but I cant download it from the scope.
Looking for a mod firmware 00.04.01.00.02 for downgrading. Any help or ideas would be very greatfull. thank you.
...I can save the files from Rigol to sticks but it dont want to run the update mode at the start...
